Problem compiling with CCS > 4.038
jmaurin
View user's profile Send private message Visit poster's website ICQ Number
PostPosted: Sun Mar 06, 2011 7:45 pm     Reply with quote
Hi.
I have a program with i usually compile using CCS 4.038 and everything works fine. I tried to use ANY version after 4.038, but not work, any version.
The program compiles fine, but the memory mapping where code are stored are totally crazy.
My code is to use with Microchip bootloader for 18F4550 and i have these lines to make sure my code start from the right point in memory, but it`s not working anymore.
//Bootloader
#build(reset=0x800, interrupt=0x808)
#org 0x000, 0x7ff { }
This is the RIGHT code, compiled in PCWHD 4.038
http://img845.imageshack.us/i/working.jpg/
Look at the address, start exactly where i need.
Now, this is the code generated by any CCS after 4.038
http://img402.imageshack.us/i/wrongs.jpg/
And more: this address is random. What i'm missing?
PostPosted: Mon Mar 07, 2011 9:29 am     Reply with quote
Settings.
Check the code format being generated. Normally an odd format like this, is because CCS is set to generate a different output format to the one that the MPLAB program is trying to read. The default changed during the development of V4....
jmaurin
PostPosted: Mon Mar 07, 2011 1:18 pm     Reply with quote
But where? I tried to change everything in "Output Files" and still the same problem :/
jmaurin
PostPosted: Fri Apr 15, 2011 10:45 am     Reply with quote
Up
PostPosted: Fri Apr 15, 2011 12:54 pm     Reply with quote
You didn't post a test program, so there's no real way to test your
exact problem. So I just threw together some code, that may not be in
your same configuration, and compiled it with vs. 4.120 and it works.
Here's the program:
#include <18F4550.h>
#fuses HS,NOWDT,NOLVP,PUT,NOBROWNOUT
//Bootloader
Then if I go to View/Disassembly Listing in MPLAB, I get this.
(I don't have your USB bootloader). It's working.
1:                 #include <18F4550.h>
  0800    EF04     GOTO 0x808
2:                 #fuses HS,NOWDT,NOLVP,PUT,NOBROWNOUT
3:                 #use delay(clock=20000000)
4:
5:                 //Bootloader
6:                 #build(reset=0x800, interrupt=0x808)
7:                 #org 0x000, 0x7ff { }
8:
9:
10:                //======================================
11:                void main(void)
12:                {
  0808    6AF8     CLRF 0xff8, ACCESS
  080A    9ED0     BCF 0xfd0, 0x7, ACCESS
  080C    6AEA     CLRF 0xfea, ACCESS
  080E    6AE9     CLRF 0xfe9, ACCESS
  0810    50C1     MOVF 0xfc1, W, ACCESS
  0812    0BC0     ANDLW 0xc0
  0814    090F     IORLW 0xf
  0816    6EC1     MOVWF 0xfc1, ACCESS
  0818    0E07     MOVLW 0x7
  081A    6EB4     MOVWF 0xfb4, ACCESS
13:
14:                while(1);
  081C    D7FF     BRA 0x81c
