I have problem to use Interrupt RB pin4-7c in PIC16LF876
HGHK
PostPosted: Sat Dec 25, 2010 3:32 am     Reply with quote
I need use PORT B Change Interrupt (pins RB7:RB4), moreover External Interrupt (pin B0) in a PIC16LF876 to active my device from sleep.
This interrupt doesn't work carefully and when I make a pulse in pin B5 no action where down. Please help me ASAP!
My program is :TERMOCUNTERPIC16LF876.c:
#include "C:\Documents and Settings\HGhK\Desktop\CRP\temp project\TERMOCUNTERPIC16LF876.h"
#int_RB
void  RB_isr(void)
PKC++;
if((Command!=Press_Key_First)||(Command!=Press_Key_Second)||(Command!=Press_Key_Third)){Pervius_Command=Command;}
switch (PKC){
case  1: Command=Press_Key_First;PK1=1;PK2=0;PK3=0;break;
case  2: command=Press_Key_Second;PK1=0;PK2=1;PK3=0;break;
default: command=Press_Key_Third;PK1=0;PK2=0;PK3=1;PKC=0;break;
OFC=0;
set_timer0(0);
enable_interrupts(INT_TIMER0);}
#int_EXT
void  EXT_isr(void)
ExINT=1;
Command=Routine_Temperature_Sampling;
#int_TIMER0
void  TIMER0_isr(void)
OFC++;
if (OFC==0xFFFE){OFC=0x0000;}
clear_interrupt(INT_TIMER0);}
#int_RDA
void  RDA_isr(void)
RC=0;RXin=0;
RXin=getch();
if (CC){
Command=RXin;}
else if (RXin==Are_You_ready){Pervius_Command=Command;Command=Controller_Connected;CC=1;}
OFC=0;
set_timer0(0);
output_high(LED1);
output_high(LED2);
if (!Cal_A) {Cal_A = 165;}
if (!Cal_B) {Cal_B = 328;}
if (!Cal_C) {Cal_C =  20;}
if (!Cal_D) {Cal_D = -40;}
if (!Temp_Down_Limit) {Temp_Down_Limit=Temperature_Low_Limit_Defult;}
if (!Temp_Up_Limit) {Temp_Up_Limit=Temperature_Up_Limit_Defult;}
if (!Sleep_Priod_Division_Reg) {Sleep_Priod_Division_Reg=Time_Period_Defult_Division;}
   setup_adc_ports(AN0);set_adc_channel(0);
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_256);
   setup_timer_1(T1_DISABLED);
   setup_ccp1(CCP_OFF);
   setup_ccp2(CCP_OFF);
   enable_interrupts(INT_RB);
   disable_interrupts(INT_TIMER0);
   enable_interrupts(INT_RDA);
   enable_interrupts(INT_EXT);ext_int_edge(H_TO_L);
   port_b_pullups(1);
disable_interrupts(GLOBAL);
PCF8563_init();
while(1){
   switch (Command) {
    case 0x11:       // Routine Temperature Sampling
          Err=0;
          PCF8563_Clear_Alarm_Flag();
          Temperature_Exam = Temperature();
          if ((Temperature_Exam>Temp_Down_Limit)&&(Temp_Up_Limit>Temperature_Exam)) {TSC = TSC+1;}
          PCF8563_Read_SMH();
          ALARM_MINS_REG = MINUTES_REG + 60/Sleep_Priod_Division_Reg;
          if (ALARM_MINS_REG > 59) {ALARM_MINS_REG -= 60 ;};
          PCF8563_Set_Alarm();
        Reset_Command();
          clear_interrupt(INT_EXT);ExINT=0;
    case 0x12:       // Report Temperature Sampling counter
          disable_interrupts(INT_RDA);
          clear_interrupt(INT_RDA);
          Err=0;
          ReportTSC(Temperature_Exam);
          Reset_Command();
    case 0x14:       // Reset Temperature Sampling counter Set Sleep Priode
              putc(I_am_ready);
              If (kbhit()) {RXin=getch();
                            if (RXin<60) {Sleep_Priod_Division_Reg=RXin;TSC=0;}
                            Reset_Command();
    case 0x18:       // Report Temprature Limits
           Reset_Command();
    case 0x21:       // Set Temperature Limits
           Reset_Command();
    case 0x22:       // Report Temprature
           Reset_Command();
    case 0x24:       // Press_Key_First
          Err=0;
          if (OFC>2){clear_interrupt(INT_RB);}
          putLCD(Temperature_Exam,1);
          if (OFC>120){Reset_Command();putLCD(0,0);}
    case 0x28:       // Press_Key_Second
          Err=0;
          Calculation=TSC*Sleep_Priod_Division_Reg/60;
          putLCD(Calculation,1);
    case 0x41:       // Press_Key_Third
              Err=0;
              putLCD(0,0);
              PKC=0;PK1=0;
              PK2=0;PK3=0;
              Reset_Command();
    case 0x42:       // Batry_Voltage_Sampling
              Err=0;
              disable_interrupts(INT_RB);
              if (!BVS ){OFC=0;BVS=1;}
              if (OFC>8){Reset_Command();enable_interrupts(INT_RB);disable_interrupts(INT_TIMER0);}
    case 0x44:       // Calibration_Setting
           Reset_Command();
    case 0x48:       // Report_Time_And_Date
           Reset_Command();
    case 0x81:       // Set_Time_And_Date
           Reset_Command();
    case 0x82:       // Controller_Connected
            Err=0;
            if ((CC)&&(!(input_state(ES)))){Command=0x82;}
            if ((CC)&&(input_state(ES))&&(BVS )){Command=0x42;}
            if (OFC>8) { putc(Are_You_ready);
                         OFC=0;
                         delay_ms(10);
                         If (kbhit()) {RXin=getch();if (RXin == I_am_ready){CC=1;}else{CC=0;Reset_Command();}}
    case 0x84:       // Ricived_From_Controller
           Reset_Command();
    case 0x88:       // Controller_Disconnected
           Err=0;
           CC=0;
           Reset_Command();
If (Command == None_Command){
            if ((Pervius_Command)&&(!Err)) {Command=Pervius_Command;Err=1;}
            else  {
                   PCF8563_Read_SMH();
                   if ( MINUTES_REG > ALARM_MINS_REG ){
                      if (!(((ALARM_MINS_REG+60)> MINUTES_REG)&&(MINUTES_REG > (ALARM_MINS_REG + 60 - (60/Sleep_Priod_Division_Reg)))))
                      ALARM_MINS_REG = MINUTES_REG  +  ( 60 / Sleep_Priod_Division_Reg);
                      if (ALARM_MINS_REG > 59) {ALARM_MINS_REG-=60;}
                      Reset_Command();
                      clear_interrupt(INT_RTCC);
                      clear_interrupt(GLOBAL);
                      if (!Command) {sleep();}
And its header is :TERMOCUNTERPIC16LF876.h :
#include <16F876.h>
#device ICD=TRUE
#device adc=10
#FUSES XT                       //Crystal osc <= 4mhz for PCM/PCH , 3mhz to 10 mhz for PCD
#FUSES DEBUG                    //Debug mode for use with ICD
#use delay(clock=2000000)
#define SDN    PIN_A1
#define DIG1   PIN_A2
#define DATA3  PIN_A3
#define LED1   PIN_A4
#define LED2   PIN_A5
#define EINT   PIN_B0
#define DIG3   PIN_B1
#define DIG4   PIN_B2
#define DE     PIN_B3
#define ES     PIN_B5
#define PGC    PIN_B6
#define PGD    PIN_B7
#define DATA2  PIN_C0
#define DATA1  PIN_C1
#define DATA0  PIN_C2
#define DIG2   PIN_C5
#define TX     PIN_C6
#define RX     PIN_C7
#use rs232(baud=4464,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8)
#use i2c(Master,Slow,sda=PIN_C4,scl=PIN_C3,force_hw)
#define Time_Period_Defult_Division           2
#define Temperature_Up_Limit_Defult           5
#define Temperature_Low_Limit_Defult          0
// command set definition
#define None_Command                 0x00
#define Routine_Temperature_Sampling 0x11
#define Report_TSC                   0x12    // TSC : Temprature Sampling Counter
#define Reset_TSC_Set_Sleep_Priode   0x14
#define Report_Temprature_Limits     0x18
#define Set_Temperature_Limits       0x21
#define Report_Temprature            0x22
#define Press_Key_First              0x24
#define Press_Key_Second             0x28
#define Press_Key_Third              0x41
#define Batry_Voltage_Sampling       0x42
#define Calibration_Setting          0x44
#define Report_Time_And_Date         0x48
#define Set_Time_And_Date            0x81
#define Controller_Connected         0x82
#define Ricived_From_Controller      0x83
#define Controller_Disconnected      0x88
void DataEE_Read(int32 addr, int8 * ram, int bytes) {
     int i;
     for(i=0;i<=bytes;i++,ram++,addr++)
     *ram=read_eeprom(addr);
void DataEE_Write(int32 addr, int8 * ram, int bytes) {
     int i;
     write_eeprom(addr,*ram);
addressmod (eepromdata,DataEE_read,DataEE_write,0x00,0xff);          // would define a region called DataEE between 0x5 and 0xff in the chip data EEprom.
signed   int8  eepromdata Temp_Up_Limit,Temp_Down_Limit;
signed   int16 eepromdata Cal_A,Cal_B,Cal_C,Cal_D;
unsigned int8  eepromdata Sleep_Priod_Division_Reg;
unsigned int8  eepromdata EEPROM_Pervius_Command,EEPROM_Command;
unsigned int32 eepromdata TSC;
unsigned int32            Calculation;
unsigned int16            A2DC;
unsigned int8             Pervius_Command=None_Command,Command=None_Command,Condition;
unsigned int8             OFC;           // 15sec counter
unsigned int8             PKC,RC;        //press key counter , Rambler cOunter
unsigned int8             RXin,TXout;
signed   int8             Temperature_Exam,Up,Down;
    ************** CONDITION VARIABLE ***************
    |  7  |  6  |  5  |  4  |  3  |  2  |  1  |  0  |
    | Err | BVS | RXA |ExINT| PK3 | PK2 | PK1 | CC  |
#bit Err  = Condition.7
#bit BVS  = Condition.6   // Batry Voltage sampling Condition
#bit RXA  = Condition.5
#bit ExINT= Condition.4
#bit PK3  = Condition.3
#bit PK2  = Condition.2
#bit PK1  = Condition.1
#bit CC   = Condition.0   // Controller Connected
typedef struct
int8 seconds;    // 0 to 59
int8 minutes;    // 0 to 59
int8 hours;      // 0 to 23  (24-hour time)
int8 day;        // 1 to 31
int8 weekday;    // 0 = Sunday, 1 = Monday, etc.
int8 month;      // 1 to 12
int8 year;       // 00 to 99
}date_time_t;
typedef struct
}PCF8563_Alarm;
#define Are_You_ready   0x3c
#define I_am_ready      0xc3
#ifndef PCF8563_SDA
#define PCF8563_SDA  PIN_C4
#define PCF8563_SCL  PIN_C3
// #use i2c(master, sda=PCF8563_SDA, scl=PCF8563_SCL)
#ifndef PCF8563_WRITE_ADDRESS
#define PCF8563_WRITE_ADDRESS 0xA2
#define PCF8563_READ_ADDRESS  0xA3
// Register addresses
#define PCF8563_CTRL_STATUS_REG1   0x00
#define PCF8563_CTRL_STATUS_REG2   0x01
#define PCF8563_SECONDS_REG        0x02
#define PCF8563_MINUTES_REG        0x03
#define PCF8563_HOURS_REG          0x04
#define PCF8563_DAY_REG            0x05
#define PCF8563_WEEK_REG           0x06
#define PCF8563_MONTH_REG          0x07
#define PCF8563_YEAR_REG           0x08
#define PCF8563_ALARM_MINS_REG     0x09
#define PCF8563_ALARM_HOURS_REG    0x0A
#define PCF8563_ALARM_DAY_REG      0x0B
#define PCF8563_ALARM_WEEKDAY_REG  0x0C
#define PCF8563_CTRL_CLKOUT_REG    0x0D
#define PCF8563_CTRL_TIMER_REG     0x0E
#define PCF8563_TIMER_REG          0x0F
int8 CTRL_STATUS_REG1,CTRL_STATUS_REG2,LV_sec,MINUTES_REG;
int8 HOURS_REG,DAY_REG,WEEK_REG,C_Mon,YEAR_REG;
int8 CTRL_TIMER_REG,TIMER_REG,CTRL_CLKOUT_REG;
int8 ALARM_MINS_REG,ALARM_HOURS_REG;
#bit LowVoltage = LV_sec.7
#bit Century = C_Mon.7
#define  bcd_min   MINUTES_REG
#define  bcd_hrs   HOURS_REG
#define  bcd_day   DAY_REG
#define  bcd_yer   YEAR_REG
#define  wek       WEEK_REG
// Commands for the Control/Status register.
#define PCF8563_START_COUNTING     0x08
#define PCF8563_STOP_COUNTING      0x28
//*************************************  for Set_Alarm()
#define PCF8563_Alarm_off          0x00
#define PCF8563_M_Mode             0x01
#define PCF8563_MH_Mode            0x04
#define PCF8563_MHW_Mode           0x07
#define PCF8563_MHD_Mode           0x0B
//*************************************  for config_CLKOUT()
#define PCF8563_CLKOUT_off         0x00
#define PCF8563_CLKOUT_32KHz       0x80
#define PCF8563_CLKOUT_1KHz        0x81
#define PCF8563_CLKOUT_32Hz        0x82
#define PCF8563_CLKOUT_1Hz         0x83
//*************************************  for config_PCF8563_Timer()
#define PCF8563_Timer_off          0x00
#define PCF8563_Timer_4KHz         0x80
#define PCF8563_Timer_64Hz         0x81
#define PCF8563_Timer_1Hz          0x82
#define PCF8563_Timer_1_60Hz       0x83
//*************************************  for config_PCF8563_Interrupt()
#define Alarm_Interrupt_Enable     0x01
#define Timer_Interrupt_Enable     0x02
#define A_T_Interrupt_Enable       0x03
#define Timer_INT_Pulse_on         0x10
#define Timer_INT_Pulse_off        0x00
int8 bin2bcd(int8 value)
char retval = 0;
   // Get the tens digit by doing multiple subtraction
   // of 10 from the binary value.
   if(value >= 10)
      value -= 10;
      retval += 0x10;
   else // Get the ones digit by adding the remainder.
      retval += value;
return(retval);
// This function converts an 8 bit BCD value to
// an 8 bit binary value.
// The input range must be from 00 to 99.
char bcd2bin(char bcd_value)
char temp;
temp = bcd_value;
// Shifting the upper digit right by 1 is
// the same as multiplying it by 8.
temp >>= 1;
// Isolate the bits for the upper digit.
temp &= 0x78;
// Now return: (Tens * 8) + (Tens * 2) + Ones
return(temp + (temp >> 2) + (bcd_value & 0x0f));
void PCF8563_write_byte(int8 address, int8 data)
i2c_start();
i2c_write(PCF8563_WRITE_ADDRESS);
i2c_write(address);
i2c_write(data);
i2c_stop();
int8 PCF8563_read_byte(int8 address)
int8 retval;
i2c_start();
i2c_write(address);
i2c_start();
i2c_write(PCF8563_READ_ADDRESS);
retval = i2c_read(0);
i2c_stop();
return(retval);
//           PCF8563 Initial              // //
void PCF8563_init(void)
i2c_start();
i2c_write(PCF8563_CTRL_STATUS_REG1);
i2c_write(PCF8563_START_COUNTING);
i2c_write(0x02);   // CTRL_STATUS_REG2
i2c_write(1);      // SECONDS_REG
i2c_write(1);      // MINUTES_REG
i2c_write(1);      // HOURS_REG
i2c_write(1);      // DAY_REG
i2c_write(1);      // WEEK_REG
i2c_write(1);      // MONTH_REG
i2c_write(1);      // YEAR_REG
i2c_stop();
void PCF8563_Read_SMH(void)
i2c_start();
i2c_write(PCF8563_SECONDS_REG);
i2c_start();
LV_sec         =i2c_read();
MINUTES_REG    =i2c_read();
HOURS_REG      =i2c_read();
                i2c_read();
                i2c_read();
                i2c_read();
                i2c_read();
ALARM_MINS_REG =i2c_read();
ALARM_HOURS_REG=i2c_read(0);
i2c_stop();
void PCF8563_Clear_Alarm_Flag(void)
i2c_start();
i2c_write(PCF8563_CTRL_STATUS_REG2);
i2c_write(0x02);
i2c_stop();
void PCF8563_Set_Alarm(void)
i2c_start();
i2c_write(PCF8563_ALARM_MINS_REG);
i2c_write(ALARM_MINS_REG);
i2c_write(0x80);   // ALARM_HOURS_REG
i2c_write(0x80);   // ALARM_DAY_REG
i2c_write(0x80);   // MINUTES_REG
i2c_write(0x80);   // ALARM_WEEKDAY_REG
i2c_write(0x80);   // CTRL_CLKOUT_REG
i2c_write(0x00);   // CTRL_TIMER_REG
i2c_stop();
void config_PCF8563_Interrupt(int8 mode,ti_tp)
mode = mode | ti_tp;
PCF8563_write_byte(PCF8563_CTRL_STATUS_REG2, mode);
**************************** ICM7211AIPL ***********************************
int8 dig[4];
typedef struct {
   signed int quot;
   signed int rem;
} div_t;
div_t div(signed int numer, signed int denom)
   div_t val;
   val.quot = numer / denom;
   val.rem = numer - (denom * val.quot);
   return (val);
void show_Digit(int8 intercode)
     intercode = intercode & 0x0F;
       switch (intercode)
               case 0:output_low(DATA3);output_low(DATA2);output_low(DATA1);output_low(DATA0);break;       //FOR 0
               case 1:output_low(DATA3);output_low(DATA2);output_low(DATA1);output_high(DATA0);break;      //FOR 1
               case 2:output_low(DATA3);output_low(DATA2);output_high(DATA1);output_low(DATA0);break;      //FOR 2
               case 3:output_low(DATA3);output_low(DATA2);output_high(DATA1);output_high(DATA0);break;     //FOR 3
               case 4:output_low(DATA3);output_high(DATA2);output_low(DATA1);output_low(DATA0);break;      //FOR 4
               case 5:output_low(DATA3);output_high(DATA2);output_low(DATA1);output_high(DATA0);break;     //FOR 5
               case 6:output_low(DATA3);output_high(DATA2);output_high(DATA1);output_low(DATA0);break;     //FOR 6
               case 7:output_low(DATA3);output_high(DATA2);output_high(DATA1);output_high(DATA0);break;    //FOR 7
               case 8:output_high(DATA3);output_low(DATA2);output_low(DATA1);output_low(DATA0);break;      //FOR 8
               case 9:output_high(DATA3);output_low(DATA2);output_low(DATA1);output_high(DATA0);break;     //FOR 9
               case 10:output_high(DATA3);output_low(DATA2);output_high(DATA1);output_low(DATA0);break;    //FOR -
               case 11:output_high(DATA3);output_low(DATA2);output_high(DATA1);output_high(DATA0);break;   //FOR E
               default:output_high(DATA3);output_high(DATA2);output_high(DATA2);output_high(DATA0);break;  //FOR BLANK
void putLCD(signed int16 value,int8 lcd_power_switch )
if (lcd_power_switch)
     div_t numb;
     int8 mode=0x00,i;
  if (value > 9999 || value < 999 ){
                                    for (i=0;i>=3;++i) dig[1]=11;
else                              {
     for (i=0;i>=3;++i) dig[1]=12;
     if (value<0) {
                   value=value*(-1);
                   mode = 0x10;
                   dig[3] = 10;
     if (value>999){
                    numb=div(value,1000);
                          dig[3] = numb.quot;
                          value = numb.rem;
                          mode  +=  0x08 ;
     if (value>99){
                    numb=div(value,100);
                         dig[2] = numb.quot;
                         value = numb.rem;
                         mode +=  0x04 ;
     if (value>9){
                    numb=div(value,10);
                    dig[1] = numb.quot;
                    value = numb.rem;
                    mode +=  0x02 ;
     if (value > -1){
                     dig[0] = value;
                     mode += 0x01;
output_high(DE);   delay_us(2);
output_high(DIG1); delay_us(2);
show_Digit(dig[0]);delay_us(2);
output_low(DIG1);
output_high(DIG2); delay_us(2);
show_Digit(dig[1]);delay_us(2);
output_low(DIG2);
output_high(DIG3); delay_us(2);
show_Digit(dig[2]);delay_us(2);
output_low(DIG3);
output_high(DIG4); delay_us(2);
show_Digit(dig[3]);delay_us(2);
output_low(DIG4);  delay_us(2);
show_Digit(0);
if (lcd_power_switch==1) {output_high(LED2);output_high(LED2);output_low(LED1);}
if (lcd_power_switch==2) {output_high(LED1);output_high(LED1);output_low(LED2);}
else {
output_low(DIG1);
output_low(DIG2);
output_low(DIG3);
output_low(DIG4);
show_Digit(0);
output_low(DE);
output_high(LED1);
output_high(LED2);
output_high(LED2);
output_high(LED1);
signed int8 Temperature(void){
          output_high(SDN);
          delay_us(80);
          A2DC=read_adc();
          delay_us(10);
          output_low(SDN);
 Return make8((((Cal_A * ( A2DC - Cal_C))/Cal_B) + Cal_D),0);
void ReportTSC(int32 inp){
int8 i,dig[4],temp;
dig[0]= make8(inp,0);
dig[1]= make8(inp,1);
dig[2]= make8(inp,2);
dig[3]= make8(inp,3);
temp=Sleep_Priod_Division_Reg;
putc(I_am_ready);
for(i=0;i=3;i++)putc(dig[i]);
putc(temp);
void Reset_Command(void){
if (Pervius_Command){Command=Pervius_Command;Pervius_Command=0x00;
   enable_interrupts(GLOBAL);}
     if (PK1){Command=0x24;enable_interrupts(INT_RB);}
     if (PK2){Command=0x28;enable_interrupts(INT_RB);}
     if (PK3){Command=0x41;enable_interrupts(INT_RB);}
     if (CC){Command=0x82;}
     if (ExINT){Command=0x11;}
Thanks, if you help me and explain me about using PORT B Change Interrupt (pins RB7:RB4) in other simplest code and guide me about using it so it worked carefully.
My Gmail is:
HGholizadehK@Gmail.com
You can send pm for me in it
PostPosted: Sat Dec 25, 2010 2:51 pm     Reply with quote
PortB must be read inside the #int_RB routine, to clear the "Mismatch
condition". This is stated in the PIC data sheet. To do this, add the
code (shown in bold below) to your program.
// This function reads Port B without changing the TRIS.
int8 input_state_b(void)
#byte PortB = getenv("SFR:PORTB")
return(PortB);
#int_RB
void RB_isr(void)
int8 temp;
PKC++;
switch (PKC){
OFC=0;
set_timer0(0);
temp = input_state_b(); // Clear mismatch condition on Port B
#include <16F876.h>
#device ICD=TRUE
#device adc=10
Do you really have a 2 MHz crystal ? That's very unusual. Or is it
really supposed to be 20 MHz ? If so, edit the #use delay() statement
and also change the fuse from XT to HS.
Are you using the INT output pin of the pcf8563 ? If so, you need a
pull-up resistor on it. You can use 4.7K ohms.
HGHK
PostPosted: Tue Dec 28, 2010 7:08 am     Reply with quote
Dear PCM programmer
thanks
I test it, but noises make interrupt in another pin from B4-B7. I must pull-up Port B but I made my PCB and I don't know why when I use
port_b_pullups(1);
in my program the port doesn't pull up.
I used 1MHz crystal before but I don't find it in shops and I prefer 2MHz crystal for low consuming power requirements in PIC16LF876 series and I2C baud rate true setting. Also it find in shops!
If you have a better offer I very like to know.
I use PCF8563 Interrupt for wake up from sleep and I pull up it by 4.7K resistor. So I pull up Pin B5 and it connect with Push-pull bottom and noise reduction capacitor to GND.
Thanks for your help. Wink
My Gmail is:
PostPosted: Tue Dec 28, 2010 12:51 pm     Reply with quote
I must pull-up Port B but I made my PCB and I don't know why when I use:
port_b_pullups(1);
Then make a small test program and study how to use the
port_b_pullups() function.
I looked in your program for the port_b_pullups() line, which you say
you have in there. I didn't find it. But I did see this problem:
int8 i,dig[4],temp;
putc(I_am_ready);
for(i=0;i=3;i++)putc(dig[i]); putc(temp);
What does that line do ? How can "i=3" work ?
Here is a test program to test that line of code:
#include <16F877.H>
int8 i;
for(i=0;i=3;i++) putc('A');
Here is the output:
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
Your code does not work correctly.
You need to study "for loops" in the C language and learn how to make
a correct for() statement.
HGHK
PostPosted: Tue Jan 04, 2011 4:19 am     Reply with quote
I placed corrections that you offered in my program. Thanks for your attention. but in ccs c manual says that:
for
For is also used as a loop/iteration statement.
The syntax is
for (expr1;expr2;expr3)
statement
The expressions are loop control statements. expr1 is the initialization, expr2 is the termination check and expr3 is re-initialization. Any of them can be omitted.
Example:
for (i=1;i<=10;++i)
printf("%u\r\n",i);
I think termination check means that when I come to expr2 this loop is end of screwing and when this loop were end next line go runs.
pleas help me that what of these:
for(i=0;i<=3;i++)putc(dig[i]);
or
for(i=0;i>3;i++)putc(dig[i]);
is ok?
My Gmail is:
PostPosted: Tue Jan 04, 2011 1:22 pm     Reply with quote
Make a test program. Test it with each of those lines of code.
Then you can see what each line does.
You can test it with the MPLAB simulator:
See this post for instructions on how to use the "UART1" feature of the
MPLAB simulator to display serial output in the MPLAB Output Window:
http://www.ccsinfo.com/forum/viewtopic.php?t=23408&start=1
