delogren
Joined: 16 Jan 2011 Posts: 1 Location: Around Chicago
External interrupts for a 12F683? |
Posted: Fri Jan 21, 2011 6:54 pm |
Howdy,
I'm new to this forum. PIC chips, and the CCS compiler, but not to embedded systems..
At the moment I'm trying to write an interrupt service routine for a 12F683 to read a PWM signal from an external source and turn that into %on %off numbers to use in the main loop. But I'm all bogged down in the details...
What #FUSES flags do I set? Which pin do I use? And on and on...
Yes, I know... RTFM...
But if anyone has a code example that would help me short-circuit the learning curve, it would be much appreciated.
--del |
