Prefekt
icd-u64 |
Posted: Mon Jan 03, 2011 1:28 pm |
Hello
When I use the ICD-64U, must the I give vdd and vcc to the pic or can the icd-64u do this?
I have bought the icd-64u and put a ic-socket only on the connector from icd-u64, but I can't program the pic. When I put the vcc and vdd from an external power supply it works.
How can I burn a 10f200 pic with the icd-u64?
regards
Volker |
dyeatman
Posted: Mon Jan 03, 2011 2:01 pm |
Taken from the ICD-U64 instructions:
Quote: | The ICD-U64 connects to your PC via a USB port and can power your target board.
Power a board at 5.0V by closing the jumper near the ICD jack inside the unit (The unit must be opened) |
_________________ Google and Forum Search are some of your best tools!!!! |
Prefekt
Posted: Tue Jan 04, 2011 12:29 am |
Ok,
But how I can open the case. I will not break the case...
regards
Volker |
dyeatman
Posted: Tue Jan 04, 2011 6:50 am |
That I don't know. I haven't tried to open mine.
Send a message to CCS tech support and ask them for the proper way... _________________ Google and Forum Search are some of your best tools!!!! |
Ken Johnson
Joined: 23 Mar 2006 Posts: 197 Location: Lewisburg, WV
Posted: Tue Jan 04, 2011 1:15 pm |
There are notches in the sides of the case. Using a flat-blade screwdriver, pry the case apart at the seams - it just snaps together.
Ken |
gpsmikey
Posted: Tue Jan 04, 2011 2:59 pm |
Here is some additional information I had come across the other day looking for info on the ICD gadget (nobody would answer me in the ICD section of the forums ). Anyway, part way down this page, there is some useful info:
http://www.ccsinfo.com/faq.php?page=connect_icd
mikey _________________ mikey
Prefekt
Posted: Sat Jan 15, 2011 6:35 am |
thanks for the information I will try out to open the case :-)
Volker |
