update period of the POWER PWM in PIC18F4431
gianhenrique
View user's profile Send private message Send e-mail MSN Messenger
PostPosted: Mon Dec 20, 2010 4:28 pm     Reply with quote
hey guys
I'm from Brazil and I'm desperate because I can not update the values of the period (PTPER) quickly, this function requires a time of 10ms, which impairs my motor ..
how I set this function correctly PWM POWER, and how do I update the value of frequency (period) without delay by one? Question
please help me!
tnk's
PostPosted: Mon Dec 20, 2010 4:59 pm     Reply with quote
I can not update the values of the period (PTPER) quickly, this function requires a time of 10ms.
Post a test program which shows that it takes 10ms to update PTPER.
Example of test program:
http://www.ccsinfo.com/forum/viewtopic.php?t=37206&start=2
gianhenrique
PostPosted: Mon Dec 20, 2010 5:11 pm     Reply with quote
void front_d()
enable_interrupts(int_pwmtb);
do{
setup_power_pwm(PWM_CLOCK_DIV_16 | PWM_FREE_RUN | PWM_DEAD_CLOCK_DIV_4, 1, 0, freq, 0, 0, 0);
output_high(pin_b0);
set_power_pwm0_duty(PWM_UPDATE_ENABLE|duty);
set_power_pwm2_duty(PWM_UPDATE_disable);
delay_ms(10); //the problem is that delay
}while(input_d()==0b00000100);
do{
delay_ms(10); // and that
}while(freq<4095);
the treatment interruption is below ... noting that the code is not all here...
#INT_PWMTB
void trata_pwm()
   if(prog==1){
      if(pulso1==255){
             pulso2++;
             pulso1=0;
           else pulso1++;
      if(ace==1){
   if((freq==4095) | (freq>2047)){
      freq=freq-4;
      duty=duty-8;
      if((freq==2047) | (freq>1023)){
      freq=freq-2;
      duty=duty-4;
      if((freq==1023)|(freq>800)){
      freq=freq-1;
      duty=duty-2;
      if((freq==800)|(freq>750)){
      if(exp4==4){
      exp4=0;
      freq=freq-1;
      duty=duty-2;
      if(exp4<4)exp4=exp4+1;
      if((freq==750)|(freq>700)){
      if(exp8==8){
      exp8=0;
      freq=freq-1;
      duty=duty-2;
      if(exp8<8)exp8=exp8+1;
      if((freq==700)|(freq>620)){
      if(exp16==8){
      exp16=0;
      freq=freq-1;
      duty=duty-2;
      if(exp16<16)exp16=exp16+1;
      if((freq==620)){
      freq=620;
      duty=1240;
   if(des==1){
   if((freq==650)|(freq<2698)){
      freq=freq+1;
      duty=duty+2;
   if((freq==2698)|(freq<3722)){
      freq=freq+2;
      duty=duty+4;
   if((freq==3722)|(freq<3946)){
      freq=freq+1;
      duty=duty+2;
   if((freq==3946)|(freq<3996)){
      freq=freq+1;
      duty=duty+2;
   if((freq==3996)|(freq<4046)){
      freq=freq+1;
      duty=duty+2;
   if((freq==4046)|(freq<4095)){
      freq=freq+1;
      duty=duty+2;
which always changes how can you realize, is that the variable FREQ is
time ...
I'm developing is an acceleration to a robot that needs
acceleration so as not to slip and therefore not lose the precision!
tnks
PostPosted: Tue Dec 21, 2010 1:06 pm     Reply with quote
You didn't give me a short test program that I can run on my PicDem2-
Plus board. If you do that, and post your compiler version, then I can
look at the problem in hardware.
Again, here is an example of a complete (but short) test program:
gianhenrique
PostPosted: Tue Dec 21, 2010 1:34 pm     Reply with quote
eu vou postar o codigo inteiro entao, para que vc possa dar uma olhada...
o fato é que eu só queria arranjar uma forma de atualizar a frequencia sem ter que configurar a função do Power_PWM denovo...
mas, muito obrigado pela ajuda que vc esta me dando PCM
PS: the comments are in Brazilian Portuguese excuse the flaws in English also
Abaixo se encontra o codigo:
#include <18f4431.h>
#fuses NOLVP, HS, NOWDT, NOPROTECT, PUT, BROWNOUT,BORV27,NOMCLR, NOFCMEN
//PAGINA 67 DO DATASHEET ENDEREÇO DOS REGISTRADORES
#BYTE pwmcon0=0XF6F      //Registrador de PWMCON0, define quais os pinos de pwm irao operar
#priority PWMTB
/****************   VARIÁVEIS DE CONTROLE   ***********************************/
int1   ace=0;         //FLAG QUE SINALIZA ACELERAÇÃO NA FUNÇÃO DE MOVIMENTOS
int1   des=0;         //FLAG QUE SINALIZA DESACELERAÇÃO NA FUNÇÃO DE MOVIMENTOS
int1   prot=0;         //FLAG QUE IMPEDE DE GRAVAR NO PROTOCOLO OUTRO MOVIMENTO SEM ENCERRAR O QUE FOI FEITO ANTES
int1   REC=0;         //QUANDO REC FOR ZERO, ELE FARA COM QUE SOMENTE SOME OU SUBTRAIA O MOVIMENTO, IMPEDINDO DE FAZER MOVIMENTOS SEM DECIDIR O QUE IRÁ FAZER
int1   play=0;         //FLAG QUE FAZ O RUN TER INICIO, SE ESSE FLAG FOR ZERO, NAO EXECUTARÁ NADA
int1   prog;         //FLAG PRA SABER SE É MODO DE PROGRAMAÇÃO DO CHIP
int1   run;            //FLAG PRA SABER SE É MODO DE EXECUÇÃO DO CHIP
int8   exp4=0;        //VARIÁVEL RESPONSÁVEL PELA ACELERAÇÃO, POR EXEMPLO, QUANDO ESSA VARIAVEL FOR 4, DECREMENTARA 1 EM FREQ, FAZENDO-O ACELERAR
int8   exp8=0;        //MESMA FUNÇÃO DE EXP4 MAS, CONTA ATÉ 8 PULSOS
int8   exp16=0;        //MESMA FUNÇÃO de EXP4 E EXP8, MAS CONTA ATÉ 16
int8   pulso1=0;      //VARIÁVEL DE 8 BITS PARA CONTAR PULSOS DO PWM (PARTE BAIXA LSB)
int8   pulso2=0;      //VARIAVEL DE 8 BITS PARA CONTAR PULSOS DO PWM (PARTE ALTA MSB)
int8   local=0;         //VARIAVEL RESPONSÁVEL PELO ENDEREÇO DE GRAVAÇÃO NA MEMORIA(SEMPRE INCREMENTADA)
int8   protocolo=0;    //VARIAVEL DE PROTOCOLO QUE DIZ AO CHIP NO MODO RUN, O QUE FAZER
int8   Res_pulso1=0;      //VARIÁVEL RESPONSAVEL PELA METADE DE C_PULSOS
int8   Res_pulso2=0;      // VARIÁVEL RESPONSÁVEL PELA OUTRA METADE DE C_PULSOS
int16  pulso=0;         //RESULTADO DA ARITMÉTICA PARA SABER A QUANTIDADE REAL DE PULSOS
int16  C_pulso=0;      // Cópia do valor de pulsos do movimento, para aceleração modo RUN
int16  deb=400;         //DEBUNSEN
int16  Freq_P=4095;      //VARIÁVEL RESPONSÁVEL PELA FREQUENCIA DESTINADA AOS MOTORES
int16  duty_P=8190;      //VARIÁVEL RESPONSÁVEL PELO DUTY CYCLE DO PWM DESTINADO AOS MOTORES, O VALOR DE DUTY TEM SEMPRE QUE SER O DOBRO DA FREQ
int16  Freq_R=3000;      // VARIÁVEL RESPONSÁVEL PELA FREQUENCIA DESTINADA AOS MOTORES NO MODO RUN
int16  duty_R=6000;      // VARIÁVEL RESPONSÁVEL PELO DUTY DO PWM DESTINADO AOS MOTORES EM MODO RUN
int16  y=0;            //ARMAZENA AS DUAS PARTES DE PULSOS TEMPORARIAMENTE, ATÉ SER SOMADO, E PREPARADO PARA GRAVAR O MOVIMENTO, ARMAZENA A PARTE ALTA E BAIXA DE PULSO, PARA SE TORNAR PULSO DENOVO DEPOIS DE GRAVADO
/**************      TRATAMENTO DE INTERRUPÇÕES      **************************/
#INT_PWMTB
void trata_pwm()
   if(prog==1){
      if(pulso1==255){
             pulso2++;
             pulso1=0;
           else pulso1++;
      if(ace==1){
      if((Freq_P==4095) | (Freq_P>2047)){
      Freq_P=Freq_P-16;
      duty_P=duty_P-32;
      if((Freq_P==2047) | (Freq_P>1023)){
      Freq_P=Freq_P-2;
      duty_P=duty_P-4;
      if((Freq_P==1023)|(Freq_P>800)){
      Freq_P=Freq_P-2;
      duty_P=duty_P-4;
      if((Freq_P==800)|(Freq_P>750)){
      if(exp4==4){
      exp4=0;
      Freq_P=Freq_P-1;
      duty_P=duty_P-2;
      if((Freq_P==750)|(Freq_P>700)){
      if(exp8==8){
      exp8=0;
      Freq_P=Freq_P-1;
      duty_P=duty_P-2;
      if((Freq_P==700)|(Freq_P>620)){
      if(exp16==8){
      exp16=0;
      Freq_P=Freq_P-1;
      duty_P=duty_P-2;
   if(des==1){
   if((Freq_P==750)|(Freq_P<3722)){
      Freq_P=Freq_P+2;
      duty_P=duty_P+4;
   if((Freq_P==3722)|(Freq_P<3946)){
      Freq_P=Freq_P+4;
      duty_P=duty_P+8;
   if((Freq_P==3946)|(Freq_P<3996)){
      Freq_P=Freq_P+4;
      duty_P=duty_P+8;
   if((Freq_P==3996)|(Freq_P<4095)){
      Freq_P=Freq_P+4;
      duty_P=duty_P+8;
/*   if((Freq_P==750)|(Freq_P<2698)){
      Freq_P=Freq_P+1;
      duty_P=duty_P+2;
   if((Freq_P==2698)|(Freq_P<3722)){
      Freq_P=Freq_P+2;
      duty_P=duty_P+4;
      Freq_P=Freq_P+1;
      duty_P=duty_P+2;
      Freq_P=Freq_P+1;
      duty_P=duty_P+2;
   if((Freq_P==3996)|(Freq_P<4046)){
      Freq_P=Freq_P+1;
      duty_P=duty_P+2;
   if((Freq_P==4046)|(Freq_P<4095)){
      Freq_P=Freq_P+1;
      duty_P=duty_P+2;
  if(run==1){
    if(ace==1){
      if((Freq_R==4095) | (Freq_R>2047)){
      Freq_R=Freq_R-16;
      duty_R=duty_R-32;
      if((Freq_R==2047) | (Freq_R>1023)){
      Freq_R=Freq_R-2;
      duty_R=duty_R-4;
      Freq_R=Freq_R-2;
      duty_R=duty_R-4;
      if((Freq_R==800)|(Freq_R>750)){
      if(exp4==4){
      exp4=0;
      Freq_R=Freq_R-1;
      duty_R=duty_R-2;
      if(Freq_R<=750){
         freq_R=750;
         duty_R=1500;
      if(exp8==8){
      exp8=0;
      Freq_P=Freq_P-1;
      duty_P=duty_P-2;
      if(exp16==8){
      exp16=0;
      Freq_P=Freq_P-1;
      duty_P=duty_P-2;
   if(des==1){
   if((Freq_R==750)|(Freq_R<1000)){
      Freq_R=Freq_R+2;
      duty_R=duty_R+4;
   if((Freq_R==1250)|(Freq_R<1500)){
      Freq_R=Freq_R+4;
      duty_R=duty_R+8;
   if((Freq_R==1500)|(Freq_R<2000)){
      Freq_R=Freq_R+4;
      duty_R=duty_R+8;
   if((Freq_R==2000)|(Freq_R<3000)){
      Freq_R=Freq_P+4;
      duty_R=duty_P+8;
   if(Freq_R==3000){
     Freq_R=3000;
     duty_R=3000;
/*   if((Freq_R==750)|(Freq_R<2698)){
      Freq_R=Freq_R+1;
      duty_R=duty_R+2;
   if((Freq_R==2698)|(Freq_R<3722)){
      Freq_R=Freq_R+2;
      duty_R=duty_R+4;
   if((Freq_R==3722)|(Freq_R<3946)){
      Freq_R=Freq_R+1;
      duty_R=duty_R+2;
   if((Freq_R==3946)|(Freq_R<3996)){
      Freq_R=Freq_R+1;
      duty_R=duty_R+2;
   if((Freq_R==3996)|(Freq_R<4046)){
      Freq_R=Freq_R+1;
      duty_R=duty_R+2;
   if((Freq_R==4046)|(Freq_R<4095)){
      Freq_R=Freq_R+1;
      duty_R=duty_R+2;
   if(res_pulso1!=0){
      res_pulso1--;
   if(res_pulso1==0){
      res_pulso2--;
   CLEAR_INTERRUPT(INT_PWMTB);
#INT_TIMER0
void trata_t0()
   output_toggle(pin_c3);
   SET_TIMER0(15535);
   CLEAR_INTERRUPT(INT_TIMER0);
/*******************   PROTOTIPOS DE ROTINAS   ********************************/
void FRENTE_D(void);          // Roda da DIREITA para Frente
void FRENTE_E(void);          // Roda da ESQUERDA para Frente
void TRAS_D(void);            // Roda da Direita para Tras
void TRAS_E(void);            // Roda da Esquerda para Tras
void FRENTE(void);            // As duas rodas para Frente
void TRAS(void);              // As duas rodas para Tras
void EE(void);                // Girar no proprio Eixo (Esquerda)
void ED(void);                // Girar no proprio Eixo (Direita)
void PARA(void);              // Desliga os 2 pinos de PWM
void F_run(void);             // FRENTE no modo run
void T_run(void);           // TRAS no modo run
void EE_run(void);           // Eixo esquerdo no modo run
void ED_run(void);           // Eixo Direito no modo run
void TD_run(void);           // Tras direita no modo run
void te_run(void);           // Tras esquerda no modo run
void fd_run(void);            // Frente Direita no modo run
void fe_run(void);           // Frente Esquerda no modo Run
void PISCA(void);            // Rotina para sinalizar gravação, soma,subtração
void decide(void);           // Rotina para decidir se vai somar ou subtrair movimento
void grava(void);           // Rotina para gravar movimento
void fim(void);              // coloca Chip em modo Sleep
/*****************      MAIN   ************************************************/
void main(){
   SETUP_TIMER_0(RTCC_INTERNAL|RTCC_DIV_64);
    SET_TIMER0(15535);
   protocolo=0; local=0; pulso1=0; pulso2=0; pulso=0; y=0;
   if(input(pin_e2)==1){
         prog=1;
         run=0;}
         else{
         prog=0;
         run=1;}
/*****************     PROG    ************************************************/
    while(prog==1 && run==0)
     pwmcon0 = 0b01101111;
      switch(input_d())
         case 0b00000001:{
         delay_ms(deb);
         if(input_d()==0b00000001)frente_e();
         case 0b00001000:{
         delay_ms(deb);
         if(input_d()==0b00001000)tras_e();
         case 0b00000100:{
         delay_ms(deb);
         if(input_d()==0b00000100)frente_d();
         case 0b00000010:{
         delay_ms(deb);
         if(input_d()==0b00000010)tras_d();
         case 0b00001010:{
         delay_ms(deb);
         if(input_d()==0b00001010)tras();
         case 0b00000101:{
         delay_ms(deb);
         if(input_d()==0b00000101)frente();
         case 0b00000011:{
         delay_ms(deb);
         if(input_d()==0b00000011)ee();
         case 0b00001100:{
         delay_ms(deb);
         if(input_d()==0b00001100)ed();
       case 0b00010000:{
         if(input_d()==0b00010000)fim();
         else grava();
         default:para();
/*****************      RUN    ************************************************/
 while(run==1 && prog==0)
     //setup_power_pwm(PWM_CLOCK_DIV_4 | PWM_FREE_RUN | PWM_DEAD_CLOCK_DIV_4, 1, 0, Freq_P, 0, 0, 0);
    Enable_interrupts(INT_TIMER0);
      if(input(pin_a0)==1 && play==0)play=1;
      if(play==1){
      protocolo=0; pulso1=0; pulso2=0; pulso=0;
      protocolo=read_eeprom(local);
      local++;
      pulso1=read_eeprom(local);
      local++;
      pulso2=read_eeprom(local);
      local++;
      pulso=((pulso2*256)+pulso1);
      pisca();
     c_pulso=pulso;
     res_pulso1=c_pulso/2;
     res_pulso2%=c_pulso/2;
      switch(protocolo){
         case 0b00111101:F_run();   break;
         case 0b00001101:T_run();   break;
         case 0b00010101:EE_run();  break;
         case 0b00100101:ED_run();  break;
         case 0b00001001:TD_run();  break;
         case 0b00000001:Te_run();  break;
         case 0b00111001:fd_run();  break;
         case 0b00110001:fe_run();  break;
         case 0b11111111:fim();     break;
/***************   ROTINAS DE MOVIMENTOS E CONTROLE    **********************/
void frente_d()
   do{
      ace=1;
      setup_power_pwm(PWM_CLOCK_DIV_16 | PWM_FREE_RUN | PWM_DEAD_CLOCK_DIV_4, 1, 0, Freq_P, 0, 0, 0);
      set_power_pwm0_duty(PWM_UPDATE_ENABLE|duty_P);
      delay_ms(6);
   do{
      ace=0;
      des=1;
      delay_ms(6);
   while(Freq_P<4095);
     para();
     if (prot==0){
     protocolo=0b00111001;
     prot=1;
     REC=1;
     decide();
void tras_d()
   do{
      ace=1;
      output_low(pin_b0);
      delay_ms(6);
    while(input_d()==0b00000010);
   do{
      ace=0;
      des=1;
      output_low(pin_b0);
      delay_ms(6);
   while(Freq_P<4095);
      para();
     if (prot==0){
     protocolo=0b00001001;
     prot=1;
     REC=1;
      decide();
void frente_e()
   do{
      ace=1;
      output_low(pin_b2);
      set_power_pwm2_duty(PWM_UPDATE_ENABLE|duty_P);
      set_power_pwm0_duty(PWM_UPDATE_disable);
      delay_ms(6);
       while(input_d()==0b00000001);
   do{
      ace=0;
      des=1;
      output_low(pin_b2);
      delay_ms(6);
   while(Freq_P<4095);
      para();
     if (prot==0){
     protocolo=0b00110001;
     prot=1;
     REC=1;
     decide();
void tras_e()
   do{
      ace=1;
      output_high(pin_b2);
      delay_ms(6);
       while(input_d()==0b00001000);
   do{
      ace=0;
      des=1;
      delay_ms(6);
   while(Freq_P<4095);
      para();
     if (prot==0){
     protocolo=0b00000001;
     prot=1;
     REC=1;
     decide();
void tras()
   do{
      ace=1;
      output_low(pin_b0);
      delay_ms(6);
   while(input_d()==0b00001010);
   do{
      ace=0;
      des=1;
      setup_power_pwm(PWM_CLOCK_DIV_16| PWM_FREE_RUN | PWM_DEAD_CLOCK_DIV_4, 1, 0, Freq_P, 0, 0, 0);
      output_low(pin_b0);
      delay_ms(6);
   while(Freq_P<4095);
      para();
     if (prot==0){
     protocolo=0b00001101;
     prot=1;
     REC=1;
      decide();
void frente()
   do{
      ace=1;
      output_low(pin_b2);
      delay_ms(6);
   while(input_d()==0b00000101);
   do{
      ace=0;
      des=1;
      output_low(pin_b2);
      delay_ms(6);
   while(Freq_P<4095);
      para();
     if (prot==0){
     protocolo=0b00111101;
     prot=1;
     REC=1;
      decide();
void ee()
   do{
      ace=1;
      output_low(pin_b0);
      output_low(pin_b2);
      delay_ms(6);
   while(input_d()==0b00000011);
   do{
      ace=0;
      des=1;
      output_low(pin_b0);
      output_low(pin_b2);
      delay_ms(6);
   while(Freq_P<4095);
      para();
     if (prot==0){
     protocolo=0b00010101;
     prot=1;
     REC=1;
      decide();
void ed()
   do{
      ace=1;
      delay_ms(6);
   while(input_d()==0b00001100);
   do{
      ace=0;
      des=1;
      delay_ms(6);
   while(Freq_P<4095);
      para();
     if (prot==0){
     protocolo=0b00100101;
     prot=1;
     REC=1;
      decide();
/*****************      ROTINAS RUN      **************************************/
void F_run()
   do{
      ace=1;
      setup_power_pwm(PWM_CLOCK_DIV_16 | PWM_FREE_RUN | PWM_DEAD_CLOCK_DIV_4, 1, 0, Freq_R, 0, 0, 0);
      output_low(pin_b2);
      set_power_pwm0_duty(PWM_UPDATE_ENABLE|duty_R);
      set_power_pwm2_duty(PWM_UPDATE_ENABLE|duty_R);
      delay_ms(6);
   while(res_pulso1!=0);
   do{
      ace=0;
      des=1;
      output_low(pin_b2);
      delay_ms(6);
   while(res_pulso2!=0);
      para();
void T_run()
   output_low(pin_b0);
   while(pulso!=0);
   para();
void EE_run()
    output_low(pin_b0);
    output_low(pin_b2);
   while(pulso!=0);
   para();
void ED_run()
   while(pulso!=0);
   para();
void TD_run()
    output_low(pin_b0);
   while(pulso!=0);
   para();
void te_run()
   while(pulso!=0);
   para();
void fd_run()
{   enable_interrupts(int_pwmtb);
   while(pulso!=0);
   para();
void fe_run()
    output_low(pin_b2);
   while(pulso!=0);
   para();
/*************************    ROTINAS DE CONTROLE DE MOVIMENTOS   *****************/
void para()
   ace=0;
   des=0;
   set_power_pwm0_duty(PWM_UPDATE_DISABLE);
   set_power_pwm2_duty(PWM_UPDATE_DISABLE);
   disable_interrupts(int_pwmtb);
   if(prog==1){
     Freq_P=4095;
        duty_P=8190;
   if(run==1){
     Freq_P=3000;
        duty_P=6000;
void pisca()
   output_high(pin_e1);
    output_low(pin_e1);
void fim()
   disable_interrupts(INT_TIMER0);
   write_eeprom(local,0b11111111);
   output_high(pin_c3);
   delay_ms(2000);
   output_low(pin_c3);
   sleep();
   sleep();
void grava(){
      pulso1=make8(y,0);
      pulso2=make8(y,1);
      write_eeprom(local,protocolo);
      local++;
      write_eeprom(local,pulso1);
      local++;
      write_eeprom(local,pulso2);
      local++;
      pulso1=0; pulso2=0; protocolo=0; y=0; prot=0; REC=0;
      pisca();
      pisca();
      pisca();
void decide()
   while(REC==1){
       if(input_d()==0b10000000)delay_ms(20);      //SOMA
       if(input_d()==0b10000000){
         while(input_d()==0b10000000);
               y=y+((pulso2*256)+pulso1);
               pulso1=0; pulso2=0; REC=0;
               pisca();
       if(input_d()==0b00100000)delay_ms(20);         //SUBTRAI
       if(input_d()==0b00100000){
         while(input_d()==0b00100000);
            y=y-((pulso2*256)+pulso1);
            pisca();
            pisca();
PostPosted: Tue Dec 21, 2010 1:37 pm     Reply with quote
That is not a short test program. Try to remove a large amount of the
code, but still have a program that demonstrates the problem.
If it's a short program (that compiles OK), I have a better chance to
quickly find the problem.
gianhenrique
PostPosted: Tue Dec 21, 2010 1:54 pm     Reply with quote
sorry
I'll put part of the program that works too.
I believe that works right ...
#priority PWMTB
int1   prog=0;
int8   exp4=0;
#INT_PWMTB
void trata_pwm()
      if(ace==1){
      Freq_P=Freq_P-16;
      duty_P=duty_P-32;
      Freq_P=Freq_P-2;
      duty_P=duty_P-4;
      Freq_P=Freq_P-2;
      duty_P=duty_P-4;
      if(exp4==4){
      exp4=0;
      Freq_P=Freq_P-1;
      duty_P=duty_P-2;
   if(des==1){
      Freq_P=Freq_P+2;
      duty_P=duty_P+4;
      Freq_P=Freq_P+4;
      duty_P=duty_P+8;
      Freq_P=Freq_P+4;
      duty_P=duty_P+8;
      Freq_P=Freq_P+4;
      duty_P=duty_P+8;
#INT_TIMER0
void trata_t0()
   SET_TIMER0(15535);
void main(){
    SET_TIMER0(15535);
   prog=1;
    while(prog==1)
      switch(input_d())
         case 0b00000100:{
         delay_ms(deb);
         default: para();
void frente_d()
   do{
      ace=1;
      setup_power_pwm(PWM_CLOCK_DIV_16 | PWM_FREE_RUN | PWM_DEAD_CLOCK_DIV_4, 1, 0, Freq_P, 0, 1, 0);
      delay_ms(6);
   do{
      ace=0;
      des=1;
      delay_ms(6);
   while(Freq_P<4095);
     para();
void para()
   ace=0;
   des=0;
   if(prog==1){
     Freq_P=4095;
        duty_P=8190;
PostPosted: Tue Dec 21, 2010 5:00 pm     Reply with quote
 if(ace==1){
      Freq_P=Freq_P-16;
      duty_P=duty_P-32;
      Freq_P=Freq_P-2;
      duty_P=duty_P-4;
      Freq_P=Freq_P-2;
      duty_P=duty_P-4;
      if(exp4==4){
      exp4=0;
      Freq_P=Freq_P-1;
      duty_P=duty_P-2;
I don't understand your logic in this code. Suppose 'Freq_P' is 2048.
Then all of the if() statements will be executed. Is that what
you want it to do ?
What is the purpose of your code above ? Do you want to detect
one specific range of Freq_P, and then subtract a number from Freq_P ?
Also, it's not normal programming to use the bitwise OR operator '|'
in a logical statement. The logical OR operator '||' should be used.
However, I'm not sure what you want to do. I suspect that you want
to detect several ranges. If that's true, the following code would work
better:
if(ace==1){
      if((Freq_P <= 4095) && (Freq_P > 2047)){   // Range:  2048 to 4095
      Freq_P=Freq_P-16;
      duty_P=duty_P-32;
    if((Freq_P <= 2047) && (Freq_P > 1023)){    // Range:  1024 to 2047
      Freq_P=Freq_P-2;
      duty_P=duty_P-4;
      if((Freq_P <= 1023) && (Freq_P > 800)){   // Range:  801 to 1023
      Freq_P=Freq_P-2;
      duty_P=duty_P-4;
      if((Freq_P <= 800) && (Freq_P > 750)){   // Range: 751 to 800
      if(exp4==4){
      exp4=0;
      Freq_P=Freq_P-1;
      duty_P=duty_P-2;
The code above could be made much more simple by using "else if"
statements. For example, here's a test program that you can run
in MPLAB simulator, using "else if" statements:
#include <18F452.h>
#fuses HS,NOWDT,PUT,BROWNOUT,NOLVP
#use delay(clock = 20000000)
int16 Freq_P;
for(Freq_P = 600; Freq_P < 4100; Freq_P += 100)
if(Freq_P > 2047)
   printf("Freq_P=%lu, range = 2048 to 4095 \r", Freq_P);
else if(Freq_P > 1023)
   printf("Freq_P=%lu, range = 1024 to 2047  \r", Freq_P);
else if(Freq_P > 800)
   printf("Freq_P=%lu, range = 801 to 1023  \r", Freq_P);
else if(Freq_P > 750)
   printf("Freq_P=%lu, range = 751 to 800  \r", Freq_P);
Here's the output of the program above. You can study how the program
works by running it in MPLAB simulator:
Freq_P=800, range = 751 to 800
Freq_P=900, range = 801 to 1023
Freq_P=1000, range = 801 to 1023
Freq_P=1100, range = 1024 to 2047
Freq_P=1200, range = 1024 to 2047
Freq_P=1300, range = 1024 to 2047
Freq_P=1400, range = 1024 to 2047
Freq_P=1500, range = 1024 to 2047
Freq_P=1600, range = 1024 to 2047
Freq_P=1700, range = 1024 to 2047
Freq_P=1800, range = 1024 to 2047
Freq_P=1900, range = 1024 to 2047
Freq_P=2000, range = 1024 to 2047
Freq_P=2100, range = 2048 to 4095
Freq_P=2200, range = 2048 to 4095
Freq_P=2300, range = 2048 to 4095
Freq_P=2400, range = 2048 to 4095
Freq_P=2500, range = 2048 to 4095
Freq_P=2600, range = 2048 to 4095
Freq_P=2700, range = 2048 to 4095
Freq_P=2800, range = 2048 to 4095
Freq_P=2900, range = 2048 to 4095
Freq_P=3000, range = 2048 to 4095
Freq_P=3100, range = 2048 to 4095
Freq_P=3200, range = 2048 to 4095
Freq_P=3300, range = 2048 to 4095
Freq_P=3400, range = 2048 to 4095
Freq_P=3500, range = 2048 to 4095
Freq_P=3600, range = 2048 to 4095
Freq_P=3700, range = 2048 to 4095
Freq_P=3800, range = 2048 to 4095
Freq_P=3900, range = 2048 to 4095
Last edited by PCM programmer on Tue Dec 21, 2010 5:15 pm; edited 2 times in total
gianhenrique
PostPosted: Tue Dec 21, 2010 5:19 pm     Reply with quote
sorry again!
I do this part of the code, is to compare the value of this one OR the other ...
there was a mistake, because the code is not posted an updated code ...
I've moved this logic to the bitwise logical OR comparison '| |'
not understand what the 'range' is ...
is a function of the ccs?
PostPosted: Tue Dec 21, 2010 5:42 pm     Reply with quote
'Range' is a programming concept. A "range" of numbers:
A range between a lower number and a higher number.
I don't really know what you want to do. I'm not sure if
I want to work on this problem any more.
gianhenrique
PostPosted: Tue Dec 21, 2010 5:47 pm     Reply with quote
What I want is to change the period of the pwm.
Just tell me if you like me to update the frequency PWM mode by another without use the function setup_power_pwm ()...
How to update only the value of the frequency without having to upgrade all the time other settings
have?
PostPosted: Wed Dec 22, 2010 2:20 pm     Reply with quote
I made a test program that smoothly changes the PWM frequency from
1 KHz to 2 KHz, and back down to 1 KHz again, continuously. You can
see the waveform on Pin B1 with your oscilloscope.
#include<18F4431.h>
#fuses INTRC_IO, NOWDT, NOPROTECT, NOBROWNOUT, PUT, NOLVP
#use delay(clock=8000000)
#define MAX_PWM_PERIOD 1999  // 1 KHz pwm freq with 8 MHz osc.
#define MIN_PWM_PERIOD 1000
#byte PTPERL = getenv("SFR:PTPERL")
#byte PTPERH = getenv("SFR:PTPERH")
#INT_PWMTB
void pwmtb_isr(void)
static int16 period = MAX_PWM_PERIOD;
static int8 period_increasing = FALSE;
// Ramp the PWM period down and up, continuously.
if(period_increasing)
   if(period < MAX_PWM_PERIOD)
      period++;
else  // period is decreasing
   if(period > MIN_PWM_PERIOD)
      period--;
      period_increasing = TRUE;
// Set period in hardware register to new value.
PTPERL = make8(period, 0);
PTPERH = make8(period, 1);
// Setup the 4 Power PWM channels as ordinary pwm channels.
setup_power_pwm_pins(PWM_ODD_ON, PWM_ODD_ON, PWM_ODD_ON, PWM_ODD_ON);
// Mode = Free Run
// Postscale = 1   (1-16) Timebase output postscaler
// TimeBase = 0   (0-65355) Initial value of PWM Timebase
// Period = 2000  (0-4095) Max value of PWM TimeBase
// Compare = 0     (Timebase value for special event trigger)
// Compare Postscale = 1 (Postscaler for Compare value)
// Dead Time
setup_power_pwm(PWM_FREE_RUN, 1, 0, MAX_PWM_PERIOD, 0, 1,0);
set_power_pwm0_duty((int16)((MAX_PWM_PERIOD *4) * .1)); // 10%
clear_interrupt(INT_PWMTB);
enable_interrupts(INT_PWMTB);
gianhenrique
PostPosted: Mon Jan 03, 2011 5:09 am     Reply with quote
PCM programmer Thanks for the help, your help was amazing utility!
Sorry for any faux pas I made.
Graciously
Gian Correa
Very Happy
