Parsing a variable length string.....
John Morley
PostPosted: Thu Mar 10, 2011 1:36 pm     Reply with quote
Hi All,
I need to parse a string that contains fields of variable length. I've got it working, but my "solution" seems to be a bit of a kludge, so I'm hoping to get some other ideas!
I need to parse a string in these formats:
A=xxx, B=yyy<Cr> or A=xxx B=yyy<Cr>
These strings are identical except one has a comma separator, and the other has a space. Note the 'xxx' and 'yyy' portions can be 'x', 'xx', or 'xxx' and 'y', 'yy', or 'yyy'.
To illustrate my technique, I'll just show how I get the first part:
           for(iIndex = 2 ; Msg_Buffer[iIndex] != ',' && Msg_Buffer[iIndex] != ' ' ; iIndex++)
            DigitCount++;
         // Let's decode the address and act on it.....
         switch (DigitCount)
            case 1:   // here we have a single digit
               RcvAddress = gethexbyte(Msg_Buffer[2]);
            case 2:   // here we have 2 digits
               RcvAddress = (10 *gethexbyte(Msg_Buffer[2])) + gethexbyte(Msg_Buffer[3]);
            case 3:   // here we have 3 digits
               RcvAddress = (100 * gethexbyte(Msg_Buffer[2])) + (10 * gethexbyte(Msg_Buffer[3])) + gethexbyte(Msg_Buffer[4]) ;
Again, it's working, but it seems like there must be a 'cleaner' approach? I'd like to do it all in the 'For Loop', but the problem is that the digit 'weight' is not known until the total number of digits is determined.
Thanks,
John
John Morley
PostPosted: Thu Mar 10, 2011 2:43 pm     Reply with quote
Somehow I feel that the 'isdigit' function would be useful for parsing if x,xx,y,yyy are numbers...
newguy
PostPosted: Thu Mar 10, 2011 3:52 pm     Reply with quote
What I'd do is:
#define CR 0x0d
int1 found_A = FALSE;
int1 found_B = FALSE;
int16 first_digit = 0;
int16 second_digit = 0; // set these variable sizes to whatever you like
i = 0;
do {
   switch (MsgBuffer[i]) {
      case 'A':
         found_A = TRUE;
         found_B = FALSE;
      case 'B':
         found_B = TRUE;
         found_A = FALSE;
      default:
         if (found_A && isdigit(MsgBuffer[i]) {
            first_digit = (10 * first_digit) + (MsgBuffer[i] - 0x30);
         if (found_B && isdigit(MsgBuffer[i]) {
            second_digit = (10 * second_digit) + (MsgBuffer[i] - 0x30);
   i++;
} while (MsgBuffer[i] != CR);
This will fail if the CR isn't in the string, but the nice thing about it is that A and B can be out of order (B comes before A) and the algorithm will still properly extract your data.
I also assumed that the number is in ascii format in the string, and that's the reason for the 0x30 offset being subtracted.
