Pic18F46K22 PWM
Goto page 1, 2  Next
NivNavick
Pic18F46K22 PWM
PostPosted: Thu Jan 27, 2011 12:17 pm     Reply with quote
I bought Pic18F46K22 last week and tries to run a pwm on it.
My pwm software that I wrote, worked perfectly on the PIC18F4520 but after couple of days it's stopped. I run the software on the Pic18F46K22 and nothing happened.
//Main.c File
#include <MainDefines.h>
int x=0;
/*#int_EXT
void int_isr()
 output_d(0);
 SET_TRIS_D(0x00);
 SET_TRIS_B(0x3F);
 SET_TRIS_C(0x00);
 SET_TRIS_A(0x3f);
 setup_spi(SPI_SS_DISABLED);
 setup_wdt(WDT_OFF);
 setup_timer_0(RTCC_INTERNAL);
 setup_timer_2(T2_DIV_BY_16,129,1);
 setup_timer_1 ( T1_INTERNAL | T1_DIV_BY_4 );
 //setup_timer_2(T2_DIV_BY_16,248,1);
 setup_ccp1(CCP_PWM);
 setup_ccp2(CCP_PWM);
 //setup_vref(FALSE);
 //enable_interrupts(INT_TIMER1);
 enable_interrupts(INT_EXT);
 //enable_interrupts(INT_RTCC);
   setup_wdt(WDT_OFF);
   setup_timer_1(T1_INTERNAL|T1_DIV_BY_4);         //prescale 1:4 overflow 52.4 ms
   setup_timer_2(T2_DIV_BY_16,249,1);
   setup_timer_4(T4_DIV_BY_16,129,1);
 output_d(0);
 output_c(0);
  output_bit(pin_c0,1);
//MainDefines.h Files
#ifndef _DEVICE_18F46K22_
#define _DEVICE_18F46K22_
#ifndef _18F46K22_H
#include <18F46K22.h>
#endif
#device adc=8
#FUSES HS                       //High speed Osc (> 4mhz)
#FUSES NOPUT                    //No Power Up Timer
#FUSES LVP                      //Low Voltage Programming on B3(PIC16) or B5(PIC18)
#FUSES PBADEN                   //PORTB pins are configured as analog input channels on RESET
#FUSES NOEBTRB                  //Boot block not protected from table reads
#FUSES NOCPB                    //No Boot Block code protection
#FUSES LPT1OSC                  //Timer1 configured for low-power operation
#FUSES MCLR                     //Master Clear pin enabled
#FUSES XINST
//#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8)
#endif
#ifndef MainDefines_H
#define MainDefines_H
//#define ir_in              PIN_A5
#define us_trigger         PIN_A5
#define us_right           pin_A3
#define us_front           PIN_C6
#define us_left            PIN_C4
#define us_back            PIN_A4
#define cmp                PIN_C2
#include <Hardware.h>
#include <AtomicFunctions.h>
#endif
What's wrong with the code?
PostPosted: Thu Jan 27, 2011 1:41 pm     Reply with quote
I don't know what you mean by "pwm". You have commented out the
setup_ccp1() and setup_ccp2() statements. Do you want to toggle a pin ?
Is that what you mean by "pwm" ?
Your program is too large. Remove 90% of the code in main(). It's not
needed to show the problem. If you don't need interrupts, then remove
all interrupt code. Post a small program that we can easily understand
and test. Tell us the pin that you want the pwm signal to be on.
Also tell us your CCS compiler version.
NivNavick
PostPosted: Thu Jan 27, 2011 2:45 pm     Reply with quote
I want to toggle pins C2 and C1 (the data sheet says that they are PWM pins) but they are not working as well.
I use CCS COMPILER 4.114
I did a mistake by commented out the setups (the program that are on the PIC have those setups, still the same behavior, nothing happened and the pin give me 0).
PostPosted: Thu Jan 27, 2011 3:26 pm     Reply with quote
#FUSES LVP
#FUSES XINST
These fuses are wrong. Use NOLVP and NOXINST in all your programs.
See this thread for a sample PWM program for the 18F46K22 for vs. 4.114:
http://www.ccsinfo.com/forum/viewtopic.php?t=44166&start=1
Notice how short the program is.
NivNavick
PostPosted: Thu Jan 27, 2011 11:42 pm     Reply with quote
thank you very much!!!!!!
It should works right? Very Happy Very Happy
NivNavick
PostPosted: Fri Jan 28, 2011 4:57 am     Reply with quote
When i'm adding CCP2 (PIN_C1)
both CCPS are not working
#include <18F45K22.h>
#fuses INTRC_IO,NOWDT,PUT,BROWNOUT,NOLVP
#use delay(clock=2000000)
#byte T2CON = 0xFBA
#byte PR2 = 0xFBB
#define setup_timer_2(prescaler, PR2val, postscaler) \
if(prescaler)   \
   PR2 = PR2val;  \
   T2CON =  prescaler | ((postscaler -1) << 3);  \
else            \
  T2CON = 0;
int pwm_value;
SETUP_ADC(ADC_CLOCK_INTERNAL);
SETUP_ADC_PORTS(sAN0);
setup_timer_2(T2_DIV_BY_1, 255, 1);
  pwm_value = READ_ADC();
  OUTPUT_D(pwm_value);
  set_pwm1_duty(pwm_value);
 set_pwm2_duty(pwm_value);
PostPosted: Fri Jan 28, 2011 10:40 am     Reply with quote
If nothing else, add some delay into the loop.
You can't just keep sending values to the PWM. The value update on the _next_ cycle of the PWM. Given the PWM, only updates every 256 instruction times, add at least a few hundred uSec delay to the loop somewhere. As it currently stands you are giving no time for the ADC capacitor to recharge, and outputting the value several dozen times between each possible update of the PWM.
If you want to synchronise to the PWM, then clear the timer2 interrupt flag, and wait for this to set again (just test the flag bit, no need to involve an interrupt), then read the ADC and write the new value.
NivNavick
PostPosted: Fri Jan 28, 2011 1:25 pm     Reply with quote
When I'm adding CCP2 setup it's cancels all the .
It should repair the CCP2 problem?
Can you take a look at the fuses I posted above and please tell
me why CCP3 (PIN_B5) aren't working, (I mean that it's always sends 1(5v) and I can't reset the above pin)?
Maybe one of the fuses refers to Port B and cancel the access to
the pins?
I think the problem could #FUZES NOLVP because it is he NO LOW VOLTAGE on B5 meaning high voltage,could it be the problem with CCP3?
Thanks!!!
PostPosted: Fri Jan 28, 2011 4:19 pm     Reply with quote
To make CCP2 work with vs. 4.114 with the 18F45K22 (or 18F46K22)
you need to use the substitute routine "my_setup_ccp2()" shown below.
That's because setup_ccp2() is buggy in vs. 4.114 for this series of PICs.
#byte T2CON = 0xFBA
#byte PR2 = 0xFBB
if(prescaler)   \
   PR2 = PR2val;  \
else            \
  T2CON = 0;
#byte CCP2CON  = 0xF66
#byte PWM2CON  = 0xF65
#byte ECCP2AS  = 0xF64
#byte PSTR2CON = 0xF63
void my_setup_ccp2(int32 mode)
output_low(PIN_C1);   // This assumes "standard i/o" mode is used
CCP2CON = make8(mode, 0);
PWM2CON = 0;
ECCP2AS = make8(mode, 2);
if(make8(mode, 3) == 0x00)  // If no steering pin was specified, use P1A
   PSTR2CON = 1;
my_setup_ccp2(CCP_PWM);
set_pwm1_duty(64);
set_pwm2_duty(128);
NivNavick
PostPosted: Fri Jan 28, 2011 4:43 pm     Reply with quote
the pins?
Thanks!!!
thank you very much!!!!!!!!!!!!
Do you know how to fix CCP3 ?
PostPosted: Fri Jan 28, 2011 4:56 pm     Reply with quote
Well, probably. But why do I have to do all the work ? Why don't you try.
NivNavick
PostPosted: Sat Jan 29, 2011 1:39 am     Reply with quote
I tried and my thought are that the NOLVP is the problem, but I'm not sure,
do you think it's the problem too?
PostPosted: Sat Jan 29, 2011 5:01 am     Reply with quote
No.
NOLVP, is _required_, if you are going to use the LVP programming pins for anything _but_ programming. If LVP is enabled, these pins become 'unusable', which matches what you are seeing. LVP, should _only_ be enabled if you are using a low voltage programmer that uses these pins (99.9% of programmers don't). One (faint) possibility would be, that you _are_ using such a programmer, and it's software automatically turns off the NOLVP setting, making the pins unusable.....
NivNavick
PostPosted: Sun Jan 30, 2011 1:11 am     Reply with quote
#fuses INTRC_IO//,NOLVP
when the above fuse is in my program the clock are messed up
and if I delete the fuse the clock value which was 20MH is fine
I mean with delay_ms(1); it's look like 1 sec
what is the problem?
PostPosted: Sun Jan 30, 2011 3:26 am     Reply with quote
Your timings are not going to work, because you are using an impossible combination. The internal RC oscillator, _does not offer 20MHz as an available speed_.
You _must_ start by reading the data sheet, and only using options supported by the chip you are using.
Goto page 1, 2  Next
Page 1 of 2
