aruna1
need help in decimal to binary conversion |
Posted: Sun Jan 02, 2011 6:46 am |
Hi
I'm trying to read analog voltage using MCP3421 ADC chip. it is a 18 bit adc chip.it uses I2C to communicate.
when reading ADC value it send 18 bits of data as 3 sets of bytes.I captured them.since I2C_read() function returns values in integer format, 18 bits of data looks like this
byte0 = 1
byte1 = 149
byte2 = 81
so if i convert each byte to binary,then merge them and finally convert merged binary value to decimal I get the correct ADC value.(i use a calculator and did it manually)
my question is how to convert these values to binary and merged converted data to recover original 18bit value and hence calculate the adc reading.
is there any built in function for this? perhaps a ready-made code part?
thank you very much |
ezflyr
Posted: Sun Jan 02, 2011 7:16 am |
Yes, look at the Make16 function, it's ready-made for this type of operation.
John |
aruna1
Posted: Sun Jan 02, 2011 7:47 am |
ezflyr wrote: | Hi,
John |
hi
thank you ezflyr. I will try. |
Posted: Sun Jan 02, 2011 8:13 am |
You will actually need the make32 function, not make16, since the value you have is 18bits. Just put a 'zero' for the top byte.
You'll need to hold the result in an int32, since CCS, doesn't intrinsically have any numeric 'types' between an int16, and an int32.
aruna1
Posted: Sun Jan 02, 2011 11:10 am |
Ttelmah wrote: | You will actually need the make32 function, not make16, since the value you have is 18bits. Just put a 'zero' for the top byte.
It didn't work with make32.
Here is my code,
output value of make32 for (data0=1,data1=81,data2=142) is 65617.
This is incorrect.
Then I tried three 8bit values 255,255,255 manually and it gave correct value.
Can you point me the error
#include "E:\My Electronic projects\gyro test\i2c\main.h"
int ack[3];
int16 data[4];
int32 value;
int16 data0;
int16 data1;
int16 data2;
int16 data3;
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
i2c_start();
ack[0]=i2c_write(0xD0);//set to write mode
ack[1]=i2c_write(0x9C);//config bits-18bit adc,1 pga
i2c_stop();
delay_ms(10);
printf("\n ack0 = %d\r",ack[0]);
printf("\n ack0 = %d\r",ack[1]);
printf(".............................\n\r");
//if(!input(PIN_D1))
output_toggle(PIN_D0);
//i2c_write(0x00);
i2c_start();
ack[2]=i2c_write(0xD1);//read command
data0=i2c_read(1);
data1=i2c_read(1);
data2=i2c_read(1);
data3=i2c_read(1);// config bits
//data[4]=i2c_read(0);
i2c_stop();
delay_ms(10);
value = make32(data0,data1,data2);
printf("\n data0 = %Ld\r",data0);
printf("\n data1 = %Ld\r",data1);
printf("\n data2 = %Ld\r",data2);
printf("\n data3 = %Ld\r",data3);
printf("\n value = %Ld\r",value);
printf("\n--------------------------------------------------------\r");
// TODO: USER CODE!!
ezflyr
Posted: Sun Jan 02, 2011 11:56 am |
Yeah, I (obviously) meant Make32. I was hoping to alert you to these built in CCS functions, and then have you consult the CCS manual for further assistance.....
I think you've got the order of your 8 bit integer values reversed. Note that the manual says 'MSB first', and the example shown clearly illustrates that order.....
Your 'test case' is unfortunate because '255' yields the same result with Make32 in any order!!
Good Luck!
John |
aruna1
Posted: Sun Jan 02, 2011 11:58 am |
ezflyr wrote: | Hi,
Good Luck!
John |
hi
order is correct
device sends MSB first and LSB last
so data0 contains MSB & data2 contains LSB |
gpsmikey
Posted: Sun Jan 02, 2011 12:00 pm |
A quick read shows you don't have the same byte order in your example that is wrong as you listed above (1,81,142) vs (1,149,81) also, from the example in the compiler manual where they show "x = make32(1,2,3,4); // x is 0x01020304" it looks like the default is hex - are the numbers you are using decimal ???
mikey _________________ mikey
aruna1
Posted: Sun Jan 02, 2011 12:03 pm |
gpsmikey wrote: | A quick read shows you don't have the same byte order in your example that is wrong as you listed above (1,81,142) vs (1,149,81) also, from the example in the compiler manual where they show "x = make32(1,2,3,4); // x is 0x01020304" it looks like the default is hex - are the numbers you are using decimal ???
mikey
hi
It seems second order I listed is wrong (typing error).
And data is integer. |
ezflyr
Posted: Sun Jan 02, 2011 12:21 pm |
I haven't used this function in a while, but you've got everything right there, why not just play with it and see if it works the way you expect if you pass the function the hex representation of your numerical values? Just hard code some values for test purposes and see if it works.
BTW, there is nothing magic about any of the 'Make' functions. You can roll your own equivalents very easy to do exactly what YOU need to do. You've really got to get in the habit of playing around with this stuff, and trying different things!!
John |
FvM
Posted: Sun Jan 02, 2011 12:28 pm |
Your code is supposed to give correct data in 18 Bit mode of the ADC, if data0 to data2 are int8 data. You have defined them as
int16, which can't work. Code: | ack[2]=i2c_write(0xD1);//read command
data0=i2c_read(1);
data1=i2c_read(1);
data2=i2c_read(1);
i2c_stop();
value = make32(data0,data1,data2); |
Code: | it looks like the default is hex - are the numbers you are using decimal ??? |
make32() is assembling int8 or int16 data to int32. It doesn't care for decimal, hex or whatever. Binary data are just binary data. |
aruna1
Posted: Sun Jan 02, 2011 12:30 pm |
FvM wrote: | Your code is supposed to give correct data in 18 Bit mode of the ADC, if data0 to data2 are int8 data. You have defined them as
data0=i2c_read(1);
data1=i2c_read(1);
data2=i2c_read(1);
i2c_stop();
make32() is assembing int8 or int16 data to int32. It doesn't care for decimal, hex or whatever. Binary data are just binary data. |
hi i tried int8 but final value begin to give negative value.i tried making it unsigned int8 but it didnt solve.so i changed it to int16 |
gpsmikey
Posted: Sun Jan 02, 2011 12:40 pm |
Quote: | make32() is assembling int8 or int16 data to int32. It doesn't care for decimal, hex or whatever. Binary data are just binary data. |
Well, sort of - unless the compiler is thinking you are giving it a hex number when you say "81" and you are thinking decimal "81" (0x51). It is those "out of sight helps" that will bite you :-) If the byte that was listed as "81" was printed using the %ud, then you have converted it for *your* viewing pleasure - if you stuff that back into something that is expecting hex, you will not get the result you expect. That said, 01010001 in binary is indeed 0x51 hex or 81 decimal as you indicated - it is the sneaky translation that can get you ... (been there, done that ... felt foolish when I realized ! )
Posted: Sun Jan 02, 2011 1:00 pm |
The problem is that you are putting the received values into int16's, rather than int8's. Change data0 to 3, to be int8 values, and it should work
What is happening, is that you are presenting make32, with 6 bytes (3 * int16 values), which won't fit into an int32.....
You need to change the prints for the bytes, to be %u, otherwise if the top bit is set, they will print as -ve....
I see several other have posted the answer, while I have been cooking my evening meal!....
gpsmikey
Posted: Sun Jan 02, 2011 1:50 pm |
Evening meal ?!? Not even time for hot buttered rum here yet ... well, maybe it is !
