koesterk
ADC definitions disappeared from header file? |
Posted: Wed Jan 26, 2011 2:25 am |
after more than 2 years I updated my PCM compiler. Unfortunately, I can't compile my code any more now. This line causes an error:
Code: | SETUP_ADC_PORTS(sAN11); |
I checked the corresponding header file "16F677.h" and I found something interesting. The version from my old compiler looks like this:
Code: | // Constants used in SETUP_ADC_PORTS() are:
#define sAN0 1 //| A0
#define sAN1 2 //| A1
#define sAN2 4 //| A2
#define sAN3 8 //| A4
#define sAN4 16 //| C0
#define sAN5 32 //| C1
#define sAN6 64 //| C2
#define sAN7 128 //| C3
#define sAN8 0x10000 //| C6
#define sAN9 0x20000 //| C7
#define sAN10 0x40000 //| B4
#define sAN11 0x80000 //| B5
#define NO_ANALOGS 0 // None
#define ALL_ANALOG 0xF00FF // A0 A1 A2 A4 C0 C1 C2 C3 C6 C7 B4 B5
// One of the following may be OR'ed in with the above using |
#define VSS_VDD 0x0000 //| Range 0-Vdd
#define VSS_VREF 0x4000 //| Range 0-Vref
The latest version of this header file looks slightly different:
// First argument:
// OR together desired pins
#define ALL_ANALOG 255 // A0 A1 A2 A4 C0 C1 C2 C3
// Optional Second argument:
#define VSS_VDD 0x0000 // Range 0-Vdd
#define VSS_VREF 0x4000 // Range 0-VrefH
Who knows why CCS has removed sAN8 .. sAN11 from this file? I found the same effect in many other header files from this chip family.
Thanks and best Regards
Klaus |
Posted: Wed Jan 26, 2011 3:13 am |
Load 4.099 instead, and swear at CCS.....
Learn a simple 'fact' about CCS. The latest releases are untested/unreliable. They seem to post code without any testing (they claimed some years ago, that they were improving this, but there has never been any sign of this becoming true....).
The last couple of releases have been full of problems, and the sections of include file 'going walkabout', is another to add to the list. On the download page, they always post the 'last known reasonably good' version as well for download, and unless you need a feature that is in the latest release, you are better off using this.
You could try just adding the defines back, but the fault does represent the 'state' of the compiler.
Joined: 01 Jul 2010 Posts: 9402 Location: Greensville,Ontario
Posted: Wed Jan 26, 2011 7:16 am |
I think one of the problems they're facing is the ever increasing number of PICs available.Way too many choices,features,etc.20 years ago,you used the 16C84 and 16F877...now there are hundreds of PIC types.
To their credit they try to get the compilers 'up to date' as fast as they can,but to try every function of every periperhal of could take them days, then there's all the CCS supplied functions and libraries(math,etc.).
It's a mind numbing task when you consider the challenge!
If you think it's simple, please, cut code to exercise and test all the hardware and software fuctions of say a PIC12F683.Might be interesting to log how many days( !) you spend on just that 'simple' PIC.
Whatever the problems are, it sure beats toggling in bootloaders on PDP-8Es ! |
gpsmikey
Posted: Wed Jan 26, 2011 8:31 am |
temtronic wrote: |
Yep !! Been there, done that ... That was why my first S-100 system used a "Morrow's Mircostuff" 8080 cpu/front panel that had an octal keypad. Still have my old "sliderule" for hand assembling octal code for the 8080 - still have the cpu and sliderule downstairs too
mikey _________________ mikey
