dspic30f4013 and I2C slave mode
on7nh
View user's profile Send private message Visit poster's website MSN Messenger
PostPosted: Sun Feb 20, 2011 7:11 am     Reply with quote
can somebody tell me why this piece of code is NOT working?
#include <30f4013.h>
#device adc=12
#FUSES WDT // Watch Dog Timer
#FUSES HS
#FUSES NOCKSFSM //Clock Switching is disabled, fail Safe clock monitor is disabled
#FUSES HS2_pll8 // div by 2 and  multiply the ext. clock of 30mhz /2 by 8x
#define XTAL_FREQUENCY 120000000,RESTART_WDT
#use delay(clock=XTAL_FREQUENCY)
#use rs232(stream = RS232, baud=115200,parity=N,uart2,bits=8)
#use i2c(SLAVE, SDA=PIN_F2, SCL=PIN_F3, address=0x08,FORCE_HW)
/////////////////// Variabelen /////////////////
   int led1;
/////////////////// UITGANGEN /////////////////
   #define led      PIN_B0   // output    pen 5
#INT_SI2C
void SSP_interrupt()
   if (led1 == true)
      output_low(led);
      led1 = false;
      output_high(led);
      led1=true;
   printf("i2c interrupt");
Void main()
    enable_interrupts(intr_GLOBAL);
    enable_interrupts(int_SI2C);
     enable_interrupts(int_MI2C);
   While(1)
         restart_wdt();//at least one in the main while(1) loop
I want to use this controller as slave.
I have made a test of the I2c Address from the master with another 18f controller and this is working.
Many thanks
FvM
PostPosted: Sun Feb 20, 2011 8:05 am     Reply with quote
I guess, you have used the address coding for PIC18. It's different for dsPIC, if I remember right. Refer to the dsPIC family refernce manual.
on7nh
PostPosted: Sun Feb 20, 2011 8:15 am     Reply with quote
What do you mean with "diffrent address coding"?
i found in the last PCd manual this :
#use I2C(slave,sda=PIN_C4,scl=PIN_C3 address=0xa0,FORCE_HW)
(Page 142, pcd manual Januari 2011)
FvM
PostPosted: Sun Feb 20, 2011 9:36 am     Reply with quote
The manual example clarifies, that the CCS guys aren't aware of the difference, because the 0xa0 is an invalid 7-Bit address with dsPIC. The value is written as is to the address register, but it holds a 7-Bit value.
But instead of guessing about the PCD manual, you may want to read the dsPIC handbook, as suggested, or simply try different address settings respectively poll the bus for I2C devices by the host. This is, what most practical men would do.
If I remember right, there has been a previous thread discussing the same issue.
on7nh
PostPosted: Sun Feb 20, 2011 9:53 am     Reply with quote
correct, for this reason i am using 0x08 as address
the PCD manual is Crap (Read : A bad rewritten version of the 18f manual)
now i am reading the reference manual...
on7nh
PostPosted: Wed Mar 16, 2011 3:48 pm     Reply with quote
still struggling with this problem... anyone plz?
