store double in eeprom
cerr
PostPosted: Thu Feb 17, 2011 11:36 am     Reply with quote
Hi There,
I'm having troubles storing an array of 16 16bit values to the eeprom and read it back.
I read all weird values :(. My functions look like this:
It's one value per iteration, VARNUM is set to 16.
void WriteToEEPROM(eevalues* data)
int8 i=0;
for (i=0; i<VARNUM; i++){
     write_eeprom((i*2),*((int8*)&(data[i]->value)));
     write_eeprom((i*2)+1,*((int8*)&(data[i]->value) + 1));
void ReadFromEEPROM(eevalues* data)
  int8 i;
  for (i = 0; i<VARNUM; i++) {
     *((int8*)&data[i]->value) = read_eeprom((i*2));
     *((int8*)&(data[i]->value)+1) = read_eeprom((i*2)+1);
What am I doing wrong here?
Thank you for assistance!
Ron
bkamen
PostPosted: Thu Feb 17, 2011 1:48 pm     Reply with quote
Honestly, instead of fluffing through all that,
I usually build myself a structure with all my stuff in it that I want to save.
Like:
struct {
   unsigned int a;
   unsigned long b;
   unsigned int32 c;
} config;
and then I basically loop around a pointer to config and save every byte to EEPROM....
As long as you load and save config, byte by byte in the same order, your structure is golden.
PostPosted: Thu Feb 17, 2011 3:34 pm     Reply with quote
Key fault though is in the pointer/array handling.
If 'data' is a pointer, then 'data[i]', is the 'i'th value pointed _to_, not a pointer.
To access the address of the element inside the array, would need:
&(data[i].value)
bkamen
PostPosted: Thu Feb 17, 2011 3:50 pm     Reply with quote
&(data[i].value)
Is that for me or him? (I don't access the array quite like that when saving).
-Ben
cerr
PostPosted: Thu Feb 17, 2011 4:55 pm     Reply with quote
Well I get it going by just taking every double apart and saving byte by byte which works fine.
Thanks for your hints & suggestions!
PostPosted: Fri Feb 18, 2011 2:57 am     Reply with quote
&(data[i].value)
-Ben
That's for the original poster, who is using 'data[i]', as if it is a pointer, by using the -> construct. No wonder it doesn't work.....
