PIC16F628A #int_RA Interrupt problem
bells_electronics
PostPosted: Thu Jan 20, 2011 1:07 pm     Reply with quote
hey guys
I'm having problem with #int_RA, I want an interrupt whenever any change occurs at port A. Here is my code
#include <16F628A.h>
#FUSES HS                       //High speed Osc (>4mhz)
#FUSES PUT                      //No Power Up Timer
#use delay(clock=4MHz , internal)
#define test_led PIN_B0
#INT_RDA
void port_a_isr()
  output_toggle(test_led);
  set_tris_b(0b00000000);
  set_tris_a(0b00000111);
  output_low(test_led);
  enable_interrupts(INT_RDA);
PostPosted: Thu Jan 20, 2011 1:38 pm     Reply with quote
Go to the webpage for the 16F628A and download the data sheet.
http://www.microchip.com/wwwproducts/devices.aspx?ddocname=en010210
Look in this section, which is in the "Special Features of the CPU" section.
14.5 Interrupts
Do you see any interrupt-on-change for PortA listed ?
Download the CCS compiler manual.
http://www.ccsinfo.com/downloads/ccs_c_manual.pdf
Look in this section:
#INT_xxxx
What does #INT_RDA do ?
