only AN7 analog on PIC18F4550 ?
Gio
PostPosted: Thu Feb 10, 2011 5:09 am     Reply with quote
Hello !
In my application with 18f4550, I need a ADC channel and only pin RE2 is free.
AN0 to AN6 are already in use as digital, input or output and connected to other IC on the board.
Can I set only AN7 in analog mode ? I think not....
Or, can I use SETUP_ADC_PORTS (AN0_TO_AN7) for the time necessary to read the ADC value after changing the TRIS directions and then reset the baseline?
I run into problems?
Thanks in advance,
Gio
PostPosted: Thu Feb 10, 2011 6:39 am     Reply with quote
Learn by doing ! You cannot harm the PIC. If the die of the 18F4550 is similar to the 16F88 cut a small program, download into a test PIC on a breadboard and run it for 24hrs.
Don't bother with a 'simulator' ONLY test in the real world !
SherpaDoug
PostPosted: Thu Feb 10, 2011 9:04 am     Reply with quote
If you put digital voltage into an analog pin you won't hurt anything. As long as your digital lines don't mind having the analog input for a short time you should be OK.
