PIC18F45K22 Issue without ICD set to TRUE
BRathbunSpaceElectronics
PostPosted: Thu Dec 30, 2010 7:53 pm     Reply with quote
I'm new to PIC programming and the CCS compiler, though I have been a programmer on DOS and Windows for decades. My first project is proving the learning curve still exists.
I strip the program down to its simplest form. I have code that monitors 2 input pins and sets a digital pattern on 4 output pins.
The code works as long as the #Device ICD=TRUE is present. If it is commented out (to save code space in the future) then the chip does not communicate to the LCD or respond to any input stimulus.
My compiler is version 4.116. My code is below.
I am running the PIC with the PLL on and a 16 MHZ xtal.
MCLR has a pull up resistor.
I am betting its something obvious but I appreciate any assistance anyone can offer.
Main.H
#include <18F45K22.h>
#device ICD=TRUE               //Comment out this line kills all functions
#device adc=8
#FUSES NOWDT
#FUSES WDT1                     //Watch Dog Timer uses 1:1 Postscale
#FUSES H4                       //High speed with 4x PLL
#FUSES BORV20                   //Brownout reset at 2.0V
#FUSES NOWRTD                   //Data EEPROM not write protected
#FUSES FCMEN                    //Fail-safe clock monitor enabled
#FUSES NOPBADEN                 //PORTB pins are configured as digital I/O on RESET
#FUSES NOWRTC                   //configuration not registers write protected
#FUSES NOWRTB                   //Boot block not write protected
#FUSES NOEBTR                   //Memory not protected from table reads
#FUSES NOEBTRB                  //Boot block not protected from table reads
#FUSES NOCPB                    //No Boot Block code protection
#FUSES MCLR                     //Master Clear pin enabled
#FUSES NOXINST                  //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#FUSES NODELAYINTOSC
#FUSES PLLEN                    //Enable PLL 4x Clock
#FUSES PRIMARY_ON
#FUSES TIMER3C0
#FUSES CCP2D2
#FUSES WDT_NOSLEEP
#use delay(clock=64Mhz, crystal)
tools.c
//  Global Pin Definitions
//I/O Pin Constants
#define Range_Select_Bit0_PIN    PIN_A0   //Range Control Bit 0
#define Range_Select_Bit1_PIN    PIN_A1   //Range Control Bit 1
#define Range_Select_Bit2_PIN    PIN_A2   //Range Control Bit 2
#define Master_Range_Select_PIN  PIN_A3   //Master Range Control Bit
#define Select_Key_Pin           PIN_B0   //Select Key Bit
#define Up_Key_Pin               PIN_B1   //Up Key Bit
#define Down_Key_Pin             PIN_B2   //Down Key Bit
#define ADC_Ready_Pin            PIN_B3   //ADC Ready Bit
#define ADC_Standby              PIN_A7   //ADC Standby Bit
//  Global Control Constants
//Range Select Constants
Const int RANGE_1    = 0;  //Range 1 Index
Const int RANGE_2    = 1;  //Range 2 Index
Const int RANGE_3    = 2;  //Range 3 Index
Const int RANGE_4    = 3;  //Range 4 Index
Const int RANGE_5    = 4;  //Range 5 Index
Const int RANGE_6    = 5;  //Range 6 Index
Const int RANGE_7    = 6;  //Range 7 Index
Const int RANGE_8    = 7;  //Range 8 Index
//  Global Control Variables
//Present Variables
int     P_Selected_Range;     //Present Selected Range
//  Functions and Procedures
//  Port Setup Functions
void SetUpAllIO(void)
//Make All Analog Pins Digital
#byte ANSELA = 0xF38
#byte ANSELB = 0xF39
#byte ANSELC = 0xF3A
#byte ANSELD = 0xF3B
#byte ANSELE = 0xF3C
ANSELA = 0;
ANSELB = 0;
ANSELC = 0;
ANSELD = 0;
ANSELE = 0;
//Set Fast IO for All
  #USE FAST_IO (All)
//Set Input and Output Assignments
  //Set A7,A4,A3,A2,A1,A0 as Output (0), A6,A5 as Input (1)
  SET_TRIS_A(0b01100000);
  //Set B all as Input (1)
  SET_TRIS_B(0b11111111);
  //Set .C6,C5,.C3... as Output (0), C7,..C4.... as Input (1)
  SET_TRIS_C(0b10010111);
  //Set D6 as Output (0), All others Input (1)
  SET_TRIS_D(0b10111111);
//  Range Functions
void  SetRange(int iRange)
   P_Selected_Range = iRange;
   Switch(P_Selected_Range) {
      Case RANGE_1 :
           //  Set Ouptut Controls
             output_low(Range_Select_Bit2_PIN);
             output_low(Range_Select_Bit1_PIN);
             output_low(Range_Select_Bit0_PIN);
             output_low(Master_Range_Select_PIN);
             Break;
      Case RANGE_2 :
             output_high(Range_Select_Bit0_PIN);
             Break;
      Case RANGE_3 :
             output_high(Range_Select_Bit1_PIN);
             Break;
      Case RANGE_4 :
             Break;
      Case RANGE_5 :
             output_high(Range_Select_Bit2_PIN);
             Break;
      Case RANGE_6 :
             output_high(Master_Range_Select_PIN);
             Break;
      Case RANGE_7 :
             Break;
       Case RANGE_8 :
              Break;
      default:
         P_Selected_Range = RANGE_1;
      }//Case
}//SetRange
//  Key Functions
void  ProcessUpKey(void)
  //Debounce 20 mS
    delay_ms(20);
  //Check if sill down
    If (!Input(Up_Key_Pin)) {
      //Wait for Key Release
        Do {} While (!Input(Up_Key_Pin));
      //Increment Range
        If (P_Selected_Range==RANGE_8)
        Else
          P_Selected_Range = P_Selected_Range+1;
      //Select Range
        SetRange(P_Selected_Range);
    }//If (!Input(Up_Key_Pin))
}//ProcessUpKey
void  ProcessDownKey(void)
  //Debounce 20 mS
    delay_ms(20);
    If (!Input(Down_Key_Pin)) {
        Do {} While (!Input(Down_Key_Pin));
      //Decrement Range
         If (P_Selected_Range==RANGE_1)
           P_Selected_Range = RANGE_8;
         Else
           P_Selected_Range = P_Selected_Range-1;
      //Select Range
    }//If (!Input(Down_Key_Pin))
}//ProcessDownKey
void  SetupSystem(void)
  setup_adc(ADC_CLOCK_DIV_2|ADC_TAD_MUL_0);
  setup_spi(SPI_SS_DISABLED);
  setup_spi2(SPI_SS_DISABLED);
  setup_wdt(WDT_OFF);
  setup_timer_0(RTCC_INTERNAL);
  setup_timer_1(T1_DISABLED);
  setup_timer_4(T4_DISABLED,0,1);
  setup_ccp1(CCP_OFF);
  setup_comparator(NC_NC_NC_NC);// This device COMP currently not supported by the PICWizard
  SetUpAllIO();
  //Delay 600 mS
    delay_ms(600);
  //Set Starting Range to No Range
    SetRange(RANGE_1);
}//SetupSystem
main.c
#include <main.h>
#include <tools.c>
  //  Setup Meter
    SetupSystem();
  //Main Outer Reset Loop
    while(TRUE){
      //Check Keys
          ProcessUpKey();
          ProcessDownKey();
    }//Main Loop End
}// Program End
PostPosted: Thu Dec 30, 2010 8:45 pm     Reply with quote
See if this thread helps.
http://www.ccsinfo.com/forum/viewtopic.php?t=28356
If not, compile your program with and without the #device ICD=TRUE
line. Compare the fuses listed at the end of the .LST file for each
compilation.
The reason for doing this is because when you invoke the
#device ICD=TRUE statement, the compiler will automatically disable
certain fuse settings. Disabling these fuses may be what allows your
program to run.
If you compare the fuses for the two compilations, it may tell you which
fuse setting is the critical one.
PIC18F45K22 Runaway Inter
PostPosted: Sun Jan 02, 2011 3:30 pm     Reply with quote
Thanks PCM Programmer, I was able to track it down to the change below.
Fuses with ICD=TRUE
Configuration Fuses:
   Word  1: F200   HSH PLLEN PRIMARY_ON FCMEN IESO
   Word  2: 0019   NOPUT NOBROWNOUT BORV20 NOWDT WDT1
   Word  3: BD00   CCP2C1 NOPBADEN CCP3B5 NODELAYINTOSC TIMER3C0 CCP2D2 MCLR
   Word  4: 0000   NOSTVREN NOLVP NOXINST DEBUG
   Word  5: C00F   NOPROTECT NOCPB NOCPD
   Word  6: E00F   NOWRT NOWRTC NOWRTB NOWRTD
   Word  7: 400F   NOEBTR NOEBTRB
Fuses without ICD=TRUE
   Word  2: 0119   NOPUT NOBROWNOUT BORV20 WDT_NOSLEEP WDT1
   Word  4: 0081   STVREN NOLVP NOXINST NODEBUG
As you can see, the Word 4 fuses are different. The DEBUG and Stack Overflow FUSES have changed and the stack overflow fuse is the one that is causing the PIC to appear lockup.
This indicates to me a stack overrun is the ultimate source of my locked up. Having not much PIC experience my guess is I have an interrupt executing without the proper interrupt routine, thus casing the stack overflow to trip. I am not implicitly enabling any interrupts in my code but my thought is that one of the functions in my setup procedure is enabling an interrupt.
Any thoughts? Thanks,
Brandon
PostPosted: Sun Jan 02, 2011 3:54 pm     Reply with quote
Fuses with ICD=TRUE
In the section above, the ICD=TRUE is disabling the Watchdog timer.
In the section above, the Watchdog timer is enabled, and at a very
rapid rate.
Solution: Edit the #fuses your original code. Delete all references
to "WDT" or anything that uses it (in the fuses). Then add NOWDT to
the fuses. Re-compile and test.
PostPosted: Sun Jan 02, 2011 4:00 pm     Reply with quote
Interrupts have to be explicitly enabled. I don't see this in your code.
I'm a bit surprized about automatic disabling of stack overflow reset with ICD. I remember, that I have traced a stack overflow under PCH V 3.xx, so the setting seemed to be compatible with ICD operation at times.
P.S.:
In the section above, the Watchdog timer is enabled, and at a very rapid rate.
Yes, sounds more plausible. Simply remove the #FUSE WDT1 setting, that cancels #FUSE NOWDT. If you intended to use a
watchdog timer, select a suitable rate.
Thanks ...
PostPosted: Mon Jan 03, 2011 9:24 am     Reply with quote
My troubleshooting skills lead me astray, turns out the WDT fuses were the issue. I'm up and running, and thanks for the help.
I'm now off to research RS232 interrupt issues.
Thanks again for all the help.
Brandon
