12f675 code will compile but it would not run
IceMetal
PostPosted: Wed Dec 29, 2010 12:44 pm     Reply with quote
I have this simple code that I been trying to run on my pic12f675
#include <12F675.h>
#fuses INTRC_IO,NOWDT,NOPUT,NOPROTECT,NOMCLR
         OUTPUT_HIGH(PIN_A0);
         output_low(PIN_A0);
it does compile but when I burn it into the chip it would not run I though it was something wrong with the hardware, but when I put this hex file that I downloaded from online the led starts blinking
http://www.voti.nl/blink/code/b675i-1.hex
PostPosted: Wed Dec 29, 2010 1:33 pm     Reply with quote
What's your compiler version ?
Are you running this in Proteus or a real board ?
Also, what's the Vdd voltage on your PIC board ?
IceMetal
PostPosted: Wed Dec 29, 2010 4:44 pm     Reply with quote
I'm using version 4.068
this is my circuit I'm using the pickit 2
voltage is 5V
also I'm using this with MPLAB IDE v8.56
PostPosted: Wed Dec 29, 2010 6:13 pm     Reply with quote
I installed vs. 4.068 and it works in hardware. The LED is blinking.
I don't see an LED on your schematic. My LED circuit looks like this:
pin      470 ohms      LED
A0    ---/\/\/\/------->|----
                          -----  Ground
Also, make sure you compile the program for "Release" mode
and not Debug mode.
