store a character in eeprom
dynamitron
PostPosted: Mon Dec 20, 2010 10:45 am     Reply with quote
Could someone explain me why if I try to store a character in eeprom, I must use the following instruction:
write_eeprom(816,78);
If I try this one, I am not getting the correct character when I read it back:
write_eeprom(816,'n');
Thanks for the help,
D.
PostPosted: Mon Dec 20, 2010 10:59 am     Reply with quote
Remember that 78, is the character code for 'N', not 'n'. For 'n', you would get back 110.
gpsmikey
PostPosted: Mon Dec 20, 2010 11:03 am     Reply with quote
What are you getting back when you try to read it ? (as Ttelmah indicates, a lower case 'n' is 110 decimal (or 0x6E hex)).
mikey
mikey
dynamitron
PostPosted: Mon Dec 20, 2010 11:55 am     Reply with quote
For N, I get 'B'
I am just curious because otherwise using the ascii code, it works fine
PostPosted: Mon Dec 20, 2010 12:09 pm     Reply with quote
Post a simple test program that shows the problem. Example:
http://www.ccsinfo.com/forum/viewtopic.php?t=17590&start=1
It should be complete and compile without errors, similar to the
program shown in the link above.
Also post your compiler version.
Also, tell us if you have ever programmed that eeprom location with
a continuous loop for a long time, and possibly burned out the eeprom.
PostPosted: Mon Dec 20, 2010 2:12 pm     Reply with quote
Obvious question - What chip - how much EEPROM does it have?.
