Values on segment are unstable.
Sid2286
PostPosted: Mon Dec 27, 2010 9:16 am     Reply with quote
I'm trying to display the adc values on seven segments. I'm using mcp3208 and the file mcp3208.c.
The units place digit is flickering however the input to mcp is rock steady. I googled and made necessary changes such as decoupling cap at i/p etc. But nothing has helped so far.
Please suggest something.
gpsmikey
PostPosted: Mon Dec 27, 2010 9:35 am     Reply with quote
Without seeing the circuit and software, it is tough to really nail it down, but there are a number of factors. What does your Vref signal look like on the chip - if that is not perfectly stable, you will get wandering results. You may also want to consider adding a software filter to the results since you want to be able to view the results and are not going for a high data rate sample speed. There was recently another post here where Ttelmah showed how to implement a simple rolling average filter that did not use a lot of ram for array storage. See this post for details
http://www.ccsinfo.com/forum/viewtopic.php?t=44115
There will almost always be some variation down at the lower couple of bits - various noise sources in the system, the actual value may be right on a bit boundary etc.
mikey
mikey
