pebbert9
SPI EEPROM with a Explorer 16 Board |
Posted: Fri Dec 31, 2010 12:45 am |
I am trying to get the 25LC256 EEPROM on an Explorer 16 board to work.
I found this http://www.ccsinfo.com/forum/viewtopic.php?t=28199&start=1 which seems to explain everything clearly.
I've edited the SELECT, CLK, DI, and DO pins to conform to the Explorer 16 board, but when I look at the pins on a scope I'm not getting any signals to them.
I am using PCWHD v4.116
I then found this driver which doesn't use the built-in SPI functions http://www.ccsinfo.com/forum/viewtopic.php?t=38064 . This driver does drive signals to the pins.
The SPI port doesn't seem to be setting up correctly. Any ideas why I am not getting any signals to the CLK, DI, and DO pins?
Here is the test code:
Code: | #include <24FJ128GA010.h>
#device ICD=TRUE
#fuses NOIESO // No 2-speed Start Up
#fuses NOJTAG // No JTAG
#fuses NOPROTECT // No Memory Protection
#fuses NOWDT // No WatchDog Timer
#fuses NODEBUG // Debug Mode.
#FUSES CKSFSM // Clock Switching is enabled, fail Safe clock monitor is enabled
#use delay(clock=8000000)
#use rs232(baud=9600, xmit=PIN_F4, rcv=PIN_F5, ERRORS)
#define SPI_MODE_0_0 0x4000
#define SPI_MODE_0_1 0x0000
#define SPI_MODE_1_0 0x0010
#define SPI_MODE_1_1 0x4010
// If your hardware SPI pins are different than the
// ones used on the 16F877, then define them here
// and un-comment this section.
#define EEPROM_SELECT PIN_D12
#define EEPROM_CLK PIN_G6
#define EEPROM_DI PIN_G8
#define EEPROM_DO PIN_G7
#include <25LC640_Hardware_SPI.c>
#include <STDLIB.H>
int8 data;
int8 wrote;
int16 addr;
int16 errors = 0;
init_ext_eeprom();
// Fill eeprom with random data.
printf("\n\r");
printf("writing");
srand(0x55);
for(addr = 0; addr < EEPROM_SIZE; addr++)
write_ext_eeprom(addr, (int8)rand());
if((int8)addr == 0)
putc('.');
// Read the eeprom and check for errors.
printf("\n\r");
printf("reading");
srand(0x55);
data = read_ext_eeprom(addr);
wrote = (int8)rand();
if(data != wrote)
printf("%lx: read %x, should be %x\n\r", addr, data, wrote);
errors++;
if(errors >= 10)
if((int8)addr == 0)
putc('.');
printf("\n\r");
printf("done\n\r");
The driver is identical to the post.
#ifndef EEPROM_SELECT
#define EEPROM_SELECT PIN_C2
#define EEPROM_CLK PIN_C3
#define EEPROM_DI PIN_C5
#define EEPROM_DO PIN_C4
#endif
#define EEPROM_ADDRESS long int
#define EEPROM_SIZE 8192
void init_ext_eeprom()
output_high(EEPROM_SELECT);
setup_spi(SPI_MASTER | SPI_MODE_0_0 | SPI_CLK_DIV_16 );
int1 ext_eeprom_ready(void)
int8 data;
output_low(EEPROM_SELECT);
spi_write(0x05);
data = spi_read(0);
return(!bit_test(data, 0));
void write_ext_eeprom(EEPROM_ADDRESS address, BYTE data)
while(!ext_eeprom_ready());
spi_write(0x06);
spi_write(0x02);
spi_write(address >> 8);
spi_write(address);
spi_write(data);
BYTE read_ext_eeprom(EEPROM_ADDRESS address)
int8 data;
spi_write(0x03);
spi_write(address);
data = spi_read(0);
return(data);
FvM
Posted: Fri Dec 31, 2010 2:03 am |
The SPI mode coding in your post is completely invalid for PIC24, they are for PIC16. Because CCS has recently fixed a bug in PIC24 mode coding, it's a bit complicated. See:
http://www.ccsinfo.com/forum/viewtopic.php?t=41421 |
pebbert9
Posted: Sat Jan 01, 2011 12:06 am |
It turns out my issue was that the EEPROM is connected to SPI2 and I was trying to initialize SPI1 with SPI2's pins.
I have the EEPROM on the Explorer 16 board working with the following code.
Test Code:
#device ICD=TRUE
#include <25LC256_SPI.c>
#include <STDLIB.H>
int8 data;
int8 wrote;
int16 addr;
int16 errors = 0;
init_ext_eeprom();
printf("\n\r");
printf("writing");
srand(0x54);
for(addr = 0; addr < 16; addr++) // Change addr < 16 to addr < EEPROM_SIZE to write to all memory locations
if((int8)addr == 0)
putc('.');
printf("\n\r");
printf("reading");
srand(0x54);
for(addr = 0; addr < 16; addr++) // Change addr < 16 to addr < EEPROM_SIZE to read from all memory locations
if(data != wrote)
errors++;
if(errors >= 10)
if((int8)addr == 0)
putc('.');
printf("\n\r");
printf("done\n\r");
Place the following driver into 25LC256_SPI.c
#define EEPROM_SIZE 32678
setup_spi2(SPI_MASTER | SPI_XMIT_L_TO_H | SPI_CLK_DIV_4 );
int8 data;
spi_write2(0x05);
data = spi_read2(0);
spi_write2(0x06);
spi_write2(0x02);
spi_write2(address >> 8);
spi_write2(address);
spi_write2(data);
int8 data;
spi_write2(0x03);
return(data);
