GLCD prints garbage
romanrdgz
GLCD prints garbage
PostPosted: Mon Mar 07, 2011 6:22 am     Reply with quote
I'm starting a GLCD project. When i draw some rectangles and text on the GLCD and call glcd_update(), it's printed almost OK, but there are some defects over some characters or lines.
I only thought about adding some delays around the glcd_writebyte function, but doesn't work at all.
Defects appear always at the same spots for each window i draw, but the are not the same screen pixels all the time (i mean, the problem is not death pixels).
For example, for this piece of code:
   char* tituloError [10];
   char* textoOK [3];
   pulsaOK = 1;
   sprintf(textoOK, "OK");
   if(code<10)
      sprintf(tituloError, "ERROR #0%d", code);
      sprintf(tituloError, "ERROR #%d", code);
   glcd_rect(12,10,116,54,0,ON);
   glcd_rect(13,11,115,53,1,OFF);
   glcd_rect(14,12,114,52,1,ON);
   glcd_line(30,22,98,20,OFF);
   glcd_rect(53,39,75,50,1,OFF);
   glcd_text57(36,14, tituloError, 1, ON);
   glcd_text57(58, 41, TextoOK, 1, OFF);
   glcd_update();
...I'm getting this on the GLCD:
the glcd.c library is the one included with the ccs compiler, used for a 128x64 screen. Any changed at the libraries except my attempt of fixing the problem adding delays.
Any idea where the problem could be coming from?
PostPosted: Mon Mar 07, 2011 3:05 pm     Reply with quote
There have been some bugs in the GLCD driver code in the past.
They are listed in the CCS forum archives.
What is your GLCD controller chip ? And manufacturer and model number
of the GLCD ?
What is your compiler version ?
