I want to use the ex_fat example with the pic 24hj256gp610 and a micro SD card.
I have tested the hardware with ex_mmcsd.c code and I was able to store a value in a memory location and retrieve it to check if it fit with what I set. So I think the hardware is ok, although after I format the sd card the value is the same.
When I test the ex_fat code I get the error "ERROR INITIALIZING FAT".
The sd card is formated fat32 and unit size 512.
Any idea?
Posted: Sun Jan 16, 2011 5:28 am
Obviously check that fat.c, has FAT32 selected. What compiler version?. Were quite a few reports of problems in the past.....
tzbuu
Posted: Sun Jan 16, 2011 5:35 am
I had select the #define FAT32. My compiler version is 4.105.
I also correct the "get_next_addr" and "get_prev_addr" function without any luck.
Thank you.
