Jody
PIC18F4550 USB CDC port b1 is not going high |
Posted: Thu Feb 17, 2011 6:59 am |
compiler version: 4.078
What works: USB connecting to the PC working perfect.
When a IC is pulling mine B1 pin high, the PIC is keeping it low... I have no idea what I am doing wrong....
What I tested: IC without PIC is going high and low like it should.
Replaced the IC...
Replaced the PIC.. and always it work except when I connect the PIC and IC together. I have the same IC on different pins.. like B0 and B2, and this works...
Included code:
#include "C:\MentorProjects\Sensa\PIC_CODE\Sensa.h"
#include <stdlib.h>
// Includes all USB code and interrupts, as well as the CDC API
#include <usb_cdc.h>
#include <float.h>
#include <string.h>
#define B0 PIN_B0
#define B1 PIN_B1
#define B2 PIN_B2
#define B3 PIN_B3
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_spi(SPI_SS_DISABLED);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
usb_cdc_init();
usb_init();
while(!usb_cdc_connected())
usb_task();
if (usb_enumerated())
if(input(pin_B1))
printf(usb_cdc_putc,"A");
if(!(input(pin_B1)))
delay_ms(400);
printf(usb_cdc_putc,"a");
#include <18F4550.h>
#device adc=8
#FUSES HSPLL //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#FUSES BORV20 //Brownout reset at 2.0V
#FUSES DEBUG //Debug mode for use with ICD
#FUSES NOIESO //Internal External Switch Over mode enabled
#FUSES NOPBADEN //PORTB pins are configured as digital I/O on RESET
#FUSES PLL5 //Divide By 5(20MHz oscillator input)
#FUSES CPUDIV1 //System Clock by 2
#FUSES USBDIV //USB clock source comes from PLL divide by 2
#FUSES VREGEN //USB voltage regulator enabled
#FUSES NOICPRT //ICPRT enabled
#use STANDARD_IO(B)
#use rs232(baud=2400,parity=N, stop =1,xmit=PIN_C6,rcv=PIN_C7,bits=8)
Posted: Thu Feb 17, 2011 8:40 am |
Try changing one line:
to
SETUP_SPI(FALSE);
This is a 'balls up' in the Wizard (has been around for a long time), which actually results in the SPI port being _enabled_. Since B1, is the SPI clock output, this might well cause what you are seeing....
Jody
Posted: Thu Feb 17, 2011 10:18 am |
Thanks I will try this tomorrow..... |
Jody
Posted: Fri Feb 18, 2011 2:23 am |
Yes that did the trick!!!
Thanks Ttelmah!!!! |
Jody
Posted: Fri Feb 18, 2011 4:18 am |
Now I am having a strange problem with B3...
Input toggles but mine code doesn't react on it...
Is this also a fuse problem??? |
Posted: Fri Feb 18, 2011 4:58 am |
Possibly.
Always with this, look at the data sheet, and the pin diagrams. What 'else' may be attached to pin B3?.
Various possible things. VPO, CCP2 and AN9.
Now the last you have potentially already dealt with. NOPBADEN, means that port B wakes up set for digital I/O. So look at the former two. VPO, is the output to drive an external USB transceiver. Not a configuration bit, but a software enabled bit. Clear by default, and only set if you configure the USB driver to use an external transceiver. Shouldn't apply. The last though is affected by a fuse. CCP2C1 or CCP2B3. These set which pin receives the CCP signal. So CCP2C1, might affect your code.
However the default here is for CCP2 to be connected to C1, so this shouldn't apply, and even if the CCP pin was connected here, unless the CCP was enabled, it shouldn't interfere.
