Joined: 08 Sep 2003 Posts: 105 Location: New Castle, DE
Struct number of bits out of range error
Posted: Mon Feb 28, 2011 1:18 pm
Hello
Can someone tell me why this?
If I define the struct with element 2 as 4 bits it compiles without an issue.
struct wwvbtime { //top 32 bits received
int nu1; //top 8 bits of 32 not used
int nu2 :4; //next 7 bits of 32 not used
int mt :3; //tens of minutes
int nu3 :1; //one bit not used
int m :4; //minutes
int nu4 :2; //two bits not used
int ht :2; //tens of hours
int nu5 :1; //one bit not used
int h :4; //hours
} rxhigh;
But if I replace the 4 bits with 7 bits I get a compiler error.
"Number of bits is out of range"
With 7 bits in element 2 would make the total bits in the struct = 32.
int nu2 :7; //next 7 bits of 32 not used
int m :4; //minutes
int h :4; //hours
} rxhigh;
Compiler 4.119 PIC18F4550
Posted: Mon Feb 28, 2011 2:38 pm
You may have to email CCS for a clarification on this.
