Potentiometer and change time of sequential leds.
Marcusfbi1
View user's profile Send private message Yahoo Messenger MSN Messenger
PostPosted: Sat Feb 19, 2011 4:40 pm     Reply with quote
I need to build a program of sequential leds with a change time for potentiometer (A/D).
I have a pic16F877A.
Would anybody help me?
PostPosted: Sat Feb 19, 2011 6:51 pm     Reply with quote
1. Setup the ADC using CCS functions. Search the forum for 'read_adc'
for sample code. Here is a link to forum's search page:
http://www.ccsinfo.com/forum/search.php
2. Make a continuous while() loop with beginning and ending braces, like this:
3. At the start of the while loop, read the ADC value. Put it in a variable
named 'led_delay'.
4. The ADC will give you a number from 0 to 255 (or 0 to 1023, if you
set it up that way). Multiply the ADC value by some number, to give the
desired range of delays (in milliseconds). Make sure you declare a
variable with a size that is big enough to hold the number.
5. Put in one or more sets of statements as shown below in the while()
loop. This will turn each LED on and off for the desired period:
output_high(LED1);
delay_ms(led_delay);
output_low(LED1);
Read the CCS manual for all the functions that you use. Make sure
you are using parameters that the function can accept. Link to manual:
http://www.ccsinfo.com/downloads/ccs_c_manual.pdf
This is a basic outline of one way to do it. But you need to do this
program. We don't want to do it for you.
