Application of "ex_usb_bootloader.c"
lokken
PostPosted: Fri Feb 25, 2011 9:39 am     Reply with quote
I couldn't use this example for 18f14k50.
First of all I load this program using a device programmer.("ex_usb_bootloader.hex")
Than I added just these lines to my simple program;
#define _bootloader
#include <usb_bootloader.h>
Than I tried to load this program via SIOW.exe and Microchip USB HID bootloader program. But I couldn't succeed.
Could you propose anything?
Here is my schematic:
lokken
PostPosted: Sun Feb 27, 2011 5:14 am     Reply with quote
Is it related with schematic or my codes?
lokken
PostPosted: Thu Mar 03, 2011 5:13 am     Reply with quote
Is there anyone who uses USB bootloader with CCS?
Darren Rook
PostPosted: Thu Mar 03, 2011 8:31 am     Reply with quote
The CCS USB bootloader uses SIOW, not the Microchip HID software.
#include <usb_bootloader.h> simply re-arranges your HEX file to be compatible with the CCS USB CDC bootloader.
You first need to load your PIC with the actual bootloader, which is ex_usb_bootloader.c. Compile and load ex_usb_bootloader.c onto your PIC, the use SIOW to load your application (which has included usb_bootloader.h)
Read the documentation above ex_usb_bootloader.c for more help.
I came, I saw, I compiled.
dbotkin
PostPosted: Thu Mar 03, 2011 9:32 am     Reply with quote
I am using the USB bootloader on a couple of projects now. It works as it should if you (carefully) read and follow the documentation Darren mentioned. The only thing I have seen is that about 20% of the time, the load will stop and you have to start it again... I suspect it's flow control or something. When you're just sending an ASCII file, there's no error checking or correction like there would be with even a simple protocol like XMODEM. I haven't decided yet whether to just live with it, or try to implement XMODEM or a similar protocol.
sseidman
PostPosted: Thu Mar 03, 2011 4:08 pm     Reply with quote
I've been meaning to ask this, and as long as we're into the very basics of bootloading here, this seems as good a place as any.
I'd like to deploy something in quantity. I'd like a bootloader, but I also want to send firmware v1.0 to Microchip to get the bulk order preloaded, and I don't want to have to load everything myself.
What do I do?? Do I program the bootloader, then bootload a prototype, pull the hex off with the programmer, and send that hex file off to Microchip?
Sorry for the idiot question. I've got time put aside to try this on Saturday, but thought I'd float the question first as long as the thread was going this way.
PostPosted: Thu Mar 03, 2011 4:22 pm     Reply with quote
Do I program the bootloader, then bootload a prototype, pull the hex off with the programmer ?
See this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=38730
sseidman
PostPosted: Thu Mar 03, 2011 5:39 pm     Reply with quote
Thanks PCM!!!
