baud rate issue
cerr
baud rate issue
PostPosted: Mon Feb 21, 2011 5:21 pm     Reply with quote
Hi There,
I have two mcus communicating via rs-232 with each other, one is a 18f8722 and the other one a 16f883. In addition, I have hooked the 2nd USART from the 18f controller to my pc and the terminal at 9600 baud.
I get the communication there going nicely but there seems to be a problem with the 16f guy. I have hooked both Rx and Tx up to an oscilloscope and I see that one byte from the 18f takes about 1ms which is right at 9600 baud, the 16f seems to be totally out of sync and way slower. It is hooked up to a 20MHz crystal oscillator and I'm using #FUSES HS> I have also tried XT but there was no change. My #use delay(clock=20000000) is set fine too and I really don't know what the problem is here, any suggestion and hints are appreciated!
Thank you!
Ron
SherpaDoug
PostPosted: Mon Feb 21, 2011 8:00 pm     Reply with quote
Are you using a 20MHz crystal (2 pins) or a 20MHz oscillator (3 pins, power, GND & output)? If you are truly using an oscillator you should be able to use your oscilloscope to make sure the frequency is really 20MHz.
How about writing a simple loop that blinks a LED every 10 seconds. Time it with a watch to see if it is close. Use 100 or 1000 seconds to check with more precision.
John P
PostPosted: Mon Feb 21, 2011 10:40 pm     Reply with quote
If you have a scope, program the suspect processor to send out a stream of bytes each containing 0x55. That gives you alternating 1's and 0's, and you can use it to see what the baud rate actually is. If it's inconsistent, you've got an oscillator problem. If it's constant but wrong, you haven't set the baud rate properly.
cerr
PostPosted: Tue Feb 22, 2011 12:35 pm     Reply with quote
Okay, I'm sending 0x55 with a 10ms delay in between and timing seems to be fine. 1 Byte takes 1ms and then it is waiting 9 before it starts with the next one, Zoomed-in, it 1Bit is 100uS wide which should be good as well. Now, I got no rs232 converters in my circuit but the controllers don't understand each other - why would that be? If I'm not using a MAX on either side, it should still work, no? Sad
Thanks for hints!
My test code:
#include <16F883.h>
#device adc=16
#FUSES HS                       //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#USE RS232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,stream=MCU2)
  while (true){
    fprintf(MCU2,"U");
    delay_ms(10);
PostPosted: Tue Feb 22, 2011 1:16 pm     Reply with quote
Post a list of connections between the two PICs.
Is this a Proteus project or is it real hardware ?
cerr
PostPosted: Tue Feb 22, 2011 1:29 pm     Reply with quote
MCU1: Tx RC6
      Rx RC7
MCU2: Tx RG1
      Rx RG2
Connected via RS232 but not using any line converters
Real hardware.
On one side I'm using the PICDEM PIC18 dev kit from microchip. (MCU2) and on the other side an own little board that's featuring the 16f PIC (MCU1). When MCU2 sends a byte to MCU1, MCU1 would respond with a byte and MCU2 would display the response on the terminal connected to it.
Now what I get, MCU2 is sending a byte, MCU1 is properly responding but MCU2 can't really see anything (other than kbhit() returning true but there's only 0 in the buffer but 0x55 was sent back...). Now I looked at it with the scope and I see that there's a lot of echo(~1V) on MCU2's Rx line when it initially sends stuff out. this is on pins RG 1(Tx)&2(Rx). May this be the reason why kbhit kicks in too early but is not able to actually read anything smart?
And this is what I'm getting:
blue is MCU2 and red MCU1.
PostPosted: Tue Feb 22, 2011 2:03 pm     Reply with quote
Do you have a ground connection between these two boards ? Do you
have C6 connected to G2, and C7 connected to G1 ? That's what you need.
Post the test program for the 18F8722.
Also post your compiler version.
cerr
PostPosted: Tue Feb 22, 2011 2:09 pm     Reply with quote
Yes, Rx and Tx are correct and GND is connected too.
It might be a problem that MCU1 is sending signals at around 3.8V while MCU2 is sending them at 2.8V only... that could lead to a misunderstanding between the two i imagine...
PostPosted: Tue Feb 22, 2011 2:35 pm     Reply with quote
So one PIC has a 5v Vdd and the other PIC is 3.3v ? Yes, that will cause
problems with the logic levels.
cerr
PostPosted: Tue Feb 22, 2011 4:25 pm     Reply with quote
Yes I think I've figured it out, thanks for the help! Razz
Fighting with different, non electrical issues now... Rolling Eyes
