MAX6921
Jhonny
MAX6921
PostPosted: Sun Jan 30, 2011 1:15 pm     Reply with quote
Hi!
I want to use the MAX6921 chip bit banging SPI software. Totally confused when to H or L level of the CLK and LOAD terminals. I do not understand how the shift in 20 bits? If I use a VFD tube IV-18, should be subject to a, b, c, d. .. segments and grids? How can I specify that the first digit to be written in such an 8?
Please help me a sample code because I have a headache and not feel so good.
PostPosted: Sun Jan 30, 2011 5:10 pm     Reply with quote
This thread will get you started:
http://www.ccsinfo.com/forum/viewtopic.php?t=43171
But you must learn the C language, read the CCS manual, study the CCS
data types and learn how many bits can be held by each type, and study
the shift_left() function, and modify the code to do what you need.
CCS manual:
http://www.ccsinfo.com/downloads/ccs_c_manual.pdf
Jhonny
PostPosted: Mon Jan 31, 2011 1:38 am     Reply with quote
Very thanks, I was looking for this theme! If I can not do that, then I ask you? I hope you can help me then if I do not get along.
