PIC16F877 and MCP3909 help me!
Jongnonkuk
PostPosted: Thu Jan 20, 2011 2:28 am     Reply with quote
I try to connect MCP3909 with SPI function but it isn't work!
I link Avdd, Dvdd pin to +5V and AGND, DGND pin to 0V. Is it true?
And link G0,G1 to 0V.
#include "16f877.h"
#fuses    HS,NOWDT,PROTECT,NOLVP
#use    delay(clock=10000000)
#use    rs232(baud=9600,xmit=PIN_A0,STREAM = LCD,INVERT)
#use SPI(DO = PIN_C2,DI = PIN_C3,CLK = PIN_C1,BITS = 8,MSB_FIRST,SAMPLE_RISE,stream = spiNa)
#define   CS   PIN_C0
   int a;
   int input=0;
   char i;
   set_tris_c(0b00001000);   //set port
   setup_spi(SPI_MASTER | SPI_H_TO_L); //set SPI mode
   output_low(CS);
   spi_xfer(spiNa,0b10100100); // write mode
   output_high(CS);
      output_low(CS);
      if(spi_data_is_in())
         input =spi_xfer(spiNa);
      output_high(CS);
      fputc(0xFE,LCD);fputc(0x01,LCD);fprintf(LCD,"Earth");
      fputc(0xFE,LCD);fputc(0xC0,LCD);fprintf(LCD,"ch0: %d",input);
      delay_ms(600);
Result on LCD is
 "Earth"
 "ch0: -1"
What wrong? Sad
Everybody help me, please... ><!
Jongnonkuk
PostPosted: Fri Jan 21, 2011 1:59 am     Reply with quote
so sad -.-
Jongnonkuk
PostPosted: Tue Jan 25, 2011 1:46 am     Reply with quote
No one helps me. Sad
help me, please................................................
Jongnonkuk
PostPosted: Tue Jan 25, 2011 1:47 am     Reply with quote
Code new: (not work again -.-)
#include "16f877.h"
#define   CS   PIN_C0
#define   SCK   PIN_C1
#define   SDO   PIN_C2
#define   SDI   PIN_C3
#define   MCLR        PIN_C4
void clockdata(unsigned char bits_in);
void writedata(unsigned char data_in);
   char TextBuff[16];
   int16 In;
   int16 ch0=0,ch1=0;
   char i,x=1;
   output_bit(CS,1);   // Disable chip select
   output_bit(MCLR,1);
   writedata(0b10101100);
      output_bit(CS,0);   // Active chip select
      In = 0;
      output_bit(SCK,1);   // make clock high first
      for(i=1;i<=16;i++)
         output_bit(SCK,0);
         In <<=1;
         In = In | (input(SDI) & 0x01);
         output_bit(SCK,1);
      ch0 = In;
      In = 0;
      for(i=1;i<=16;i++)
         output_bit(SCK,0);
         In<<=1;
         output_bit(SCK,1);
      ch1 = In;
      fputc(0xFE,LCD);fputc(0xC0,LCD);fprintf(LCD,"ch0: %Ld",ch0);
      fputc(0xFE,LCD);fputc(0x94,LCD);fprintf(LCD,"ch1: %Ld",ch1);
   }//while(1) ...end
   output_bit(MCLR,0);   //chip Reset
   delay_us(2);
   output_bit(MCLR,1);
   delay_us(1);
   output_bit(SCK,0);   // make clock low first
   clockdata(data_in);   // Clock in data bits.
   int bitcnt;
   for (bitcnt=8; bitcnt>0; bitcnt--)
         output_bit(SCK,1);   // clock                        // Set Clock Idle level LOW.
         if ((bits_in&0x80)==0x80) {output_bit(SDO,1);}      // PCD8544 clocks in the MSb first.
         else {output_bit(SDO,0);}
         output_bit(SCK,0);   // clock                        // Data is clocked on the rising edge of SCK.
         bits_in=bits_in<<1;                  // Logical shift data by 1 bit left.
PostPosted: Tue Jan 25, 2011 3:07 pm     Reply with quote
The reason that no one gives you a reply, is because this is a complicated
chip and no one wants to write the driver for you. I've looked at it two
times recently, and I don't have the time to write the driver for you.
Jongnonkuk
PostPosted: Tue Jan 25, 2011 7:53 pm     Reply with quote
good answer. Evil or Very Mad
thank.
PostPosted: Tue Jan 25, 2011 9:38 pm     Reply with quote
I've seen worse (harder) chips to get 'online'. Everything you need is in the data sheet, looks like SPI mode 1 for communications.
Writing a driver isn't that much of a challenge but too bad it's not available in a DIP package, far easier for my old eyes to breadboard and tinker with !
Sure looks like board layout would be 'fun', maybe Microchip has a 'test board' available ? If not, wait a week or two, someone will once they see the potential for the chip.
