		| Author | Message |
		| levdev
				| Output_High to one pin resets other outputs on same port |
				|  Posted: Wed Mar 02, 2011 12:18 pm |   |
				| I have come across a problem whilst migrating some code from an old PC with an old version of the CCS compiler, has anyone seen this before?
 Compiler version PCW 4.118, ICD-U64 programmer
  	  | Code: |  	  | #include <16F685.h>
 #FUSES INTRC_IO,NOWDT,PUT,MCLR,PROTECT,NOCPD,NOBROWNOUT,NOIESO,NOFCMEN
 #use delay(clock=1000000)
 setup_oscillator( OSC_1MHZ );
 setup_adc( ADC_OFF );
 setup_adc_ports( NO_ANALOGS );
 setup_ccp1(CCP_OFF);
 output_b(48);
 delay_ms(5000);
 output_high(PIN_B4);
 delay_ms(5000);
 output_high(PIN_B5);
 while(true)
 Pin B4 and B5 are connected to LED's.  When the program executes
 both LED's are on.  But then when it executes the code :
  	  | Code: |  	  | output_high(PIN_B4);
 Pin B5 goes off and only B4 is on, and when it executes the code
  	  | Code: |  	  | output_high(PIN_B5);
 then B5 goes on but B4 goes off.
 Looking at the symbol file it seems the compiler is not properly setting the bits in the ANSEL and ANSELH register during the
  	  | Code: |  	  | setup_adc_ports( NO_ANALOGS );
 I have added the function :
  	  | Code: |  	  | void No_Analog()
 #ASM ASIS
 //Page 2
 BCF 0x03,5
 BSF 0x03,6
 //ANSEL to all zeros
 MOVLW 00
 MOVWF 0x1E
 //ANSELH to all zeros
 BCF 0x1F,0
 BCF 0x1F,1
 BCF 0x1F,2
 BCF 0x1F,3
 BCF 0x03,6
 //AD converter off
 BCF 0x1F,0
 #ENDASM
 and this seems to have fixed it.  On the old compiler (PCM 3.242) it does not have this problem.  Is this another bug?
		| FvM
				|  Posted: Wed Mar 02, 2011 1:07 pm |   |
				| This can also happen, if the load current is so high, that the output pins won't reach the minimum high level. Setting a pin involves a read-modify-write cycle, the pins not set in the command are read in from the
 port. If no high level can be recognized for a pin, it will be reset.
 P.S.: The wrong ANSEL setup is a new V4.118 bug. It's corrected in V4.119.
		| PCM programmer
				|  Posted: Wed Mar 02, 2011 1:36 pm |   |
				| There's a bug in vs. 4.118 for the 16F685.  The start-up code and also the setup_adc_ports() function don't properly disable some of the analog pins,
 in the ANSEL and ANSELH registers.   Pins that are left in the analog
 state, but are used for digital i/o will be read as "0".   The PIC does a
 Read-Modify-Write operation on the whole port it writes to pin.  That's why
 all the other analog pins on that port are reset to 0 when you do an
 output_high(PIN_B4).  It reads them as 0's and writes them back as 0's.
 Also, the top two bits of ANSEL are not setup properly.
 This bug was fixed in vs. 4.119.  So if you have maintenance with CCS,
 you could upgrade and fix it.
 You could do this as a work-around:
  	  | Code: |  	  | #byte ANSEL  = 0x11E
 #byte ANSELH = 0x11F
 ANSEL = 0;     // Make all analog pins be digital i/o pins
 ANSELH = 0;
		| levdev
				|  Posted: Wed Mar 02, 2011 3:17 pm |   |
				| Thanks for the input, wish I'd asked earlier as I spent most of this afternoon tracking this one down.  I've installed the latest version and the problem is fixed for the AD initialisation at least, but now my read or write eeprom isn't working (whereas it was on the old compiler version).  Unfortunately debugging is nearly impossible because The 16F685 doesn't support debug mode, and I haven't got an RS232 port.  The test program below highlights the problem by flashing an LED.
 #use delay(clock=8000000)
 #use fast_io(B)
 void Initialise_uC()
 setup_oscillator(OSC_8MHZ);
 set_tris_b( 0b10000000 );
 output_b(0);
 void write_float(float scale)
 int i;
 for (i = 0; i < 4; i++)
 write_eeprom(i+8, *(&scale + i) );
 float read_float()
 float reading;
 int i;
 *(&reading + i) = read_eeprom(i+8);
 return reading;
 void output_LED(float j)
 float i;
 for (i=0;i<j;i=i+1)
 output_low(PIN_B4);
 float j;
 Initialise_uC();
 delay_ms(3000);
 //if switch is pressed at startup then write value to eeprom
 if( input( PIN_B7 )==0)
 write_float(20);
 output_low(PIN_B4);
 delay_ms(3000);
 j=read_float();
 output_LED(j);
 delay_ms(3000);
 Do you have any idea why this works when I compile and prgram it with the old version (3.242) but not the new version (4.119).  It should flash the LED 20 times, but when compiled with version 4.119 it flashes about 130 times.
		| PCM programmer
				|  Posted: Wed Mar 02, 2011 3:22 pm |   |
				| See this thread: http://www.ccsinfo.com/forum/viewtopic.php?t=30461
 CCS has routines to do this, for vs. 4.xxx of the compiler.  Use them
 instead of your routines.
 #include the following file in your program and call the CCS routines:
  	  | Quote: |  	  | c:\program files\picc\drivers\internal_eeprom.c
 | You cannot post new topics in this forum You cannot reply to topics in this forum
