asdf85
Can't get SPI working |
Posted: Mon Jan 03, 2011 1:05 am |
I've been trying to get the SPI communication working using the PIC16F873. I've browsed through the forum and nothing I try works.
I cant seem to get an output using the SPI_WRITE() command.
If i use the setup_spi() command, the microcontroller seems to stop working once it reaches the SPI_WRITE().
If i use the #USE SPI, the same thing happens unless i add the 'FORCE_HW', then it doesnt hang. However there is just no output even after i check the pin. I've tried it with and without the 'delay_ms' or 'delay_us'.
also, does the SCL and SDA pin require pull up resistors?
this is my code. May i know what im doing wrong? Im using compiler version 4.093
Thanks in advance
#include "16F873.h"
#include <stdio.h>
#fuses XT,NOPROTECT,NOLVP,NOWDT,NODEBUG,NOBROWNOUT
//#use SPI(MASTER,BITS=8,SAMPLE_RISE,FORCE_HW,SPI1)//,LOAD=pin_b7,DO=PIN_C5,CLK=PIN_C3)
#define SPI_MODE_0 (SPI_L_TO_H | SPI_XMIT_L_TO_H)
#define SPI_MODE_1 (SPI_L_TO_H)
#define SPI_MODE_2 (SPI_H_TO_L)
#define SPI_MODE_3 (SPI_H_TO_L | SPI_XMIT_L_TO_H)
setup_spi(SPI_MASTER | SPI_MODE_0 | SPI_CLK_DIV_16);
spi_write(0xAA);
spi_read(0);
output_low(pin_c7);
spi_write(0xAA);
spi_read(0);
output_high(pin_c7);
Posted: Mon Jan 03, 2011 3:45 am |
Start with something really simple.
Write a 'toggle a pin' program, and test it first on C3, and then on C5. Do both pins toggle OK. If not, you have found a hardware problem...
If both don't work, then oscillator problem, MCLR problem etc..
If one works not the other, 'shorted wire'....
Then re-arrange your code slightly. Fuses should be above includes like STDIO.
Basically layout should always be:
Processor include
Fuses
Clock settings
Serial (if used)
Then general includes
Are you sure whatever you are using to detect the pulse train, would see it?.
asdf85
Posted: Mon Jan 03, 2011 4:13 am |
Hi Ttelmah,
I've tested toggling both pins. What I notice is that if I remove the #USE SPI, those 2 pins toggles OK. But if #USE SPI is present, both those pins don't toggle.
I've also re-arranged my code but it still doesn't work.
I've also tried adding an ENABLE=PIN_B6 to the #USE SPI. There is a correct output coming out of pin b6 when I tested it, but nothing from SDO and CLK.
I'm pretty sure I should be able to see the pulse from SDO & CLK if there is one.
Any other ideas?
Thanks |
Posted: Mon Jan 03, 2011 5:07 am |
Not working, with #USE SPI present, is correct. The peripheral 'overrides' the pins. Means the peripheral _is_ being connected to the pins.
You say 'fairly sure'. With /16, on a 4MHz clock, the clock 'burst' will be eight cycles at 250KHz. Just 32uSec in duration. Doesn't take much to miss it.....
Try taking the division up to /64.
asdf85
Posted: Mon Jan 03, 2011 9:43 pm |
Thanks for the info.
The actual problem lied with the MCU I was using. After replacing it with another one, it worked. |
