RS232
rafaluc
RS232
PostPosted: Mon Jan 03, 2011 5:51 am     Reply with quote
Which the difference between putc and putchar.
SherpaDoug
PostPosted: Mon Jan 03, 2011 8:05 am     Reply with quote
There is no functional difference, only aesthetic. I think if you look in the header files you will find putc is defined as putchar.
PostPosted: Mon Jan 03, 2011 9:29 am     Reply with quote
It is 'historical'.
putchar, is originally defined in K&R, as being equivalent to putc(c, stdout).
putc, in the original C implementation was equivalent to fputc, and required a stream name. On the standard C implementation, you always had three streams defined. stdin, stdout, and stderr (error output). If you just wanted to talk to stdout, and didn't want to type the name, you just use putchar.
In CCS, they are identical.
