Writing to lower 8 bits of a 16 bit port
pebbert9
PostPosted: Sat Feb 12, 2011 1:39 am     Reply with quote
I am trying to use bits 0-7 of port D as an 8-bit data buss. and the upper bits for address. ( My part is a PIC24H without a PMP port.)
Is there an easy way to write a byte to port D without affecting the upper 8 bits?
output_d(0x00) will set the entire port ( bits 0-15) to zero, not just bits 0-7.
I can set the bits individually, but that isn't too efficient.
Thank you,
PostPosted: Sat Feb 12, 2011 2:50 am     Reply with quote
By accessing the SFRs directly:
#word LATD  = 0x2DC
#byte LATDL = 0x2DC
#byte LATDH = 0x2DD
//e.g.
LATDL = 0x34;
TRISx can defined accordingly, if required
pebbert9
PostPosted: Sun Feb 13, 2011 12:59 am     Reply with quote
Thanks, that worked great.
BTW, I did have to manually set TRISD for it to work ( and LATD is 0x2D6 for my chip )
PostPosted: Sun Feb 13, 2011 2:37 am     Reply with quote
It's one of several ways. You can also use set_tris_d() to initialize the port as a whole.
bkamen
PostPosted: Sun Feb 13, 2011 8:33 am     Reply with quote
#word LATD  = 0x2DC
#byte LATDL = 0x2DC
#byte LATDH = 0x2DD
//e.g.
LATDL = 0x34;
You can also build a structure/union and overlay that on top of the port.
I also like "getenv" now instead of hard address assignments...
mbradley
PostPosted: Sun Feb 13, 2011 7:37 pm     Reply with quote
Just my two cents:
int8 addr;
int8 data;
void write(void)
  int16 wAddr;
  wAddr = addr<<8;
  output_d(wAddr | data);
this still writes the address in the upper 8 bits
Michael Bradley
www.mculabs.com
Open Drivers and Projects
