sharji
KeyPad problem with 16f877 PIC |
Posted: Mon Feb 14, 2011 12:40 pm |
Hello
I am new at this forum so please help me.
I have a project and I have to take the value of the keypad and send the value by using rs232 or display it on LCD screen.
The problem I have is the LCD or RS232 is working fine without adding KBD code. After I write the code, the LCD is not displaying anything and the RS232 is stop transmitting!!
I am using flex drivers for the LCD and KBD and my controller is 16F877.
This is the main code:
Code: | #include "LCD.c"
#include "Flex_KBD.c"
char k;
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
setup_counters(RTCC_INTERNAL,RTCC_DIV_1);
setup_timer_1(T1_DISABLED);
lcd_init();
kbd_init();
lcd_putc("\fReady...\n");
K=kbd_getc();
while (K=='\0') { //Loop waiting for the key
K=kbd_getc();
delay_ms(10);
printf(lcd_putc, " char: %c\n", K );
} // end of while
}// end of main
this is the keypad driver
Code: | ///////////////////////////////////////////////////////////////////////////
//// Flex_KBD.C ////
//// Generic keypad scan driver ////
//// kbd_init() Must be called before any other function. ////
//// c = kbd_getc(c) Will return a key value if pressed or /0 if not ////
//// This function should be called frequently so as ////
//// not to miss a key press. ////
//Keypad connection:
#define col0 PIN_E0
#define col1 PIN_E1
#define col2 PIN_E2
#define row0 PIN_D0
#define row1 PIN_D1
#define row2 PIN_D2
#define row3 PIN_D3
// Keypad layout:
char const KEYS[4][3] = {{'1','2','3'},
{'4','5','6'},
{'7','8','9'},
{'*','0','#'}};
#define KBD_DEBOUNCE_FACTOR 33 // Set this number to apx n/333 where
// n is the number of times you expect
// to call kbd_getc each second
void kbd_init() {
short int ALL_ROWS (void)
if (input (row0) & input (row1) & input (row2) & input (row3))
return (0);
return (1);
char kbd_getc( ) {
static byte kbd_call_count;
static short int kbd_down;
static char last_key;
static byte col;
byte kchar;
byte row;
kchar='\0';
if(++kbd_call_count>KBD_DEBOUNCE_FACTOR) {
switch (col) {
case 0 : output_low(col0);
output_high(col1);
output_high(col2);
case 1 : output_high(col0);
output_low(col1);
output_high(col2);
case 2 : output_high(col0);
output_high(col1);
output_low(col2);
if(kbd_down) {
if(!ALL_ROWS()) {
kbd_down=false;
kchar=last_key;
last_key='\0';
} else {
if(ALL_ROWS()) {
if(!input (row0))
row=0;
else if(!input (row1))
row=1;
else if(!input (row2))
row=2;
else if(!input (row3))
row=3;
last_key =KEYS[row][col];
kbd_down = true;
} else {
++col;
if(col==3)
col=0;
kbd_call_count=0;
return(kchar);
I want to know if my keypad is working fine or not and how to take the value from bottoms.
thanks ![Very Happy](images/smiles/icon_biggrin.gif) |
Posted: Mon Feb 14, 2011 6:44 pm |
We can see the pins you are using for the keypad, but what pins are you
using for the LCD and the RS-232 ? |
sharji
Posted: Tue Feb 15, 2011 12:42 am |
//LCD connection
// These pins are for the PIC development board:
// B1 enable
// B2 rs
// B3 rw
// B4 D4
// B5 D5
// E1 D6
// E0 D7
#define LCD_DB4 PIN_D0
#define LCD_DB5 PIN_D1
#define LCD_DB6 PIN_D2
#define LCD_DB7 PIN_D3
#define LCD_E PIN_A1
#define LCD_RS PIN_A3
#define LCD_RW PIN_A2
connection of an RS-232 host through the DB9 connector.
I mentioned that the code of LCD is working fine without the line in the main code
once i commented it, the LCD works fine
I have used different pins for LCD and KBD as you see on the code but it did not work. ![Sad](images/smiles/icon_sad.gif) |
sharji
Posted: Tue Feb 15, 2011 8:01 am |
Actually, I found that the pins that are used in LCD connections is same to the pins that are used in KBD connections, so I changed the pins that are connected to the KBD as following:
#define col0 PIN_E0
#define col1 PIN_E1
#define col2 PIN_E2
#define row0 PIN_B0
#define row1 PIN_B1
#define row2 PIN_B2
#define row3 PIN_B3
And the problem still the same, when I run the program without the following line, the program work fine and the LCD display what I want, but when I add the following line, the LCD does not display anything and sometimes display random things.
Posted: Tue Feb 15, 2011 11:30 pm |
1. Your while() loop in main() has large delays in it. You don't need them.
Look at the CCS example file, ex_kblcd.c, which shows how to use a
keypad and an LCD together in the same program:
Quote: |
c:\program files\picc\examples\ex_lcdkb.c
Remove the main() code from your program in your first post in this
thread. Use the main() code from ex_lcdkb.c instead.
Also delete the 7 lines of setup code below from main(). They are not needed:
setup_adc(ADC_OFF);
setup_spi(FALSE);
2. You need pull-up resistors on the Row pins for the keypad. You have
used PortB for the Row pins, so you can use the built-in pullups in the
16F877. To do this, edit the Flex keypad driver file and add the line
shown in bold below to the kbd_init() function:
Quote: |
void kbd_init()
port_b_pullups(TRUE);
If you do these changes, I think it has a chance to work. |
