Bootloader for PIC18F46K20
D-Kens
PostPosted: Tue Feb 08, 2011 4:02 am     Reply with quote
Hello everyone !
I've been using a regular PIC18F4620 for quite some times now, and always used Tiny Bootloader to update the firmware on RS232. Now I'm switching to use PIC18F46K20, so my question is : can I use the same HEX file than with the PIC18F4620 to load the bootloader into the PIC18F46K20 or do I have to modify it ? I'm not very familiar yet with the differences between the 18F4620 and the 18F46K20, but it seems it's mostly a consumption and technology matter, and bootloader should work the same. Isn't it ? Confused
Regards,
Christophe.
PostPosted: Tue Feb 08, 2011 12:09 pm     Reply with quote
Look at the Programming Guides for each PIC. See if there are any
differences in the Config Bits and the Flash memory programming.
Webpage for 18F4620:
http://www.microchip.com/wwwproducts/Devices.aspx?dDocName=en010304
Webpage for 18F46K20:
http://www.microchip.com/wwwproducts/Devices.aspx?dDocName=en026331
I looked at this table in each Programming Guide and there is a difference.
One PIC sets the WREN bit and the other does not. I don't know if that
is accurate or not. Maybe there is an errata on the documentation.
TABLE 3-5: WRITE CODE MEMORY CODE SEQUENCE
D-Kens
PostPosted: Thu Feb 10, 2011 8:58 am     Reply with quote
Thanks for your advice : I guess I should have started by doing that. Downloaded both Programming Specifications : I'll read and compare them as soon as possible. Embarassed
