Help! PIC18F14K50 UART Problem
Masaya Tanaka
View user's profile Send private message Visit poster's website MSN Messenger
PostPosted: Fri Feb 04, 2011 4:26 am     Reply with quote
I have the problem of UART of PIC18F14K50(at 3.3V).
Data cannot be received though data can be transmitted.
Settings : TX[RB7], RX[RB5], CTS[TB6], RTS[RB4]
#include <18F14K50.h>
#device ICD=TRUE
#device adc=8
#FUSES HS
#use delay(clock=12000000, crystal)
#use rs232(baud=9600, parity=E, STOP=1, xmit=PIN_B7, rcv=PIN_B5, bits=8, restart_wdt, stream=RFMODULE, UART, ERRORS)
#use fast_io(C)
#use fast_io(B)
#define ACTIVE     1
#define INACTIVE   0
void vRfSend(char *cBuff,int iLen);
void main
   set_tris_b(0x5F);    // B7,B4 output
                        // B6,B5 input
                        // B3-B0 none
   set_tris_c(0xFF);    // C7,C5,C4,C3,C2,C0 output
                        // C6,C1 input
   enable_interrupts(INT_RDA);
   unsigned char cSend[5]
   cSend[0] = 0x01;
   cSend[1] = 0x02;
   cSend[2] = 0x03;
   cSend[3] = 0x04;
   cSend[4] = 0x05;
      vRfSend(cSend, 5);
   int iCnt;
   unsigned char buf[10];
   int itemp = 0;
   itemp = iLen;
   memcpy(buf,cBuff,itemp);
   iCnt = 0;
   while(INACTIVE == input(RF_CTS))
   // RTS INACTIVE
   output_bit(PIN_B4, INACTIVE);
   for(iCnt=0 ; iCnt < iLen ; iCnt++)
      fputc(cBuff[iCnt],RFMODULE);
   // RTS ACTIVE
   output_bit(PIN_B4, ACTIVE);
#int_RDA
void  RDA_isr(void)
   unsigned char c;
   c = 0x00;
   c = fgetc(RFMODULE);
PostPosted: Fri Feb 04, 2011 2:34 pm     Reply with quote
void main
#use fast_io(C)
#use fast_io(B)
// B6,B5 input
// B3-B0 none
// C6,C1 input
0x5F = 0101 1111 in binary. A '1' means the Port bit is an input. So you
have set Port B to all inputs, except for B5 and B7, which are outputs.
This means the UART Rx pin (B5) won't work, because you have set it
to be an output.
Also, pin B4 won't work as an output, because you have set it to be an input.
Your comments don't match your TRIS settings for Port C.
It's best to let the compiler set the TRIS. Unlike other C compilers, CCS
will set the TRIS for you. Delete the two #fast_io statements and delete
the set_tris_x() statements and let the compiler handle it.
If it still doesn't work, there may be bugs in your version. In that case,
post your compiler version. It's a 4-digit number in this format: x.xxx
and its given at the top of your .LST file.
Masaya Tanaka
PostPosted: Sat Feb 05, 2011 12:06 am     Reply with quote
Thank you for your support.
When [set_tris_b(0x5F);] was changed to [set_tris_b(0x60);], the problem was solved.
However, the problem occurs when [#use fast_io] and [set_tris_x] are deleted.
Compiler Version is PCH 4.112.
