TINY Bootloader at a 18F2585
mkkirchner
PostPosted: Thu Dec 30, 2010 10:38 am     Reply with quote
I use TINY Bootloader and the CCS compiler and I have the following problems with a 18F2585:
If I flash my Pic with a small test program directly, every works fine.
If I use the bootloader and flash the pic with my test program by the bootloader, the delay times (delay_ms(100)) are wrong, and the variables which I print out over the RS232 are also wrong (every time 0).
The Bootloader:
   radix DEC
   LIST      P=18F2585   ; change also: Configure->SelectDevice from Mplab
xtal EQU 20000000      ; you may want to change: _XT_OSC_1H  _HS_OSC_1H  _HSPLL_OSC_1H
baud EQU 115200         ; the desired baud rate
delaytime EQU 2000000   ; for 40MHz: 1000000 gets about 1sec, for 20MHZ: 2000000 gets about 1sec
   ; The above 4 lines can be changed and buid a bootloader for the desired frequency (and PIC type)
   ;   Tiny Bootloader      18F series      Size=100words
   ;   claudiu.chiculita@ugal.ro
   ;   http://www.etc.ugal.ro/cchiculita/software/picbootloader.htm
   #include "../icdpictypes.inc"   ;takes care of: #include "p18fxxx.inc",  max_flash, IdTypePIC
   #include "../spbrgselect.inc"   ; RoundResult and baud_rate
      #define first_address max_flash-200      ;100 words
   ;can we dump these ? winpic etc have the function of configuring all
   __CONFIG _CONFIG1H, _OSC_HS_1H & _FCMEN_OFF_1H & _IESO_OFF_1H
;   __CONFIG _CONFIG2L, _PWRT_OFF_2L & _BOREN_OFF_2L
;   __CONFIG _CONFIG2H, _WDT_OFF_2H & _WDTPS_1_2H
;   __CONFIG _CONFIG3H, _MCLRE_ON_3H & _PBADEN_OFF_3H ;& _CCP2MX_PORTBE_3H not in 4680
;   __CONFIG _CONFIG4L, _DEBUG_OFF_4L & _LVP_OFF_4L & _STVREN_OFF_4L & _XINST_OFF_4L
;   __CONFIG _CONFIG5L, _CP0_OFF_5L & _CP1_OFF_5L & _CP2_OFF_5L
;   __CONFIG _CONFIG5H, _CPB_OFF_5H
;   __CONFIG _CONFIG6L, _WRT0_OFF_6L & _WRT1_OFF_6L & _WRT2_OFF_6L
;   __CONFIG _CONFIG6H, _WRTB_OFF_6H & _WRTC_OFF_6H
;   __CONFIG _CONFIG7L, _EBTR0_OFF_7L & _EBTR1_OFF_7L & _EBTR2_OFF_7L
;   __CONFIG _CONFIG7H, _EBTRB_OFF_7H & _DEVID1 & _IDLOC0
And the small test program:
     i++;
     U=4;
      output_high(PIN_C4);
      output_high(PIN_C5);
      output_low(PIN_C5);
      output_low(PIN_C4);
      printf("SS I=%lu  Xc=%c   Xd%d  Ud=%ld\r\n",i,x,x,u);
Can anybody help??
martin
PostPosted: Thu Dec 30, 2010 12:44 pm     Reply with quote
Post the complete small test program that has:
1. The #include for the PIC.
2. The #fuses.
3. The #use delay().
4. The main() function.
Post the frequency of the crystal that is connected to the PIC.
mkkirchner
PostPosted: Thu Dec 30, 2010 1:45 pm     Reply with quote
Thanks, It runs now. With the DS30 Bootloader and the same test program it was no problem.
Why it did not work with Tiny ??
martin
