software spi problem
waqas_shafique
PostPosted: Sun Feb 06, 2011 10:30 pm     Reply with quote
I wrote a code in mikroC for SPI based TC72 temperature sensor. The code was working fine, then I converted the code into CCS C code using software spi. Now the problem is that data is being sent to the sensor (Proteus simulation) but there is no response from sensor. My code is
#include<18f452.h>
#use delay(clock=4M)
void main() {
#use spi(di=PIN_d1, DO=PIN_d2,CLK=PIN_d0,mode=0,BITS=8,BAUD=10000,DIAGNOSTIC=pin_d7,STREAM=SPI)
unsigned char msb_data;
set_tris_b(0b00000000);
output_bit( PIN_d3, 1);//chip enable
spi_xfer(spi,0x80);//Control register address
spi_xfer(spi,0x04);  // continious conversion mode ,device turn on
output_bit( PIN_d3, 0);//chip disable
delay_mS(200); //  wait for first conversion, 200 milisecond from datasheet
output_bit( PIN_d3, 1); //chip enable
spi_xfer(spi,0x02); //read address
msb_data=spi_xfer(spi,0xff); // read MSB ,0xff is dummy data
output_bit( PIN_d3, 0); //chip disable
output_b(msb_data);
PostPosted: Mon Feb 07, 2011 4:00 am     Reply with quote
Big problem _clock_.
Proteus is 'thick'. If you tell it that the chip has a 4MHz clock, it does not check that the fuses 'agree' with this.
You are specifying 'clock=4M', but not how this is generated.
Either use:
#use delay(crystal=4M)
Which will tell the compiler that the 4Mhz involves an external crystal, and it will then should setup the oscillator for this, or 'be explicit':
#fuses XT
and tell the compiler which oscillator setup to use.
Currently, the compiler will be setting the oscillator fuse to the default (external RC), which won't work....
waqas_shafique
PostPosted: Mon Feb 07, 2011 4:38 am     Reply with quote
Thanks. I tried both of your suggestions to set clock but still response is same. In proteus,the SPI debugger is showing the data from controller but the response from sensor is"??".
FvM
PostPosted: Mon Feb 07, 2011 4:50 am     Reply with quote
Doesn't sound like a compiler related problem.
PostPosted: Mon Feb 07, 2011 5:14 am     Reply with quote
What is your actual clock?.
The point is that Proteus has no understanding/awareness of your real hardware. Now you say that the "response from the sensor is '??'", but what you post, would only output one byte (and the processor would go to sleep immediately after doing this), so obviously does not match what you are actually running.
You need to start with 'what hardware have I got' - crystal frequency etc., _and then set the compiler options to match this_. Proteus will not mind if these are wrong, but the real chip _will_.
Then do some basic testing. A 'one second' LED flasher, and verify that the flashes really _do_ take one second. Only once you know you have the chip running _and running at the right speed_, move on to testing the SPI.
It is like working on a racing car. When putting it together, you _would_ check that the steering wheel turns in the right direction, and does turn the wheels, and that the brakes do come on, _before_ trying to actually drive it...
waqas_shafique
PostPosted: Tue Feb 08, 2011 4:56 am     Reply with quote
thanks , the problem solved. The problem was that the enabling pin was not set as output pin. Very Happy
