18F26K22 A/D example Please
Goto page 1, 2  Next
bdrmachine
PostPosted: Sat Feb 12, 2011 10:44 am     Reply with quote
I am having trouble setting up the a/d on a 18f26k22. I need to read a 10bit value from an0 only using vss/vdd as references. I have successfully configured other pics for a/d. The application is not critical. I am only wanting to use a pot to select options of a menu based on the a/d range input.
Would some one Please show me an example?
Thanks Much
Brian
PostPosted: Sat Feb 12, 2011 12:55 pm     Reply with quote
The header file for the device would be where I'd start to see what valid combinations are allowed.
Then see what peripherals need to be disabled, if required.
bdrmachine
PostPosted: Sat Feb 12, 2011 2:33 pm     Reply with quote
Thanks for the reply. I tried looking at the header file and I'm able to get the program to compile. The trouble is I'm not getting the results I would expect. I select the an0 port only as follows: setup_adc_ports(sAN0|VSS_VDD);
But when I view the ANSELA register I find it is set to 0010111b
Should it not be 00000001b? And the value = Read_ADC(); is always 00h
Brian
PostPosted: Sat Feb 12, 2011 2:39 pm     Reply with quote
Sorry but I don't have that chip or the compiler for it. Perhaps there is an example in the examples folder that will help. Several of them have ifdef.... for various PIC series.
PostPosted: Sat Feb 12, 2011 4:03 pm     Reply with quote
Post your compiler version. If it's a compiler bug, maybe I can look at
the problem later today or tomorrow.
(Always post your version. We don't remember it from your previous threads).
gpsmikey
PostPosted: Sat Feb 12, 2011 7:43 pm     Reply with quote
It looks like the 18F26k22 is very similar to the one I'm using, the 18F14K22. In that case, I wanted to use the internal reference (at 1.024 volts since the 2**10 = 1024 and the temp sensor gives 10mv/deg C it worked out very nice). I'm using the internal precision oscillator at 8mhz using the compiler directive:
#use delay(clock=8000000) // configure for 8mhz clock
With compiler version 4.114, the header did not have the correct (or any actually) info configured for the internal reference - here is the code segment I used to set it up to use the internal reference:
     // setup AD converter
     // AN2 (RA2) = ambient temp, AN10 (RA10)=htr temp
     // NOTE: the setup_adc_ports clears my selection of the Vref source
     //       so it needs to be done before I write to ADCON1.
     // => If we define VSS_VFVR using the same format as the rest of the ref
     //    config info in the .h file (0x800) then setup_adc_ports() does select
     //    the internal reference correctly and we only have to write to the
     //    VREFCON0 register to enable the FVR and select the 1x multiplier.
setup_adc_ports(AIR_PORT | HTR_PORT,VSS_VFVR);
setup_adc(ADC_CLOCK_DIV_16);
     // Have to enable the internal FVR and set to 1x
VREFCON0 = 0x90; // FVR enabled, 1x (1.024v)  (pg 245)
     //  VREFCON1 = 0x00; // DAC is disabled  (pg 246)
     //  VREFCON2 = 0x00; // DAC output disabled (pg 246)
     //  ADCON1   = 0x08; // pos vref from FVR, neg vref from Vss (pg 214,207)
     //  ADCON2   = 0x95; // Rt. justify, TAD4,Fosc/16   (pg 215)
     // setup_adc_ports(AIR_PORT | HTR_PORT);
     // check for current settings in eeprom - if first byte of eeprom is not
     // CHK_BYTE then copy defaults to eeprom else read settings from eeprom
     // into the settings structure (over write defaults).
To read the ADC, I use the following code:
// read the heater ADC channel - return raw value + cal factor for sensor
// also saves corrected reading in HTR_raw (mv)
signed int16 rd_HTR_raw()
    set_adc_channel(HTR_CHAN); // select the HTR temp channel
    delay_us(20);              // let stabilize
    HTR_raw = read_adc(ADC_START_AND_READ)+ settings.sens_cal_htr ;
    return(HTR_raw);          // return corrected raw value (mv)
Don't forget to specify the 10 bit mode with a device line near the top of your code:
#device adc=10         // 10 bit AD mode
Hope this helps - this code runs fine in my little application (2 sensors).
Note that the page number references are for the 18F14K22 chip.
mikey
mikey
bdrmachine
PostPosted: Sat Feb 12, 2011 9:09 pm     Reply with quote
Thanks Guys for the replies!
I'll check out the code early tomorrow.
P.S.
My version is 4.110
Thanks again
Brian
bdrmachine
PostPosted: Sun Feb 13, 2011 9:47 am     Reply with quote
Still no luck getting the adc to work. The ANSELA value never changes from the default POR setting (00101111b) even after the following lines execute:
No compile errors so I assume the values I'm using are valid.
How do I set the registers manually?
Brian
gpsmikey
PostPosted: Sun Feb 13, 2011 11:09 am     Reply with quote
Here are the definitions I use for the 18F14k22 - you will need to verify they are the same for your chip, but this is how I reference the registers I need to access the ADC config stuff. Note the line in my example code above to set the VREFCON0 register as an example ...
   // Processor specific ADC config info
   // Define some SFR registers we need access to ...
#BYTE VREFCON0 = 0xFBA  // Vref configuration registers
#BYTE VREFCON1 = 0xFBB
#BYTE VREFCON2 = 0xFBC
#BYTE ADCON0 = 0xFC2    // A/D converter config registers
#BYTE ADCON1 = 0xFC1
#BYTE ADCON2 = 0xFC0
#define VSS_VFVR  0x800 // new definition to use internal vref not listed in .h
#BYTE ANSEL  = 0xF7E    // Analog Select Registers
#BYTE ANSELH = 0xF7F
#BYTE OSCCON = 0xFD3    // Oscillator control register
#BYTE OSCCON2= 0xFD2
mikey
mikey
bdrmachine
PostPosted: Sun Feb 13, 2011 11:19 am     Reply with quote
Thanks! Can I also define CONFIG3H in the same way? It's address is huge (300005h). I would like to clear bit #1 (PBADEN) in this register so the portB a/d's are disabled upon POR.
Brian
gpsmikey
PostPosted: Sun Feb 13, 2011 11:58 am     Reply with quote
I'm not sure on that one - seems to me there is something funny about the config registers up there that have to be accessed via a table command or something - I have seen other posts here about that. I think that is one of the fuses - take a look in the install directory for the compiler (usually C:\Program Files\PICC ) for the file "fuses.txt" One of the entries I find in there is:
NOPBADEN PORTB pins are configured as digital I/O on RESET
which sounds like what you are looking for.
mikey
mikey
PostPosted: Sun Feb 13, 2011 3:07 pm     Reply with quote
This program should work with vs. 4.110:
#include <18F26K22.h>
#device adc=10
#fuses INTRC_IO, NOWDT, BROWNOUT, PUT, NOLVP
#use delay(clock=4M)
int16 result;
setup_adc_ports(sAN0);
setup_adc(ADC_CLOCK_DIV_4);
set_adc_channel(0);
delay_us(10);
   result = read_adc();
   printf("%lx \n\r", result);
I tested it with an 18F45K22 in hardware, with vs. 4.110, and it worked.
It displayed these values in the terminal window as I turned a trimpot
from one end to the other:
0001
0001
0034
014a
01a7
023d
032d
03ae
03ff
03ff
bdrmachine
PostPosted: Sun Feb 13, 2011 3:14 pm     Reply with quote
Thanks for the reply I'll test it out. In the mean time I have the program working using manual setting of registers and testing / toggling the GO/DONE bit.
#byte ANSELA = 0xf38
#byte ANSELB = 0xf39
#byte ANSELC = 0xf3a
#byte ANSELD = 0xf3b
#byte ANSELE = 0xf3c
#byte ADCON0 = 0xfc2
#byte ADCON1 = 0xfc1
#byte ADCON2 = 0xfc0
#byte CM1CON0 = 0xf78
#byte CM2CON0 = 0xf77
//setup_adc(ADC_CLOCK_INTERNAL);
//setup_adc_ports(sAN0|VSS_VDD);
ANSELA = 1;
ANSELB = 0;
ANSELC = 0;
ANSELD = 0;
ANSELE = 0;
ADCON0 = 1; //AN0 (only) selected and a/d enabled
ADCON1 = 0; //Vss & Vdd are reference
ADCON2 = 0x81; //Rigth justify,
CM1CON0 = 0;
CM2CON0 = 0;
Thanks Again
Brian
bdrmachine
PostPosted: Sun Feb 13, 2011 7:47 pm     Reply with quote
I tested the code with my hardware and I get the same results as before (ANSELA remains at POR value).
The manual register select code work as expected.
Brian
PostPosted: Sun Feb 13, 2011 8:53 pm     Reply with quote
The POR (power-on-reset) value of ANSEL is "all 1's" for the analog bits.
This means they are all configured as analog pins on power-up. I looked
at the .LST file for vs. 4.110 and it doesn't write to ANSELA (0xF38).
It leaves it in the power-on-reset state.
Goto page 1, 2  Next
Page 1 of 2
