Software Uart and External Interrupt issue
david90
PostPosted: Sun Feb 20, 2011 4:48 pm     Reply with quote
//tested code with dev board.
#include <12F683.h>
#device adc=8
#FUSES INTRC                    //Internal RC Osc
#FUSES NOMCLR                   //Master Clear pin used for I/O
#FUSES FCMEN                    //Fail-safe clock monitor enabled
#use delay(clock=8000000)
#use rs232(baud=2400,parity=N,xmit=PIN_A1,rcv=PIN_A2,bits=8,errors)
int buffer[10];
int i=0;
int open_detected=0;
int close_detected=0;
   setup_adc(ADC_OFF);
   setup_timer_1(T1_DISABLED);
   setup_comparator(NC_NC);
   setup_vref(FALSE);
   setup_oscillator(OSC_8MHZ);
   enable_interrupts(INT_EXT);
   ext_int_edge( H_TO_L );
   enable_interrupts(GLOBAL); //enable interrupt
      output_high(PIN_A5);
      output_low(PIN_A5);
      if (open_detected==1)
         output_high(PIN_A0);
         output_low(PIN_A0);
         output_low(PIN_A0);
         open_detected=0;
       if (close_detected==1)
         output_low(PIN_A0);
         close_detected=0;
#INT_EXT //use external pin int to avoid polling for serial data.  Software UART does not have INT.
void INT_EXT_handler() {
      shift_left(buffer,10,0);
      buffer[0]=getc();
      if ((buffer[0]==0x57 && buffer[1]==0xA9) || (buffer[0]==0x5F && buffer[1]==0xA1))
         open_detected=1;
      if (buffer[0]==0xDF && buffer[1]==0x21)
         close_detected=1;
Whenever I power on my PIC, it immediately goes into the INT_EXT ISR and get stuck there until I send serial data to the PIC. I know for a fact that when I power up my pic, the pic doesn't even go to my infinite while loop but instead goes directly to the ISR. Why does this happen? There might be a chance that this happens because of my dev board.
PostPosted: Sun Feb 20, 2011 4:57 pm     Reply with quote
You might want to enable the PowerUpTimer ( PUT) as well as and a small delay in Main before the interrupts are enabled.
Depending on the board layout, power supply specs, etc. you might already have an interrupt from something 'glitchy'.
PostPosted: Mon Feb 21, 2011 12:36 am     Reply with quote
Read this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=43138
Why do this ? Just use a pointer or an array index.
#FUSES INTRC
If you change this fuse to INTRC_IO then you can also use PIN_A4
as an i/o pin.
