get and put
Bill Legge
get and put
PostPosted: Sat Dec 18, 2010 11:47 pm     Reply with quote
I've been learning/testing the get/gets and put/puts functions with the following code:
#include <main.h>
#use rs232(UART1,BAUD=2400)   // default, 8_bits, no parity
#define  HEARTBEAT   PIN_H0
   unsigned int8 caktr;
   // strings are character arrays with null terminator
   unsigned int8 string[30];
   // set ups
   setup_adc(ADC_CLOCK_DIV_2|ADC_TAD_MUL_0);
   setup_spi(SPI_SS_DISABLED);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL);
   setup_timer_1(T1_DISABLED);
   setup_timer_4(T4_DISABLED,0,1);
   setup_ccp1(CCP_OFF);
   While(1){
      printf("Type single character, it will be echoed\r\n");
      // program works OK if the next two lines are deleter ????????????
      caktr = getc();        // get one character
      putc(caktr);           // put one character
      printf("Type string terminated with CR(13),it will be echoed\r\n");
      gets(string);          // get string null added
      puts(string);          // put string until null
      output_toggle(HEARTBEAT);
It works OK if the lines between the ???? are deleted. What am I doing wrong?
Regards Bill Legge
Denmark in West Australia
'Where the forest meets the sea'
PostPosted: Sun Dec 19, 2010 4:52 am     Reply with quote
First critical thing, add 'ERRORS' to your UART definition.
This should (must!) always be present when using the UART, _unless_ you have written alternative ERROR handling code. Without this, if any significant number of characters (two or more) are typed in the long delay, or while the printing is occurring, the UART _will_ become permanently 'hung'. Might be your problem.
Then, what terminal program are you using?.
Bill Legge
put and get
PostPosted: Sun Dec 19, 2010 5:01 pm     Reply with quote
Thanks for your reply.
I will try the 'ERRORS' but think that it's my code at fault and not the RS232 link/comms. I've used RS232 for a few years now (but not with a C compiler) and not come across this type of difficulty.
Terminal emulators used:
1. The tool included in the CCS compiler.
2. The tool included in the ME Labs PicBasicPro compiler, and
3. Downloaded from: https://sites.google.com/site/terminalbpp/
After three days of hair pulling with trying to parse a simple, formatted incoming RS232 stream - and extract the data. I think I will download the code on this site from 'Dave' - although I'm starting to feel dumb that I can not write my own code.
Regards Bill Legge
