PIC16F877A and LCD 16x2 problem
Goto page Previous  1, 2
PostPosted: Sun Jan 23, 2011 10:02 pm     Reply with quote
I'm testing my LCD 16x2 (ABC016002A07-GHY)
This is a direct link to the data sheet:
http://www.es.co.th/Schemetic/PDF/ABC016002A07-GHY.PDF
On page 10, it gives the Backlight specifications.
To fill in the form on the LED resistor calculator website, use these values:
Number of LEDs: 1
LED voltage: 4.2
LED current: 110
Total Voltage: 5
Most of those numbers come directly from page 10 of the LCD data sheet.
Given those values, the form suggests a 7.5 ohm resistor. However, to
be safe, maybe it's better to begin with a 15 or 22 ohm resistor.
champ720
PostPosted: Tue Jan 25, 2011 12:50 am     Reply with quote
Hello, PCM
I connect series LED resistor 15 ohm, 0.5W and do anything you suggest but it doesn't work. what is next your idea ?
Thank you very much.
PostPosted: Tue Jan 25, 2011 4:20 pm     Reply with quote
That circuit only affects the backlight. You don't need the backlight
to be working. The LCD will run without it.
Did you do you all the things I listed in my post below?
http://www.ccsinfo.com/forum/viewtopic.php?t=44512&start=13
You don't need to worry about the backlight. Just do all the things
I listed in the post. Get the LCD working first.
If the LCD doesn't work, then maybe you destroyed it accidentally by
reversing the +5v and Ground connections.
champ720
PostPosted: Wed Jan 26, 2011 11:25 pm     Reply with quote
Thank you PCM,
LCD works now. I think my problem is power supply and ground is not good. When I connect PIC with GPS module, LCD works fine but GPS doesn't work.
If I use circular buffer without interrupt, it works unsmoothly. Also, I add interrupt service code (EX_SISR.c in PCWHD compiler), but nothing received through RS232. How can I solved this interrupt code problem?
This code without Interrupt
//---------------Without Interrupt--------------------//
#include <16F877A.h>          // Standard Header file for the PIC16F877A
#include <stdlib.h>
#include <math.h>
#fuses HS,NOWDT,NOPROTECT,NOLVP       // Configuration word
#use delay(clock=20000000)       // oscillator
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7)  // Standard output
#include "flex_lcd.c"
#define BUFFER_SIZE 70
int gps_data[BUFFER_SIZE]={};
int i = 0;
   lcd_putc("\f");      //Clear display
   lcd_gotoxy(1,1);
   lcd_putc("GPS Test");
      gps_data[i]=getch();
       putc(gps_data[i]);
      i++;
      if (i>BUFFER_SIZE-1)
         i=0;
This code with Interrupt
#include <stdlib.h>
#include <math.h>
BYTE buffer[BUFFER_SIZE];
BYTE next_in = 0;
BYTE next_out = 0;
#INT_RDA
void gps_isr()
   int t;
   buffer[next_in] = getc();
   t = next_in;
   next_in = (next_in+1)%BUFFER_SIZE;
   if(next_in == next_out)
         next_in = t;      //Buffer full
#define bkbhit (next_in!=next_out)
BYTE bgetc()
   BYTE c;
   while(!bkbhit) ;
      c=buffer[next_out];
      next_out=(next_out+1)%BUFFER_SIZE;
   return(c);
   lcd_gotoxy(1,1);
   delay_ms(200);
    enable_interrupts(INT_RDA);
   do
      while(bkbhit)
      putc(bgetc());
   } while (TRUE);
PostPosted: Wed Jan 26, 2011 11:44 pm     Reply with quote
do
while(bkbhit)
putc(bgetc());
} while (TRUE);
Delete the two lines in bold.
champ720
PostPosted: Wed Jan 26, 2011 11:55 pm     Reply with quote
do
while(bkbhit)
putc(bgetc());
} while (TRUE);
I delete these two lines, but it doesn't work.
PostPosted: Thu Jan 27, 2011 1:51 pm     Reply with quote
I don't understand your program.
Here, you use the LCD to display output:
lcd_gotoxy(1,1);
But then down here, you get characters from the GPS on the serial port.
But then you just transmit them back on the serial port, using putc().
What's the purpose of that ? Where is the transmit line of the PIC's
serial port going ? To the GPS ? Or to the PC ?
do
while(bkbhit)
putc(bgetc());
} while (TRUE);
Are you using a split rs232 cable, and receiving characters from the GPS
and sending them to the PC ?
Do you really want to send GPS data to the LCD, instead, and you just
made a mistake by using putc(bgetc()) above ?
Is this a Proteus program or is this real hardware ?
champ720
PostPosted: Thu Jan 27, 2011 6:14 pm     Reply with quote
Hello PCM,
I'm doing GPS data logger which display lat/long at LCD and connected laptop's usb cable for navigation. I add LCD for displaying lat/long when GPS isn't connected to laptop.
Now, I'm testing first step, receiving GPS data (by interrupt service) and display on hyper terminal. If it works, I will program code to display lat/long on LCD later. I test all on proto board.
Moreover, I attach my circuit for considering it.
Thank you,
Uploaded with ImageShack.us
ezflyr
PostPosted: Fri Jan 28, 2011 8:58 am     Reply with quote
What GPS module are you using. Post a link to the datasheet!
Your use of 500 ohm "pull-ups" on the Tx and Rx lines of the PIC is "interesting"...... My guess is that the Schmitt Trigger input on the Rx input is not compatible with your GPS receiver output. You'll probably need a proper level shifter.
John
andrewg
PostPosted: Fri Jan 28, 2011 10:51 pm     Reply with quote
I hope they aren't 33pF I'm seeing either side of the 7805! I'd expect something more like 33uF, but at least 10uF is what I'd have, maybe up to 200uF (no real upper limit) on the "out" side.
Andrew
Page 2 of 2
