i2c and LTC2631 DAC
niloc
i2c and LTC2631 DAC
PostPosted: Sun Mar 06, 2011 8:21 pm     Reply with quote
Could someone please help me with my code and please forgive my newbieness. I know the code looks untidy. I am using CCS compiler ver 4.112.
I thought I had this code running in my hardware but now it doesn't. In MPLAB IDE v8.56 DEBUG, the code will run thru but will not come out of the
#use i2c(Master,sda=PIN_C4,scl=PIN_C3) line.
If I remark out the out_DAC() function the laser turns on and off and the ADC values will change in a watch window. So the problem seems to be in the i2c function
My main problem is getting the i2c to work, i have 1k8 pullups on SCL and SDA. The i2c device is a LTC2631 DAC the PIC is master and the DAC is a write only slave.
Any advice is appeciated.
cheers
//+/- 0-5v from Photo detector is read by AN0 A/D on PIC18F2685 and output
//to LTC2631 D/A on I2C channel. Laser On switch is pressed to turn on Laser
//for reading of levels and reading is held when Laser is
//turned off. Reading retained and displayed on small voltmeter until
//Clear switch is pressed
//Code as was used in ver 5 but changed to give proper memory function
#include <18F2685.h>
#device ICD=TRUE
#device adc=10
#include <stdlib.h>
#FUSES NOWDT,INTRC_IO,NOMCLR,DEBUG,NOLVP
#define Laser_Sw PIN_B0
#define Clear_Sw PIN_B1
#define Laser_Pwr PIN_C7
#define I2C_SCL  PIN_C3
#define I2C_SDA  PIN_C4
long value;
//long stored_value;
//long reading;
//int flag;
void out_DAC()                        //Function to write to D/A via I2C
    value=value*15.044;
    i2c_start();                  //Start condition
    i2c_write(0b00010000);            //Device Address
    //i2C_write(0b01110000);         //select external reference 5v not needed?
    i2c_write(0b00110000);            //Device command
    i2c_write(value>>8);          //Device data MSB
    i2c_write(value);            //Device data LSB
    i2c_stop();                 //Stop condition
   Output_low(Laser_Pwr);
   SET_TRIS_B(0xFF);
   SET_TRIS_C(0x00);
   value = 0;
   while(true)                                  //start of main loop
   setup_adc_ports(AN0_Analog);
   set_adc_channel(0);
   delay_us(10);
        while(input(Laser_Sw)==1)          //if Laser switch is off
            value = read_adc();            //Read ADC port and store in value
            delay_us(10);
            out_DAC();                    //call I2C function
         while(input(Laser_Sw)!=1)        //If Laser Sw now on
            Output_High(Laser_Pwr);          //Turn on Laser
            delay_ms(200);               //Delay for laser to settle
            delay_us(10);
            out_DAC();                    //call I2C Function
         value=read_adc(ADC_READ_ONLY);      //Laser Sw off again
         Output_Low (Laser_Pwr);
         do
         setup_adc(ADC_OFF);            //DAC will continue to
         }                                //display stored reading until
          while (input(Clear_Sw)==1);      //clear button is pressed
PostPosted: Sun Mar 06, 2011 8:49 pm     Reply with quote
What connections do you have to pins CA0 and CA1 on the LTC2631 ?
PostPosted: Sun Mar 06, 2011 8:50 pm     Reply with quote
Couple of quick comments...I make the assumption this is real hardware and NOT a simulation (Proteus,etc.)
1) In...
value=value*15.044;
I think value will be multiplied by 15 , not the floating point 15.044....
best to check what really happens, maybe a weird number is being put into 'value'.
2) You'll have to change the program build option to 'release' from 'debug' and recompile BEFORE you burn a PIC with your code otherwise is will not work as expected..
niloc
PostPosted: Sun Mar 06, 2011 9:01 pm     Reply with quote
CA0 and CA1 are at GND which according to data sheet gives address of 0010000
niloc
PostPosted: Sun Mar 06, 2011 9:10 pm     Reply with quote
1) In...
value=value*15.044;
Yeah this is real hardware
Thanks, I'll check on the value*15.044 and I hadn't considered the release from debug option. Might be an hour or two before i can get back to it. Will post an update, cheers
PostPosted: Sun Mar 06, 2011 9:20 pm     Reply with quote
That's correct, but in your code you have 3 leading zeros on the address.
It should be only 2. The slave address is left-justified.
Look at this diagram in the data sheet:
Figure 2. Typical LTC2631 Write Transaction
It shows the address is left-justified, with A6 as the top bit.
That means only 2 leading zeros.
niloc
PostPosted: Sun Mar 06, 2011 9:30 pm     Reply with quote
I changed to i2c_write(0b0010000) but still have the problem. If I // out the "out_DAC()" function then the Laser turns on and off. With the "out_DAC()" retained the Laser will not power up.Seems as though there is a problem within the i2c settings
niloc
PostPosted: Sun Mar 06, 2011 11:07 pm     Reply with quote
Seems as though the DAC chip is at fault, the SCL line, pin 2 has an internal fault to gnd at pin 4. New chips on order. Ah the joys of prototyping!!! Crying or Very sad
It is too easy to blame the code when there is a hardware problem. Wink
I'll update as soon as the new chips arrive.
