nia
dsPIC30F4012 and SPI |
Posted: Sat Dec 25, 2010 10:42 am |
Hi CCS programmer,
I have one master using PIC18F4580 and 3 slaves using dsPIC30F4012. below is my code and it is NOT working!!
apparently, if i use PIC18F13K22 as my slaves, it works just fine. some of the forumer said that, it is due to the bugs. my compiler version is 4.114. any hint @ solution?
MASTER:
Code: | #include <18F4580.h>
#use rs232(baud=38400, xmit=PIN_C6, rcv=PIN_C7)
int8 instr;
output_bit( PIN_E0, 1);
output_bit( PIN_E1, 1);
output_bit( PIN_E2, 1);
setup_spi(SPI_MASTER | SPI_L_TO_H | SPI_XMIT_L_TO_H);
while(true)
////////////////interlock switch///////////////////////
//Simulate swicth pressing
while (input(PIN_B0)); //while HIGH stay here.
while (!input(PIN_B0)); //while LOW stay here.
/////////////////////////////////////////////////// Slave 1
output_bit( PIN_E0, 0);
spi_write(0x01); //send dummy ack to slave
delay_us(25); // Give slave some time to respond (minimum 25us)
while(!spi_data_is_in());
instr = spi_read(0);
putc(instr);
//////////////////////////////////////////// Slave 2
output_bit( PIN_E1, 0);
putc(instr);
////////////////////////////////////////////// Slave 3
output_bit( PIN_E2, 0);
putc(instr);
//////////////////////////////////////////////// END
SLAVE:
Code: | #include <30F4012.h>
#fuses FRC_PLL4, NOWDT, NOPROTECT
#device ADC=8
#use delay(clock=7.37M, internal)
#byte SPIBUF1 = 0x0224 // Register address for 30F4012
unsigned int8 adc_result, command;
setup_adc( ADC_CLOCK_INTERNAL );
setup_adc_ports (sAN0);
set_adc_channel( 0 );
delay_us(100);
setup_spi(SPI_SLAVE | SPI_L_TO_H | SPI_XMIT_L_TO_H);
while(true)
command = SPIBUF1; //read dummy send by master
adc_result = Read_ADC();
SPIBUF1 = adc_result; //pass adc result to spi buffer }
Posted: Sat Dec 25, 2010 2:49 pm |
There are no obvious coding errors at first sight. Using spi_data_is_in() on the master side seems useless, but hopefully causes no problems.
I'm using SPI with PIC24, but not in slave mode. Thus I'm not aware of particular pitfalls or bugs. Generally, there's no alternative to debugging the design step-by-step. If you can be sure that the master side is working correctly, check the slave. Will the receive trigger ever be asserted? What's received? Is the slave able to transmit arbitrary constant data (there may be a problem with ADC as well)?
You'll get almost any information of interest with MPLAB and a debugging adapter, in a few cases an oscilloscope would help to verify the actual SPI waveforms. |
nia
Posted: Sun Dec 26, 2010 12:02 am |
When I change to PIC18F, it works just fine. With the same code and slight changes on the fuses, its simply not working with dsPIC.
Help needed please. |
Posted: Sun Dec 26, 2010 2:29 am |
Quote: | With the same code and slight changes on the fuses, its simply not working with dsPIC. |
Yes, I understood this from your previous post. But I don't have the dsPIC30 chip and can't check your code. You should try to find out, which step fails.
P.S.: Additionally, the ADC doesn't work correctly with the present zero TAD setting. |
