NivNavick
PIC18F |
Posted: Mon Jan 31, 2011 9:46 am |
Hi I m looking for PIC18Fxxxx with more than 2 PWM channels and 40 pins
What are you suggesting?
THANKS |
dyeatman
NivNavick
Posted: Mon Jan 31, 2011 11:44 am |
Thanks but I want to hear peoples suggestions about PIC18F that they are familiar with. |
Posted: Mon Jan 31, 2011 1:29 pm |
You are going to need to give more info.
What do you mean by a 'channel'?. Separate timings, or just pulse widths?.
How much memory?.
NivNavick
Posted: Mon Jan 31, 2011 1:48 pm |
Just pulse width and 40 Pin, and it must to be from the pic18f series because my board isn't compatible with more or less pins.
Thank you!! |
NivNavick
Posted: Tue Feb 01, 2011 10:01 am |
hi
I have a month until my final project which I am working in it right now,
and i really need help
![Smile](images/smiles/icon_smile.gif) |
Posted: Tue Feb 01, 2011 10:43 am |
OK. Sounds as if anything with the power control PWM module will do you. Keeping it simple, so you don't have to move into devices with re-mappable pins, something like the 18F4331.
Joined: 01 Jul 2010 Posts: 9162 Location: Greensville,Ontario
Posted: Tue Feb 01, 2011 10:53 am |
You should have specified that you want HARDWARE PWM channels......
any PIC can easily to multiple channels PWM with software. |
NivNavick
Posted: Tue Feb 01, 2011 11:56 am |
Ttelmah wrote: | OK. Sounds as if anything with the power control PWM module will do you. Keeping it simple, so you don't have to move into devices with re-mappable pins, something like the 18F4331.
I looked at the DATASHEET and it's says that the device doesn't have CCP
but it has PCPPWM,
What does it mean? |
