Usb problems
Bilal
Usb problems
PostPosted: Sun Jan 23, 2011 1:45 pm     Reply with quote
hi. I am new to use usb MC (PIC18F4550). I am facing different problems.
Do I have to know everything about usb (protocols and other stuff) ? After that I will be able to begin to make a usb program?
And if I take a code from some where. Where I will find the driver for that to receive ma data from my PIC?
Is there any cheap (free) application for USB like a hyperterminal for Serial Port?
PostPosted: Sun Jan 23, 2011 2:44 pm     Reply with quote
USB CDC, can emulate a serial port.
No you don't really need to know anything aout USB. The code to do this comes with the CCS compiler (two serial USB examples).
Then the PC can use any serial program (like Hyperterm, or rather preferably almost any other serial program....).
Bilal
PostPosted: Sun Jan 23, 2011 3:08 pm     Reply with quote
thanks for ur help
Bilal
PostPosted: Sun Jan 23, 2011 3:10 pm     Reply with quote
Please can u explain me about 'USB connection sense pin'
FvM
PostPosted: Sun Jan 23, 2011 4:24 pm     Reply with quote
Activating and deactivation of the USB interface according to VBUS is required by the USB standard. It's only relevant for selfpowered USB devices.
dbotkin
PostPosted: Mon Jan 24, 2011 9:13 pm     Reply with quote
More to the point... the USB connection sense pin is connected to the USB +5V line to tell the PIC when the USB interface is connected. If your project is powered from the USB interface, you don't need it since you can assume the host is always there. If your widget has its own power supply, then just use the USB power thru a resistor.
