dorinjj
stdlib.h problem? |
Posted: Fri Jan 21, 2011 7:33 pm |
Hi, I'm new in c programming of pic mcu's and a new member of this forum, but in the process of c learning, I think that I discovered a problem with the "stdlib.h" library when is used with "#device ADC=10" directive.
I can't compile my code when I try to include "stdlib.h" library for use "itoa()" function when I have "#device ADC=10" directive and the error messages are:
*** Error 23 "led_test.c" Line 3(8,9): Can not change device type this far into the code
*** Error 48 "led_test.c" Line 3(9,12): Expecting a (
*** Error 43 "led_test.c" Line 3(13,15): Expecting a declaration
3 Errors, 0 Warnings.
The device which I use is PIC16F887.
What is the problem? Thank You.
#include <16F887.H>
//#include <stdlib.h> // problem!? I can't use this *
#device ADC=10 // ? *
#fuses INTRC_IO, NOMCLR, NOWDT
#use delay(clock=8M)
#use rs232(uart1, baud=9600, parity=N)
{ setup_oscillator(OSC_8MHZ);
set_tris_d(0x00);
int16 r,var;
setup_adc_ports(sAN0);
setup_adc(ADC_CLOCK_DIV_8);
set_adc_channel(0);
r =read_adc();
output_d(r);
printf("AD value is %4LD \r\n", r);
dyeatman
Posted: Fri Jan 21, 2011 7:42 pm |
Swap the second and third lines. The device declarations must always come first _________________ Google and Forum Search are some of your best tools!!!! |
dorinjj
Posted: Fri Jan 21, 2011 8:03 pm |
Thank You for reply.
Problem solved. |
Posted: Sat Jan 22, 2011 3:16 am |
I'd actually say, to avoid future problems, put the include down after _all_ the initialisation stuff. So:
1) Processor define/include
2) Any extra 'device' statements
3) Fuses and clock statements
4) device configuration (#use RS232/I2C etc.)
5) Include other stuff & defines
6) main code.
Problem is that if any included file uses RS232, or timings, it really needs to come after the clock setups, and RS232 declarations. Think of 1 to 4, as the 'header', that must be there before other code is loaded.
You can twiddle the order a little, _but_ in general, this is the safest layout to use, and is quite logical.
