davidnclare
fan motor PWM |
Posted: Wed Oct 06, 2010 2:31 pm |
My first real program, bits borrowed of here and by reading the CCS reference manual and the PIC data sheet.
I hope it may be of interest to somebody.
My first post also.
Code: | //this is a little test PWM program to drive a DC fan.
// the fan allready has some control circuit built into it.
//I susspect it has PIC and MOSFET controlling it.
//Some have been failing on site so I need to test it in the workshop.
//The fan manufacturers specified the PWM should be 1Khz
//Fan spec DC% 0 to 2 invalid run at default
// 5% motor RPM = 0
// 10% motor RPM = Minium
// 90% motor RPM = Maximum
// 95% reverse at marimum RPM
// 98 to 100% invalid run at default
// default speed 4600RPM for 24Vdc fans
// I know this program is not the best but it was a good learning experience
// to produce it. I do like making electronics do stuff.
#include <16f818.h>
#device ADC=8
#device ICD=TRUE
#use delay (internal=8mhz)
#define RIGHT_LED PIN_B0
#define LEFT_LED PIN_B1
void main(){
int16 value,potinput,scale;
value=25;
//Timer 2 set up 124 is calculated duty resolution 500 max 1024 10bit
setup_timer_2(T2_DIV_BY_16,124,1);
setup_ccp1(CCP_PWM);
setup_port_a(AN0);
setup_adc(ADC_CLOCK_DIV_16);
set_adc_channel(0);
delay_us(20);
while(TRUE){
output_low(RIGHT_LED); //Flashing led's so I know the program is running
output_high(LEFT_LED); //I could have used output_toggle()
delay_ms (250);
output_high(RIGHT_LED);
output_low(LEFT_LED);
delay_ms (250);
potinput=read_adc();
//potinput 8 bit ADC therefore 0 to 255
//max pwm 90%, 90% of 500 is 450 so max is 450-25=425
//425=255*1.6+25
//value=25 min5%
scale=potinput*1.6;
set_pwm1_duty(scale+value);
dpechman
Posted: Fri Feb 11, 2011 5:42 am |
here a variation using software controlled pwm
FAN SPEED CONTROL
SERIAL RECEIVE FORMAT(in X%): "speed=X%;"
#include <16F877A.h>
#fuses HS, NOWDT, NOLVP, NOBROWNOUT, NOPROTECT, PUT
#define FAN PIN_B2
#include <stdlib.h>
char string[10], c[31];
boolean reading=false;
char valorstring[10];
int index=0, startreading=0, endreading=0, tamanho=0, speed=0, time=0;
#use rs232(baud=9600, rcv=SERIAL_RX, xmit=SERIAL_TX)
#int_TIMER0
void TIMER0_isr(){
if(++time >= speed){
output_low(FAN);
else{
output_high(FAN);
if(time >= 100) time = 0;
#int_RDA
void rda_isr() {
int i;
if(kbhit()){
c[++index]=getc();
if(c[index]=='#' || index > 30){
index=0;
if(c[index]=='='){
inicioleitura=index;
reading=true;
if(c[index]=='%' && reading==true)
fimleitura = index;
reading = false;
size = endreading - startreading;
z=0;
for(y = startreading+1; y < endreading + size; y++){
valorstring[z++] = c[y];
strcpy(string, valorstring);
speed = atoi(string);
c="";
y=0;
void main(){
setup_timer_0(RTCC_INTERNAL | RTCC_8_BIT | RTCC_DIV_64);
enable_interrupts(INT_RDA);
while( true )
