Blob
Joined: 02 Jan 2006 Posts: 75 Location: Neeroeteren, Limburg, Belgium
bring rs232 out of the main loop |
Posted: Wed Feb 09, 2011 3:09 am |
I have a rotating disk with some teeth (18) on it.
Depending on the position of the wheel I will have to do some actions.
I am polling on the EXTint flag bit to "see" the teeth on the disk.
The loop will increase from 0 till 17 correspoding to each tooth.
In one position I will have to send some data via RS232.
A number between 0-310 and two numbers between 0 - 256.
At low rpm this works perfectly.
But at high rpm the time between 2 interrupts is to short to send the data.
I am now using the printf function to send the information.
Is there a way to bring the actual sending out of the loop?
At the moment I lose an interrupt while waiting for the function to end.
Is there a kind of hardware register that I can fill and that will do the sending outside my main loop?
If it is outside the main loop, it has plenty of time to send, since I have to send only once each rotation.
I use a 18f2620.
#use rs232 (baud=115200, xmit=PIN_C6, rcv=PIN_C7)
printf("%Lx-%x-%x",speed,int_something,int_something_else );
Thanks in advance
Blob |
Posted: Wed Feb 09, 2011 3:12 am |
Yes.
For sending, look at STISR.C
Takes only a few uSec to put the data into a buffer.
Blob
Posted: Wed Feb 09, 2011 5:21 am |
Great, this solved the matter
Quote: | "More matter with less art" |
Blob |
