Geps
| Using switch With Strings |
Posted: Tue Mar 01, 2011 3:29 am |
I have some code as follows:
| Code: | switch (CommandForProcessing) {
case "ABCDEFG": |
Under 4.116 it compiles, under 4.087 it doesn't, citing that the string must evaluate to a constant.
Is it valid C? And is there a workaround? Maybe a char by char comparison.....?
Cheers, |
andrewg
Joined: 17 Aug 2005 Posts: 316 Location: Perth, Western Australia
Posted: Tue Mar 01, 2011 7:30 am |
That isn't valid C, or at least what will be happening is the switch will be comparing pointers and *not* what is being pointed to!
The easiest solution is an strcmp for each command. Fancier solutions involve using a character match count for each command - basically your own strcmp but character-by-character as the characters are received. _________________ Andrew |
Wayne_
Posted: Tue Mar 01, 2011 8:11 am |
It is not valid C but is valid C++.
CCS has been incorporating in to the compiler C++ capabilities which is why it works in the later version but not the earlier one.
As stated, the C way and proberbly the solution to your problem is to use strcmp.
if (strcmp(buf, "MYVAL") == 0) ...
Again, initially CCS didn't allow constants in the strcmp function but this has changed. You may need to use a #device PASS_STRINGS=IN_RAM to make it work though. |
Geps
Posted: Tue Mar 01, 2011 4:42 pm |
How confusing! Thanks for the comments I'm back up to speed,
Cheers, |
Posted: Tue Mar 01, 2011 5:12 pm |
| Quote: | It is not valid C but is valid C++.
CCS has been incorporating in to the compiler C++ capabilities which is why it works in the later version but not the earlier one. |
If you had asked me, if CCS C implements any C++ features, I clearly rejected. Is it specified or at least mentioned somewhere? |
Wayne_
Posted: Wed Mar 02, 2011 2:51 am |
As far as I know it is not documented.
Some of the features they have implemented (I think) are
Use of strings in switch and possibly if (str1 == str2)
Variable definitions anywhere in code :-
void main ()
int i;
printf("%u", i);
int a;
printf("%u", a);
Overloaded functions (I believe)
void func1(int a);
void func1(int a, int b);
Actually this one may be in one of the C standards.
I am going from memory and program in various languages so could be a mixup on them.
There are probably be others. |
