Timer clock
russk2txb
Timer clock
PostPosted: Thu Jan 13, 2011 2:15 pm     Reply with quote
Maybe a dumb question, but I cannot find a clear answer. When using timer0 on RTCC, with #use delay(clock=40M, oscillator=10M), is the clock cycle 40M/4 or is it 10M/4 ?
Thanks, Russ
wind88
PostPosted: Thu Jan 13, 2011 2:24 pm     Reply with quote
Period = (256 - TMR0)*(4/fosc)*(Prescaler)
PostPosted: Thu Jan 13, 2011 2:37 pm     Reply with quote
The Timer0 is clocked at 1/4 of the PIC's oscillator speed. The oscillator
is running at 40 MHz, so the Timer is clocked at 10 MHz.
The fact that the oscillator speed is specified by the "clock=" statement
is given in the CCS manual:
#USE DELAY
Syntax: #USE DELAY (options))
Elements: Options may be any of the following separated by commas:
clock=speed speed is a constant 1-100000000 (1 hz to 100 mhz).
This number can contains commas. This number also supports the
following denominations: M, MHZ, K, KHZ. This specified the clock the
CPU runs at.
russk2txb
PostPosted: Thu Jan 13, 2011 3:16 pm     Reply with quote
Thanks PCM. Maybe you can see why it is confusing. The equation says use 4/fosc, but it is really 4/clock (as used in the #use delay function).
Regards, Russ
gpsmikey
PostPosted: Thu Jan 13, 2011 4:38 pm     Reply with quote
Hey Russ don't feel bad - I've been bitten with that one before too. Somehow I either end up with too many or too few "/4"parts of my equation when figuring things out. Shocked
mikey
mikey
