internal eeprom management
altra22
PostPosted: Sat Jan 01, 2011 1:39 pm     Reply with quote
Hi All
Can I implement ex_malloc.c example to internal eeprom ? My PIC is 16F876A which has 256 byte of EEPROM. I want to store users and delete users (Rarely).
So I cannot do it while run-time via Serial interface. In other memories
when the PIC Power fail/down all variables are gone so I am going to store about 100 bytes ->10 users 9 char +null character in EEPROM.
But should I store also the pointers and structures to EEPROM
   write_eeprom(i,num);
   write_eeprom(i,key);
   write_eeprom(i,count);
   write_eeprom(i,* beginCell);
   write_eeprom(i,* endCell);
   write_eeprom(i,* pCell);
   write_eeprom(i,* pCell2);
No simulators here but real hardware. My version 4.105.
Thanks in Advance
PostPosted: Sat Jan 01, 2011 2:37 pm     Reply with quote
Realistically, just do it yourself.
Malloc is too complex for what you describe.
Just treat the entries as 'records' Add a flag to say that the record is active (why would you want a null, this is part of string management....). Store this as a separate array at the start of the EEPROM. Then on boot up, just read these flags. If it is non zero (active), read the nine byte record and transfer to your RAM array (and add the termination). If it is zero, advance to the next record. When you need to add a record, just look for the first zero flag. Effectively you are implementing a very crude 'FAT' system.
